zf6 stuck in 6 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Transmission Related
Thread Tools Display Modes
  #1
Old 01-20-2010, 07:41 PM
chappy's Avatar
chappy
Offline
"Smoke A Lil Smoke"
Member's Gallery
zf6 stuck in 6
I have a chance to buy a 00 reg cab 4wd powerstroke for $3000.Only thing wrong w/ it is its stuck in 6th gear.Any idea how bad of a job it would be or what it could be.
__________________
2004 f250 egr delete,studded,fass 95,suncoast convertor,itp RR,Banks intercooler,58v tuned ficm,Powermax turbo,Matts tunes,6in Icon and 35 toyos 20x12 fuels
Early 99 exlb 4wd-SOLD All Shaeffer oil
Will Iott -8/24/84-7/4/10 "We miss you buddy"
Old 01-20-2010, 07:45 PM
roughneck0913's Avatar
roughneck0913
Offline
Member's Gallery
Re: zf6 stuck in 6
if your lucky pull shifter out and pry back into neutral. then check for worn parts in shift tower or make sure detent balls are still in place
  #3
Old 01-21-2010, 12:18 AM
badluck_early99's Avatar
badluck_early99
Offline
Going Crazy
Member's Gallery
Send a message via MSN to badluck_early99
Re: zf6 stuck in 6
yea usually if the are Stuck in a gear its something bound up wierd in the shift forks and not too bad to fix... its the not going in to gears that can be problems lol
__________________
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
  #4
Old 01-21-2010, 03:45 PM
chappy's Avatar
chappy
Offline
"Smoke A Lil Smoke"
Member's Gallery
Re: zf6 stuck in 6
sweet,alright that won't be bad then.
  #5
Old 01-21-2010, 08:03 PM
mnstroker's Avatar
mnstroker
Offline
Member's Gallery
Re: zf6 stuck in 6
if you dont pick it up send it my way
__________________
Back to stock for now.
Originally Posted by 1800joedaddy View Post
It's one thing to get cornholed... its another to pay for the cornholing!
  #6
Old 01-21-2010, 08:17 PM
mwalsh9152's Avatar
mwalsh9152
Offline
Member's Gallery
Re: zf6 stuck in 6
I used to get trucks all the time that were stuck in gear, and like has been said I just would take the shifter off and pry the forks back into neutral with a prybar.
even if the tranny is junk, its still a great deal. Id jump on it
__________________
1995 7.3 Bronco
  #7
Old 05-24-2011, 03:58 AM
greasygas
Offline
Member's Gallery
Thanks for all who posted on this subject
I am extemely gratefull you have save my canadian bacon by making it clear that linkage problems can be jury rigged without r R+R of the unit .. My situation the split pin pin partially wiggles out and causes the forks to bind ..(as seen when looking down in the hole with shifter off ) I did not want to try to replace the pin with a new one and cant really see any way its even possible ..my soulution so far is mild STeel wire laced thru the pin and twisted so it stays in place , and so far its all good news ! I want to get good synthetic fluid too and add that cooler to it as well and take advantage of the pump that is all ready there . you all saved me a lot of money time and skinned knuckles by explaining such a simple thing no on ever heard of before. Think of hundreds and hundreds of thousands of dollars in the hand of mechanics who would have sold a transmission and labor to so many suckers like me !!
cheers from Leon in ALBERTA
(View-All Members who have read this thread : 38
'99 stroker, 03_PSD, 99oilburner, a5t1, badluck_early99, Betaracer, Codydiesel, CTFFEMT, damons250, darklcdfeller, ddillenger, Dieselgeek, Dustin_Z, Goldknight, Goose1995, greasygas, hdchopfather, jarom, jawsfx4, kickstand, knoxville, madpogue, MASMOKE, me2, racerlt250r, Rockyardjo, roughneck0913, slayer7712, Smokin444, sniper_101, snorcr31, steve.s, tench372, tensixniner, The 250, tholt34, towin stroker, zs6.0
You may not post new threads
You may not post replies
Forum Jump
