DTC C1501 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 02-10-2010, 03:39 AM
SamW's Avatar
SamW
Offline
Member's Gallery
DTC C1501
anyone know what code C1501 is? truck runs fine otherwise, not counting injector issues. just might be a soft code but it has been there and cleared several times now...
__________________
2006 F250 CCSB
6.
Old 02-10-2010, 03:45 AM
PSDPlayer's Avatar
PSDPlayer
Offline
Captain Negativity!
Member's Gallery
Send a message via AIM to PSDPlayer
Re: DTC C1501
Light isn't coming on but there is a code in memory?
__________________
Website:www.gogodiesel.com Forums:forums.gogodiesel.com Facebook: www.facebook.com/GoGoDiesel
Email: Doug@GoGoDiesel.com
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
  #3
Old 02-10-2010, 03:55 AM
Mdub707's Avatar
Mdub707
Offline
Damnkids Motorsports
Member's Gallery
Send a message via AIM to Mdub707
Re: DTC C1501
What are you using to read the codes? I've had different programmers come up with different prefixes in front of the actual numeric code before...
__________________
DamnKids Motorsports
2006 F-250 6.0 4x4 Vegistroked
SCT Xcal2 w/Innovative Diesel Tuning 466/772 7/19/08
Black smoke don't mean it's broke... it means your tuning sucks!
Originally Posted by CSIPSD View Post
Paypal can go fuk themselfs... Buy me a beer the next time we meet.
  #4
Old 02-10-2010, 04:17 PM
SamW's Avatar
SamW
Offline
Member's Gallery
Re: DTC C1501
no cel, it shows up on the edge insight. might be something wierd about the insight and i know its not the best codereader but thought it might be worth checking into
  #5
Old 02-10-2010, 05:22 PM
PSDPlayer's Avatar
PSDPlayer
Offline
Captain Negativity!
Member's Gallery
Re: DTC C1501
I'm going to lean toward it being a phantom Edge make believe code.
  #6
Old 02-10-2010, 06:46 PM
06powerstroke's Avatar
06powerstroke
Offline
Member's Gallery
Re: DTC C1501
Found this in a google search, it is a ford-specific code.
"C1501 Transfer Case Contact Plate "C" Encoder Circuit Failure"
__________________
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
  #7
Old 02-10-2010, 11:02 PM
PSDPlayer's Avatar
PSDPlayer
Offline
Captain Negativity!
Member's Gallery
Re: DTC C1501
Just not to that vehicle.
4x4 Module codes for that truck would be...
B1317 Battery Voltage High 4X4 Control Module REFER to Section 414-00.
B1318 Battery Voltage Low 4X4 Control Module REFER to Section 414-00.
B1342 ECU is Defective 4X4 Control Module CLEAR DTCs. REPEAT the self-test. If DTC B1342 is retrieved, INSTALL a new 4X4 control module. REFER to 4X4 Control Module in this section. CLEAR the DTCs. REPEAT the self-test.
B1355 Ignition RUN Circuit Failure 4X4 Control Module CHECK CJB fuse 45 (10A) for an open. If the fuse is blown, GO to Pinpoint Test J. If missing, INSTALL a new fuse. TEST the system for normal operation.
B1359 Ignition RUN/ACC Circuit Failure 4X4 Control Module CHECK CJB fuse 33 (15A) for an open. If the fuse is blown, GO to Pinpoint Test J. If missing, INSTALL a new fuse. TEST the system for normal operation.
B1366 Ignition START Circuit Short to Ground 4X4 Control Module REFER to Section 211-05.
B1483 Brake Pedal Input Circuit Failure 4X4 Control Module GO to Pinpoint Test L.
B1485 Brake Pedal Input Circuit Short to Battery 4X4 Control Module GO to Pinpoint Test L.
B2477 Module Configuration Failure (Unconfigured, Incorrect or Rejected) 4X4 Control Module REFER to Section 418-01.
C1728 Transfer Case Unable to Transition Between 2H and 4H 4X4 Control Module GO to Pinpoint Test J.
C1729 Transfer Case Unable to Transition Between 4H and 4L 4X4 Control Module GO to Pinpoint Test L.
P0500 Vehicle Speed Sensor (VSS) Malfunction 4X4 Control Module GO to Pinpoint Test L.
P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure 4X4 Control Module GO to Pinpoint Test H.
P1806 Transmission 4-Wheel Drive High Indicator Short Circuit to Battery 4X4 Control Module GO to Pinpoint Test H.
P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure 4X4 Control Module GO to Pinpoint Test H.
P1810 Transmission 4-Wheel Drive Low Indicator Short Circuit to Battery 4X4 Control Module GO to Pinpoint Test H.
P1812 Transmission 4-Wheel Drive Mode Select Switch Circuit Open 4X4 Control Module GO to Pinpoint Test Q.
P1815 Transmission 4-Wheel Drive Mode Select Switch Short Circuit to Ground 4X4 Control Module GO to Pinpoint Test Q.
P1819 Transmission Neutral Safety Switch Short Circuit to Ground 4X4 Control Module GO to Pinpoint Test L.
P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure 4X4 Control Module GO to Pinpoint Test K.
P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit to Battery 4X4 Control Module GO to Pinpoint Test K.
P1828 Transmission Transfer Case Counterclockwise Shift Relay Coil Circuit Failure 4X4 Control Module GO to Pinpoint Test K.
P1830 Transmission Transfer Case Counterclockwise Shift Relay Coil Short Circuit to Battery 4X4 Control Module GO to Pinpoint Test K.
P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure 4X4 Control Module CHECK CJB fuse 27 (15A) for an open. If the fuse is OK, GO to Pinpoint Test I. If missing, INSTALL a new fuse. TEST the system for normal operation.
P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit to Battery 4X4 Control Module GO to Pinpoint Test I.
P1865 Transmission Transfer Case Contact Plate Power Short to Ground 4X4 Control Module GO to Pinpoint Test J.
P1866 Transmission Transfer Case System Concern Servicing Required 4X4 Control Module GO to Pinpoint Test J.
P1867 Transmission Transfer Case Contact Plate General Fault 4X4 Control Module GO to Pinpoint Test J.
P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure 4X4 Control Module CHECK CJB fuse 27 (15A) for an open. If the fuse is blown, GO to Pinpoint Test I. If missing, INSTALL a new fuse. TEST the system for normal operation.
P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short to Battery 4X4 Control Module GO to Pinpoint Test I.
(View-All Members who have read this thread : 32
02POWERSTROKE7.3, 04stroker6.0, 2005Ex6.0, amdriven2liv, BubbaNuke, CALADASH, dieselmac, Doug800, Ears93, FTREE50, Gibrid4x4, hillbilly123, Jagsdiesel, JuststrokeIT, keep'erpinned, Krisco, lght1, Logan21SV, Low Key, mandkole, MTNSTROKE, nbowlin, powerstroke02, ReconDieselPerformance, rtc0360, schlauderaff, tholt34, toddman35, twank11, wicked_four_play
You may not post new threads
You may not post replies
Forum Jump
