Break Controller - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Towing and Hauling - The Work Horse Forum
Thread Tools Display Modes
  #1
Old 02-20-2010, 01:33 AM
bcangelo's Avatar
bcangelo
Offline
brandon
Member's Gallery
Break Controller
My break controller took a dump. So I need to get a new one and was wondering which one i should get? Mine is getting power but not sending any, it is a BT brake mate.
__________________
2002 f-250 7.3 ex cab automatic, 4'' turbo back magnaflow exhaust. tonneau cover. SOLD
2011 f-250 6.7 Lariat fx4 with lots of extras!!Sold
2011 Screw Ecoboost 4x4 with ALL the options
Excuses are like butts, everybody got one and they all stink!
Old 02-20-2010, 05:57 AM
SIC-E's Avatar
SIC-E
Offline
Member's Gallery
Re: Break Controller
maxbrake!
__________________
2004 E450 Cutaway, 6.0L, quigley 4x4, ambul pkg., maxbrake cntrlr, curt 20k 5th whl. Future mods: 52" slpr, frame cover. Herd frt bmpr?
2003 E350, 7.3l, x-cargo
2003 JEEP, 17" Blk Moto Mtl 951's plugn 33" FC-II's, oops, not any more
1986 26' Seaway Northstar
2008 Montana Mtn'r 332PHT
1991 GMC Topkick, CAT
http://www.dieselpowerproducts.com/
  #3
Old 02-20-2010, 08:09 AM
Torque37
Offline
Member's Gallery
BrakeSmart.
__________________
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
  #4
Old 02-20-2010, 05:17 PM
Barnbuilder
Offline
Member's Gallery
Send a message via AIM to Barnbuilder
Torque37,
How do you like the BrakeSmart? The BC in my 99 needs to be replaced and was looking at it. Did you install it in the cubby hole?
__________________
1999 F350 CC XLT 4x4 6spd
2006 F350 CC KR 4x4
  #5
Old 02-21-2010, 12:27 AM
tbolt's Avatar
tbolt
Offline
Member's Gallery
Genisis, the best I've ever used.
__________________
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
  #6
Old 02-21-2010, 02:04 AM
Torque37
Offline
Member's Gallery
I have tried several different ones. Brakesmart is by far the best and most reliable. There is no need to adjust it from one trailer to the next. Yes I cut a hole big enough for the wire to go thru in the back of Cubby hole. It was such a good fit that I did not have to use any fasteners to hold it in place. Fits flush with dash and hasn't moved in the last 19K.
  #7
Old 02-21-2010, 04:08 AM
tbolt's Avatar
tbolt
Offline
Member's Gallery
The genisis has an inertia device that senses the stopping force of the truck and sends more voltage to the trailer. All digital, set it up once and use it for all my trailers. Maybe the same setup as the brakesmart. I don't know. But I love mine. Pulling a 12K+ toyhauler down some 6-9 mile 6% grades it works nice.
  #8
Old 02-21-2010, 07:41 PM
Barnbuilder
Offline
Member's Gallery
I believe the brakesmart actually ties into the brake hydraulics.
  #9
Old 02-22-2010, 02:40 AM
Torque37
Offline
Member's Gallery
Brakesmart uses a Hydrualic sensor on master cylinder, so therefore it always knows when your trying to stop. If you pull heavy loads often ( BrakeSmart or Maxxbrake) is the only way to go. I have tried several Timed, inertia, ect. They are fine for light loads. But when your loads exceeds truck weight, interia can't sense truck brakeing due to load pushing truck. The last one I had was a Prodigy P3, that thing like to got me killed. I am glad I purchased the Brake smart.
  #10
Old 02-23-2010, 05:58 AM
tbolt's Avatar
tbolt
Offline
Member's Gallery
My trailer is 12K+ loaded and I haven't had any problems with the genisis.
(View-All Members who have read this thread : 28
1bad306, 8nout, bcangelo, Cratos, cre440, Dave R, diesel_brad, dubswyoming, eric96ford, fhanrahan, flyboy41, FordCowboy, fordtrucksrule7, gnxtc2, Grapple, Grey91, jmontes, jrtcbmw, nchappy, raybass, San Antonio 78, t.land, Tom S, topshelf7.3l, Torque37, tree trimmer, woodduck97, xrcris
You may not post new threads
You may not post replies
Forum Jump
