List of TSB's - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Power Stroke Nation! > The Library > [6.4L - Technical Info]
Thread Tools Display Modes
  #1
Old 01-27-2010, 05:59 PM
Turbo99's Avatar
Turbo99
Offline
Member's Gallery
List of TSB's
Mods cans we get a STICKY list of recalls put up on here so people can know what their truck needs or has had done?
I am in that boat where I am not sure what all is out there for recalls to be fixed.
__________________
_____________________________________________
Jeremy
08'F250 CCSB 4x4 ALL White except whats Black!!
10' Camaro 2SS LS3 All White except whats Black!! Supercharged 682 RWHP 11.13 @ 126mph
Old 01-27-2010, 06:19 PM
Turbo99's Avatar
Turbo99
Offline
Member's Gallery
Re: List of TSB's
Automotive Recall and Technical Service Bulletin Titles for 2008 Ford Truck F 250 4WD Super Duty V8-6.4L DSL Turbo.
TSB Number & Issue Date TSB Title
08C04 APR 08 Recall - Fuel Tank Impact Non-Compliance
08C01 MAR 08 Recall - Seat Back Pivot Weld Non-Compliance
07C19S1 NOV 07 Recall - Air Bag Replacement (Delivery Hold/Stop Sale)
07S49S3 AUG 07 Recall - PCM Update for Possible Exhaust Flame
07S50 MAR 07 Recall - Positive Battery Cable Routing
08B06S2 JUN 09 Campaign - Installation Of Cooling System Venturi-Tee
09L04 APR 09 Campaign - Customer Vehicle Maintenance Reminder Letter
09B08 MAR 09 Campaign - Replacement Of Fuel Injectors
09L02 MAR 09 Campaign - Vehicle Shimmy And Tire Inflation Pressure
08B07S2 DEC 08 Campaign - ECM/Instrument Cluster Software Update
07T07 JUN 07 Campaign - Fuel Injector Replacement (Delivery Hold)
09-12-15 JUN 09 A/C - Large Side To Side Temperature Differences
09-12-1 JUN 09 Body - Exterior Door Handle Loose
09-11-16 JUN 09 Interior - Seat Side Trim Loose/Broken/Cracked
09-10-2 JUN 09 Engine Controls - MIL ON/DTC's Set/Low Power/Smoke
09-9-1 MAY 09 Electrical - Trailer Wiring Fault/DTC C2806
09-9-8 MAY 09 Engine - 6.4L Diesel Belt/Idler Pulley Chirp On Start Up
09-8-5 MAY 09 Cooling System - Coolant Maintenance Service Tips
09-7-8 APR 09 Instruments - Compass Intermittently Loses Calibration
09-6-8 APR 09 Diesel Engine - Lack Of Power On Acceleration
09-4-1 MAR 09 A/C - Thump Upon A/C Compressor Engagement
09-4-9 MAR 09 Drivetrain - Vibration/Shudder On Accel With Heavy Load
08-26-4 JAN 09 A/T - 5R100W Cold Weather Failure
08-25-1 DEC 08 Diesel Engine - White Smoke In Cool Humid Conditions
08-25-9 DEC 08 Engine Controls - ECM Update For Various Concerns
08-25-7 DEC 08 Engine Controls - ECM Update For Various Conditions
08-25-8 DEC 08 Engine Controls - ECM Update For Various Issues
08-24-8 DEC 08 Body - Sunroof Water Leaks During High Pressure Car Wash
08-24-2 DEC 08 Wheels/Tires - Steering Wheel Nibble/Vibration
08-19-7 SEP 08 A/C - Slow To Cool
08-19-5 SEP 08 Diesel Engine - Normal Random Ticking/Tapping Noises
08-16-7 AUG 08 Engine Controls - Cylinder Contribution Diagnostics
08-16-2 AUG 08 Engine Controls - ECM Update When Replacing Accel. Pedal
08-14-4 JUL 08 A/C - Lack of Heat Output When Snow plowing
08-12-6 JUN 08 Body - Rust Stains On Front Bumper
08-12-9 JUN 08 Keyless Entry - Transmitter May Not Operate
08-12-10 JUN 08 Power Steering - Fluid Discolored, Noise or High Effort
08-12-2 JUN 08 Suspension - Front Suspension Noise/Bottoming Out
08-11-5 JUN 08 Windows - Power Window Noisy
08-5-1 MAR 08 Audio System - Radio Won't Seek Sirius(R) Radio Channels
08-5-14 MAR 08 Cooling System - DTC's P0528/P0529 Set
08-4-9 MAR 08 Interior - Ash Tray Broken or Loose
08-3-9 FEB 08 Body - Wheel Lip Mouldings Loose/Warped
08-2-3 FEB 08 Diesel Engine - Charge Air Cooler Paint Defects
07-26-5 DEC 07 A/C - Blower Motor Inoperative or Stuck on High
07-25-2 DEC 07 Body - Rattle Noise From Tailgate
07-26-2 DEC 07 Fuel System - Intermittent No Start/Low Power/DTC P003
07-24-2 DEC 07 A/C - Heater Core Gurgling Noise
07-16-6 AUG 07 Lighting - Ambulance Package Lighting issues
07-14-8 JUL 07 Engine, A/T Controls - Erratic A/T Shifting Over 50 MPH
07-12-8 JUN 07 Body - Cab Mount Bolt Removal
07-11-5 JUN 07 Cooling System - Vehicle Overheating (Snowplow Package)
07-11-10 JUN 07 Steering/Brakes - Brake Pedal Kick-Back/Grabbing
07-10-5 MAY 07 Body - Front Door Window Scratched
07-9-1 MAY 07 Electrical - Snowplow Lighting Issues
07-7-7 APR 07 Exhaust System - Exhaust Odor Inside Vehicle/Smoke
07-7-2 APR 07 Suspension - Rear Too High/Low for 5th Wheel Trailer
07-4-11 MAR 07 Exhaust System - Regeneration Functional Characteristics
07-4-3 MAR 07 Interior - Leather Wrapping On Steering Wheel Is Loose
  #3
Old 01-29-2010, 01:43 PM
dsgsr
Offline
Member's Gallery
Re: List of TSB's
Great info. Can ya tell me where you got that, I'd like to get a report on my 08 550 job-2.
Thanks,
David
__________________
'08 F550 5-yrd Dump
  #4
Old 01-29-2010, 01:45 PM
dirtboy25's Avatar
dirtboy25
Offline
Metal - It kicks your ass
Member's Gallery
Re: List of TSB's
What about recalls for all years.?
__________________
Modded L99
  #5
Old 02-02-2010, 01:38 AM
Turbo99's Avatar
Turbo99
Offline
Member's Gallery
Re: List of TSB's
Automotive Recall and Technical Service Bulletin Titles for 2009 Ford Truck F 250 4WD Super Duty V8-6.4L DSL Turbo.
09-11-8 JUN 09 SYNC(R) System - 911 Assist VHR Software Upgrade
09-7-9 APR 09 SYNC(R) System - Software Update For Various Issues
08-25-10 DEC 08 Engine Controls - ECM Update For Various Issues
08-21-2 OCT 08 Computers/Controls - Sync Software Programming
  #6
Old 02-02-2010, 01:41 AM
Turbo99's Avatar
Turbo99
Offline
Member's Gallery
Re: List of TSB's
http://www.alldatadiy.com/TSB/20/082063eL.html
Thats where I got it, you can goto the bottom and select different years,makes, and models
  #7
Old 02-02-2010, 01:42 AM
Dzchey21's Avatar
Dzchey21
Offline
WWDD
Member's Gallery
Re: List of TSB's
Stuck, thanks for posting the info
__________________
couple trucks one fast one not
  #8
Old 02-02-2010, 01:45 AM
Turbo99's Avatar
Turbo99
Offline
Member's Gallery
Re: List of TSB's
No problem
there wasn't anything for the 2010's
  #9
Old 05-07-2010, 03:39 PM
fowlerobsession
Offline
fowlerobsession
Member's Gallery
Re: List of TSB's
thanks alot for that info i have 08 6.4 with salvage title very light hit but ford don't cover any thing with braded title can't say as i blame them but i am dealing with the cooling system issuses right now on my own dime thanks again for that info
  #10
Old 05-07-2010, 03:59 PM
fowlerobsession
Offline
fowlerobsession
Member's Gallery
Re: List of TSB's
One other thing i just learned if your gaining oil on the dip stick on the 6.4 there is a TSB premature wear on the injectors O rings had a tech writer tell me that was one of the TSB to watch fuel going in to the oil NOT GOOD !!!
(View-All Members who have read this thread : 811
'01STROKER250, -TBAZZ, 03F2506.0, 03ghosthemi, 03sixspeed, 05_PSD_Erik, 08 powerstroke, 08-SPARTAN, 086.4SD513, 08azsuperdutyf350, 08CCSFL, 08eylerford, 08Ford, 08HDF350, 08psdbeast, 08pwrstrokr6.4, 08silverbullet, 08straightpiped, 17chief, 1995stroker, 1997P-stroke, 1JR, 1Quik46, 1ton ford, 1tontuna, 1willis1, 2001-7.3Liter, 2008 f350, 2008F350, 2008power, 2010stoker, 2500HeavyDuty, 2x6 bulldog, 2xturbo, 300savage, 350sd14, 387Stroker, 51N15T3R, 6.0.downlow, 6.0psd916, 6.4stroke, 64Diesel, 64folyfe, 7.3Mongo, 73JER, 75cj5, 79ford, 7powerstroke3, 87jumpy, 907superduty, 92fordcummins, 95onetonRigRide, 97F-250HD4x4, 97rattlebox, 99350sd, aaron250r, Adamsred08, AMB, amemark, amirzada1, AngryLepercon, ArmyStroke, Ar_hunter, ashby1, Atypical Sarge, awesomewrangler, AZ08, az94yj, azblazor, azleflyer, AZ_stroker, B585Ford, bae76, Bagged85s10, bassanglerbob, bbmxandfmx, Bci99, bckcx2, bdavis, bean, Ben328is, Benrubid, bentstroker_00, Berrybr2, bert, bert1076, BHenschel67, big adam, Big Jim 54, big trucker, big*diesel, BIG12Powrstoke, bigbadford01, BIGCSS, Bigdave, bigemiller, bigjim1961, bigmick, BigPSD, bigsix300, Bill Bennett, BillyBob427, billybobslm, Black086.4, BlackFord350, Blackharleyf250, BLACKSHEEP757, blacksunshine, blaff0428, Bldghosp, Blk350on20s, blk6.4, Blowby, bluedemon, bluedura, bluepower, bm1962, BMFPS6.4, bmwrcs, Bob B, Bob63, Bobbyt, bodidly, bohl345, bond james bond, Bongiardina, Borchers88, bp7000nh, bpb424, bradleyscott, brdgraf, brianb7.3, Brichmond, bridgesb51, brinkmannap, british columbia, brkncly, Bronx, brooksbronco17, Brown Dog, bts, bturet, bufasion, Buffalo644, bulldog01, BumpRacerX, bw350stroker, bwyche, c-money, Cajun Bear, Cajunhunter67, Camcyde21, CANNONMAN, Canttchtht, carguyz28, CarolinaStroker, Cass, cbenn, ccarter@philips, cchoptank11, CCSracer13, ch3rnobyl, chadder, Chainsaw1, Charris111, ChaseN, cheprice, CHILLNTENN, chodifer, chopper, Chrisp, chromehound, chuck55, civicrr, CJR, cliford, CLJones12, cmainer, cmestrokin, cnh, Cobra23, colfaxent, colombo97, Cool Canuck, Corey08FX4, county11, Cppr_Busa, Crack85, crack_7.3, Craig@MPD, Crazy Canuck, CrimsonClint, Csmith250, cstowe2120, CTC DEEZUL, cudaguy, Cumminsatya, Custerpsd, CutThroat, CWhiteRun, Da Oops, daddystoy, Dadx4, daguirre, Danger100, daryls377, davey99ps, dbs0026, dburton, dchelette, Deep C DVD, Deputydog, Derek2001, DEZERTCHASE, dfaust, dieselburner, DieselDave 04, DieselDawg1, Dieseldrew, DieselDZ, dieseljunkie1987, dieselman2442, dieselman64, dieselnut71, DieselPowrJunky, dieselstoke99, diggerdrew, Dirty Curry Racing, Diver86er, DiverMed85, DivingDriver, dlmoore, Dommel01, Don 6.4, DPS0925, dpwilson, dp_stroker, drdiesel, Drdiesel101, dswindell1230, Duanesz, DubleA, duckdog500, dulaneyjared, Dusty Roads, Dyingtwolive, Dzchey21, DZL JIM, DzlNut, eagles231, Earl Elwood, Easyrider6, EatBeef, EBBCLA, ebigbull, edy0way, eganracing, elcaminoman, ElCon, eleventhtruck, emmysdad, Enmerdeur, epj, eric.davis, Eski, Evil Diesel, Evil Eye, excavator, F250Ghost, F350CCSB, F350KR, f6boomer, Falcon121, Faraim, Farmall66, farmall99, farmboy8630, farmboy93, Farmer Kurt, farmman57, FastCars, fatboy456, fenner408, FiberGuy, firedobbie, firedog23, fishintexas1, FlatbedStroker, FLcruzin, Flippincgfighter, flyingbambaataa, fordfanatic69, fordfish, fordpilot83, fordtough97, fordtuff08, Ford_Fan_95, FrancesFord, frb918, Frenchy520, frusteri4, Ft.Mac.F350, fuekear, FullerF250, fxr hrd, G-Man, Garage_Biitz, garybrock, gcsb771wea, gfaststroker, ghohouston, Gibrid4x4, gmatt, Go Cougs, gomileshifi, Gooch, GooseNorth, GPD270, grantpaulsmith, greaseltn, greenbomb77, Greenshield, GREGW, Greyghost1, griffin6997, griz700rocket, GROSSpolluter, gruffwolf, gsxrjason, gtakamoto, GTOKILLER, HAMMER!, Happy Camper, harleysdontbitc, harper44, haus4205, Hawgleg, hawkeye, HD-tech-NH, hdemacy, headviking, HeavyBarrel1812, HER.F.350, herzog, highmtnstrokin, hillbilly06, Hobz, Hollywood, HOOV3R05, hopperwagonbob, Hoss1997, hotrodtoddcutty, Humvette, HYDAFTL, hydrobill67, hzepeda07, IA Farmer, ibkchatton, idajack, IDRich, ikeguy29, ilmathewspro, independentreb12, IronBelgian350, isistwinteryet, itn69, iwrock, J-RODLAWSON, jackadams, jackstraw212, jacmurr, jaderderr1, jake1086, jakeloney, jakemono, jamie5878, jaxral, Jaydiesel7.3, JaymesNelsonF250, jayps5, jaywebguy, jd844k, jdgleason, jdiesel_us, jeconn, jeenyus73, jeepdo81, jeepnfool, Jeff @ Spartan, jefhuf, jelvine1, jgerdes2005, Jglaze, Jhc, jim2by4, Jimmy4570, JKDoc, jmcghay76, jmhirshorn, jmkeck, Jmswrd, jnp1267, jockeyboy, joe22790, joec410, Joedog, joestroo, joey d, John Martens, John Mc, johnc2, JohnD8870, Johnny77Mutt, jonboy108, jordan572, josemab, Joshbaker, joshk, journeydog, jps601, jstreet, jsturki, jt720, jticp, JTr717, jugger13, jwzimmer, kade08, Karjalahti, Kaufmaniac, kawa900stx, kdsf350, keithevans, Kev1988, kingranch1, kleake, klm2307, Klutch, KnobHill, KPBJJ, KR69IDI, Kratos, KrayzKajun, Kris1785, Krlajwvater, krustytheclown24, KSent, ksigatmsu7f02, ktmr334, ktmrider, KTP\MW, ldds12, leadsled9, leer, leonelhag@gmail.com, leoneo01, LiftedMoose, LILGSX, lkn4snow2, Lmtdedtn2, looker_ford, lordnorth, Love2Strokeit, lusklxix, Luther's 2008, lyle wheeler, madtired1469, maninspokane, mar1nedoc, Marine13, maritimer10, markdan, markm, markt, Matt_P, maverick347, mc204689, mcalvert83, me2, Mercracing, metlmann250r, MFD T-3, mghay, Michael5126, michaels86svo, milesd830, minzbig, MississippiJoe, mjc, MLBOWEN, Mlopez3406E, Moby, MoonMan432, moore20017.3, moose1, moose87, moosedragger, morgan41, morph, MotoStroker, Mountainous, Mr. Perfect, MR.KITTEN, mrfandango, MrMike06, Mr_Grumbles, Mugsy, murr3061, Muzbomb, mxz6001, My08F250FX4, nastystroke04, NathanScott, navyeoseabee, ncfishermann, Neel, Neverforget0722, neverkickn, nickersonf350, nicktb, Nightshift, Nixon, Non-Mechanic, NorCal997.3, nspock, nukemF350, nutsandbolts01, nutsnboltsjp, NVR-FAIL, Oakley_XC, OBS F350, offroadjack, offshore121, oguck, oh-ate6.4PSD, Oh8stroker, ohten64, Oliver, om3ga, one2nine, OneStockQuik6.0, OnlyPolaris, orlyc, OUSOONERS, OVERKILL#1, passatdiesel, PaulBunyan, pieperz06, Pmac21, pondf4, Ponesty, Popsicle, poultry7178, powdersmoke4700, Powerstroke Man 6.4, Powerstroke Racer, powerstroke95, powerstrokedkid87, powerstroken03, powerstrokeshane, POWERSTROKE_GOD, Powerstroke_Kid, PowerSub, powr2stroke, ppmcevoy, Preems14, Prew32, pro185, PwrStrkNewbie, pyro6999, qtip, QuickSilver74, r1ramjet, RacerPuller, racrguy, Ranzan, raptor0690, rashole, rbowen9895, rbro7752, rbwyatt, rcrdav, Rebel350Ford, Red assassin, red superduty, Red1680, Redman08, Redneck6.0L, redneckcorvette, REGULATOR, Reiter, rhinopc60, rhoade667, ricg, rick914, Rickeyt, rickinnakusp, rickpolite, rickvm, ridiculous_einstein, rileyrs, RJC2, roberth58, robr1970, rockcentral4wd, RockinJW, Rocky mountain stroke, RollinCoal, rollininmy64, Ronin, RoughNeck7x, RoughReady86, rowdy350, RRandal, ruarkkustomz, Ruble, Rudy's Diesel Performance, ruizhernandeztrust, rustygrind, rvtower33, Sahrens0202, sallyrun10, Say_I_Won't, sbryan, scnd2none, scott2001, Scottbigred, scottylov, SCOUT8ID, SD08, Seabee08FX4, sego4, Semperfidoordie, seriousdiesel, SgtFury, sharper, Shaunvk651, shell_guy, Sher1021, Shockwave, shore, sideshow, silverpsd_06, simmy952, sixshooter, skidatyl, skidont, skobiak, slang23488, SledDogg, sledguy86, slightlycrazy, Sliver8, slowduty80, slowmans, Smoke59, smokenblack, SmokeWithEveryStroke, SmoKingRanch, smorris, snopro_69, Snowboarder7710, sn_frgsn, Soot Life F250, SouthernNights, Sparky351, spaz416, SPECIAL332, spence_08, srptdi, SSpeeDEMONSS, Stan M, stang13, stangman893, star73, steele6599, Steinbrenner, steveo27o, stevepsu, stickman89, stik, Stites02psd, stonecoldrn, Straitlegg, straitupmain, StrokeB4Cummin, strokin20, Strokin4life, strokinDa6.4, stroking350, strokingkid1392, stumperhead, sunnysace, Super Duty Dude, SuperDually08, SUPERSTROKED, Super_Duty08, supr87gt, suprdzlduty, svjmd, SVTStrikesBack, swalker, Sweed57, swiftra, swvaexcavator, T-Roy, TacomaTag, talon932, tavis43, TAYLORPOLARIS, TD-5, TDAVIS79, TeamChampion12, telarsen, tensixniner, terryv, texaswhimp, tgdameron, ThaStroke, The Rock, The Silverback, thecrazyhorse, themudgician, the_alaskan, thobui, tight, tim410, tims0566, tisbister, tjbrowder, tk250, Tknox, tnsmoke, toad01, ToddPSD, TONSOFFUN, Tony08F250, tonymontanna1983, toodldoo, topshelf7.3l, Toreador250, Tow21, trapt97, Tre Strokes, tricktom1, TripleE44, truckshop, TSizemore, TSND_6.4, ttrentha, ttwndoc, Tuckerdog11, tughill283, Turbo99, twank11, twisted twins, TXsmoker, TXStroker97, TXTech11, TX_S, tyoung, ulfan1972, umbrae, Unbelievably, UPTHECREEK, USMC_SKID KID, utlonghorns416, vanislejimmy, vanmhk, Varney, vatejf, Vermonter, Vin6.0, vintage way, VivalDee, vixentd, VixF450, vstahl, w8n4sno, wa96stroke, wamel, Ward, Wascatch, wbwright, webb06, White08, william351, winkfab, wizbangdoodle, Wizzard of Odds, wjamesm, wolfejeremy24, WoodBoy, woodys550diesel, woolf, Wreckedwolf, wvpowerstroke, wynndaddy, xltsp580, xSmokyx, xtreme01, xtrmn8r, yhatzee89, youngjTX, Youngwvcoalroller, zacfrrd, znunez72
You may not post new threads
You may not post replies
Forum Jump
