Trailer power - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Towing and Hauling - The Work Horse Forum
Thread Tools Display Modes
  #1
Old 02-07-2010, 01:34 AM
sagebel's Avatar
sagebel
Offline
Moved in
Member's Gallery
Trailer power
What do I need to do to put a 12v battery on my enclosed trailer? I am planning on installing some 115v lights inside powered by an inverter. I want to be able to charge the battery with the truck if possible. Would also like to power the break away switch as well.
__________________
2011 F250 CC 4x4 Sterling Gray Metallic
2010 Cannondale Quick 4 (pedal powered commuter)
Old 02-07-2010, 02:09 AM
bldnmup
Offline
Member's Gallery
Re: Trailer power
you need a 7 pin trailer plug system. it will have an aux wire you can use to charge the 12 v on your trailer. then just wire it all from your trailer battery accordingly.
__________________
83 f350 drw 6.9
97 e350 7.3
2002 f350 4x4 drw custom intake,4''tb,ts 6pos bad attitude
  #3
Old 02-07-2010, 02:46 PM
tbolt's Avatar
tbolt
Offline
Member's Gallery
Re: Trailer power
That's the ticket. It will only supply current to the trailer when the truck is running so will not drain the truck batt. Same setup as a 5th wheel or camp trailer.
__________________
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
  #4
Old 02-07-2010, 02:48 PM
tbolt's Avatar
tbolt
Offline
Member's Gallery
Re: Trailer power
That's the ticket. It will only supply current to the trailer when the truck is running so will not drain the truck batt. Same setup as a 5th wheel or camp trailer. Make sure your truck has the tow pkg if not your plug might not have the aux pin in the plug. Might have only lights.
  #5
Old 02-07-2010, 03:19 PM
sagebel's Avatar
sagebel
Offline
Moved in
Member's Gallery
Re: Trailer power
I have a 7 pin on the truck. I plan on running the hot wire from the truck to the + battery termnal and then ground the battery to the trailer frame. My concern is the power inverter. If I run it with the truck plugged to the trailer will I draw too many amps through the 7 pin connector? I don't remember how my dad's camper is set up.
  #6
Old 02-11-2010, 11:18 AM
Haztanker's Avatar
Haztanker
Offline
Member's Gallery
Re: Trailer power
You need to put batteries in the trailer to run the inverter, the wire from the truck is to recharge the trailer batteries, make sure the wire from the truck has a diode in the circuit to prevent the trailer from being able to discharge the truck batteries..
  #7
Old 02-11-2010, 12:29 PM
CGMKCM's Avatar
CGMKCM
Offline
Member's Gallery
Re: Trailer power
Why are you using 110v lights? Are you also going for 110v outlets? An inverter uses power to operate and along with lights will draw down a single battery fairly quick.
__________________
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
  #8
Old 02-11-2010, 01:57 PM
BFRD22's Avatar
BFRD22
Offline
Member's Gallery
Re: Trailer power
I have 12volt lights inside, and 110V floresent, along with a series of outlets.
Inverter powers the 110 when I need them, but 12volt lighting covers 99% of my lighting needs. Trailer also has a shore line connection to allow 110 usage, and 12 volt charging also. also us a small 2000 watt gen set.
12v rear load light at the rear, and will be installing new FRC 900LED Scene lighting on the out side of the trailer 12v.
Soon as it warms up I am installing an A/V system also. This is a mobile show room that I run around with and is a constant work in progress.
7x14 haulmark Kodiak.
__________________
2006 F-350 CC Lariat Sport, Black, SB, SRW, 6.0.
"Smokey 1"
  #9
Old 02-12-2010, 12:08 AM
sagebel's Avatar
sagebel
Offline
Moved in
Member's Gallery
Re: Trailer power
Trailer will be wired for shore power. I just want the inverter to run lights while off shore power.
  #10
Old 02-12-2010, 01:30 AM
tbolt's Avatar
tbolt
Offline
Member's Gallery
Re: Trailer power
Might eat the trailer batt quickly. Have you thought about a gen?
(View-All Members who have read this thread : 10
adam8333, edowney72, Ewilly, fordguy64, HoosierHick, Matt-F350, papamac, smorris, StrokerSmoker01, volkswagenflyer
You may not post new threads
You may not post replies
Forum Jump
