7.3 wont start in cold anymore! - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 01-07-2010, 02:51 AM
j440
Offline
Member's Gallery
So heres the problem. Its been cold here for a few weeks now, lately been getting down into the teens, and even single digits. When I last fueled up (about a week ago) only put a half tank in. I didn't put the dieselkleen additive in (blew it off because it was starting fine lol) I sometimes plug it in, sometimes not it depends where I end up parking when I get home.. Either way plugging it in usually helps but now nothing. Anyways, I went to start it yesterday morning with a little bit less than 1/4 tank and it was plugged in. Started up fine, let it idle for about a minute (late for school haha) Took off, went down the end of my road and around the corner, stepped on it alittle to get up a hill and it kind of lost power and started loping, shut off. I let the GP's warm back up and tried again. It loped for about a minute straight and i tried keeping it at 1000rpms, warm it up a little bit more and it finally started running fine and by the time I got to school it was up to temp and running perfect.
Now, when I left school It was of course cold, started fine and then the exact same thing happened. So I poured about an OZ of the dieselkleen in the tank and got it to idle some how, eventually warmed up and I got home. Started it a few times when I was home and it was normal, fired up no problems. Eventually went out and filled the tank up and put the dieselkleen in.
This morning I went to start it, not plugged in. Cranked and got nothing. Waited for plugs to warm up a few more times. Fired up and idled for a few seconds, then started loping and died. Tried a few times and said F it and took my dads chevy to school. Got home and tried again.. same exact thing happened. It will fire after cranking for a while and run really rough, sometimes idle normal and then eventually die. I pulled the fuel filter out to check if it was gelled inside there (recent filter) and it was not. I tried the trick of putting cables from the positive terminal on the battery to the GPR, and it didn't do anything..
I'm thinking that its either gelled fuel or GPR/GP's.. What else could it be? Its been just plain cold here lately and it's been starting and running absolutely fine until these two incidents.
Anyone got any pointers..? Thanks
Old 01-07-2010, 03:10 AM
ditch_dawg's Avatar
ditch_dawg
Offline
Genius, when I drink
Member's Gallery
Re: 7.3 wont start in cold anymore!
I'd follow the instructions here to see if you have any bad glow plugs or a bad relay, which may help with the starting.
Cold Weather? Hard Starts? - GLOW PLUG SYSTEM TEST - Powerstroke Nation
But if it dies after you start it sounds like you may have gelled fuel as well. You can pull the fuel filter and have someone turn on the ignition key (don't actually try to start it) to see how quickly the fuel pump fills up the bowl.
__________________
'03 F250 CC
Truck Pics
"Beer is proof God loves us and wants us to be happy" Benjamin Franklin
Originally Posted by golfer View Post
blip the throttle, and you just changed your "HPOP" oil
put that on youtube
  #3
Old 01-07-2010, 08:48 AM
JerseyJim's Avatar
JerseyJim
Offline
Headwind Magnet
Member's Gallery
My truck is doing the same thing. I'm lucky that it's not my daily driver because I haven't been able to bring myself to work on it in this cold...
Definitely do the cold start problem procedure already posted. Also, have your batts load-tested as these motors can do funny things if they are weak; make sure you split the batts and check them individually. If you still have the problem then I think the next possibility is a sticky injector or two that doesn't like the cold.
I'm not sure where you live, but #2 diesel shouldn't start to gell in temps warmer than -10*F.
Best,
Jim
__________________
2002 F-350 SC/SB/SRW 4X4 auto- Tymar intake, AIH delete, Swamps injectors, Swamps IDM, Dieselsite Coolant Filter,
Bilsteins with a stock ride height.
  #4
Old 01-07-2010, 10:33 AM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
How does it do if you plug it in?
__________________
  #5
Old 01-07-2010, 07:20 PM
j440
Offline
Member's Gallery
i had it plugged in all night, cranked it this morning and it loped alittle and died. tried again and it ran rough but eventually evened out and warmed up. let it get to temp, drove it to school and it was fine. left it up on a hill at the parking lot in the sun all day (35 out today) and when i got back in it fired up right away but began loping and died. eventually got it going and got home..
than i let it run when home and took it for a spin around the block and noticed that the oil pressure gauge shot down when i put it under load quickly.. which means the HPOP correct.. now i kind of got nervous because thats really not to good of a sign. checked the oil and im really low.. probly 3-4 quarts low. noticed the oil cap was leaking and i last checked the oil about 1k miles ago. so im definitely low.. i know oil makes or breaks an engine and im kicking myself in the nuts for not checking that more frequently (but im used to gas engines... it doesn't smoke or leak so i didn't even think about oil..and it has low pressure because the gauge hasn't moved at all.. im going to do an oil change on it and put maybe the 5w30 or whatever you guys run in the cold with a new filter and all.. im guessing this is my problem.
i feel as if i ruled out the gelled fuel because i let it sit in the sun all day, and it did it.. plus, just because i plugged it in last night doesn't mean that heats the fuel either and it started this morning.
thoughts?
  #6
Old 01-08-2010, 02:06 AM
TrailerHauler's Avatar
TrailerHauler
Offline
Custom Trailer Sales
Member's Gallery
I'd change to a lighter weight oil and get the correct amount in there. Maybe check the hpop resevior before you cold start the truck and see if it's low, could have a drain back issue or even a weak hpop.
Sounds oil/ injector related based on your symptoms. Loping and dieing after its already started doesn't sounds like one of the two of those if a fuel issue is ruled out.
__________________
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
  #7
Old 01-08-2010, 02:35 AM
j440
Offline
Member's Gallery
going to do the lighter oil very soon.. along with a new fuel filter for ####s and giggles
  #8
Old 01-08-2010, 03:42 AM
tbolt's Avatar
tbolt
Offline
Member's Gallery
sounds like mine when I had to replace the uvch.
__________________
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
  #9
Old 01-08-2010, 05:10 AM
BDV/7.3
Offline
Member's Gallery
Glow plugs are touchy if they have been abused i.e. batteries without enough juice also they need AMP's around 1750 thats alot of juice for plugs and cranking just plugging in for a couple off hours is enough to help. Also try using power service instead of diesel clean I've used powers service for years in all my big rigs, and ultra low sulpher fuel can't be cut with kerosine anymore.(you can yourself get five gallons of CLEAR kero don't use dyed add it to your tank) good luck
  #10
Old 01-08-2010, 01:42 PM
opieg01's Avatar
opieg01
Offline
Work in progress
Member's Gallery
Follow the suggestions above.
Make sure your gpr and glow plugs are working
Your fuel should be alright, if it was gelled it wouldnt have any power or simply wouldnt start.
Make sure your block heater is working, should just tell by touching.
I use 5w-40 Rotella synthetic in the winter and starts like its 70*out.
3-4 qts in 1,000 miles? To me it seems like alot. Hows your blow by with the oil cap off and engine running?
__________________
2001 F-250 4X4 LARIAT Crew Cab,7.3, ZF6
GTX-4294r, Swamps 300/200%
couple other bolt ons
(View-All Members who have read this thread : 53
00PSD1, 1Macaw, 2dedge, 4.0l sahara, 97-BIG RED, a141sparky, AJDmotorsport, bigwheel, BlkNTan, bolt_bucket, Bowen Morris, Bunk, C bar M, cadd, Cholt86, Coleblythe3, CRZCNDN, DMDP, dorton413, dunavantsbodyshop, fordguy95, hatchman, IraqVetUSMC, isak, Jerodl, jp988, kickstand, lght1, Luke909, mtgrease, Myles_S, nickeagle, northid710, nossliw, oldblue96, PDEMICH, raradcli65, Red95stroker, REDTHUNDER, riley1131, RSP, Skooter_Built, Strokedout NC, tbutera2112, thecrazyhorse, thirty two, timar, Tom S, tomato76, vern232323, whytry, zankof
You may not post new threads
You may not post replies
Forum Jump
