04 5.4 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > Gasoline Engine Forum
Thread Tools Display Modes
  #1
Old 01-06-2010, 03:35 AM
cams-76
Offline
Member's Gallery
04 5.4
having trouble starting. takes a long time to crank over. any suggestions. and its cranks fast but just takes a while to turn over. its in a navigator
__________________
1997 cc lb 4x4 5 speed tymar 4 inch diamond eye straight pipe, 20 inch Eagle Alloy polished wheels,power hungry 6 pos tuned for stage 1's,idm mod,8000k H.I.D's. 4'' icon front super duty springs with sky 5'' rsk. rear 6'' icons for super duty. bilstien shocks. ebay special grill.
Old 01-06-2010, 01:43 PM
pappy19
Offline
Member's Gallery
Re: 04 5.4
How many miles on the plugs?? PCV valve changed? Fuel filter changed? Injector system cleaned?
  #3
Old 01-06-2010, 02:01 PM
woodduck97's Avatar
woodduck97
Offline
Member's Gallery
Re: 04 5.4
Did they maintain the motor by changeing the oil? Low compresion? Also if this is the 3 valve make sure you read the service bullitin on how to remove the spark plugs before you go taking them out. Also if you tune it up and its a 3 valve use the champion plugs they are made as one peice and will not seperate in the head... Good luck
__________________
1997 Ford F-250 Sleeper Edition
  #4
Old 01-06-2010, 10:52 PM
cams-76
Offline
Member's Gallery
Re: 04 5.4
its pretty low mileage. i think its around 60,000 or less. havnt changed the plug or the fuel filter. just the oil/filter and keep the air cleaner clean. how big of a job is changing the plugs and the fuel filter?
  #5
Old 01-06-2010, 10:55 PM
cams-76
Offline
Member's Gallery
Re: 04 5.4
what about the pcv valve and does cleaning the injedctors just involve putting cleaner in the fuel?
  #6
Old 01-06-2010, 11:27 PM
pappy19
Offline
Member's Gallery
Re: 04 5.4
Vehicle is almost 6 years old and the fuel filters should be changed every 15-20k. PCV valve every year. Injector system cleaned every year. Injector cleaning costs about $100 most places. Plugs should last for 100k, but maybe not. Check one and see. My son's 2007 at 62k needed replacing, so they should be checked. PCV and fuel filter are easy. If you use Chevron gas, most injectors don't need a cleaning, but any other gas used regularly should use an injector cleaner additive every few tankfuls and that should keep them clean.
Pap
  #7
Old 01-07-2010, 12:48 AM
cams-76
Offline
Member's Gallery
Re: 04 5.4
is the injector cleaning something that i can do? im sure it hasnt ever been done. and how much mpg will i pick up doing the pcv,fuel filter and injector cleaning?
  #8
Old 01-07-2010, 02:44 AM
pappy19
Offline
Member's Gallery
Re: 04 5.4
The injector cleaning is usually done at the dealer or at a Jiffy Lube, etc as it is a pressure cleaning system. As far as mileage gained, can't tell you, but the vehicle is bound to run better. Ever done a tranny fluid and filter change? Probably not, so get that done every 25-30k. If you want your vehicle to run good, you need to keep up with the regular maintenence issues, otherwise, it's a crap shoot.
Pap
  #9
Old 01-07-2010, 11:33 AM
woodduck97's Avatar
woodduck97
Offline
Member's Gallery
Re: 04 5.4
The injrcotors needing cleaned I dont think you need to. Just go to wally world and get you one of the injrctor cleaner bottles to treat 30 gallons and use the whole bottle and use 93 octane gas. That should do fine if you are worried bout it. The only time we have ever cleaned injectors really is when we have a veichle that has been sitting for a long time and has a slight miss. Also the fuel filter is pretty easy to do. With the new ethonal gas we have seen more filters clogged then when it was just str8 gas. As for the spark plugs go let us know if it is the 3 valve per cylinder engine. If so I would suggest not doing it your self and taking it to automotive shop cause if a plug seperates you will be having nightmares trust me. If it is the 3 valve engine I would take it to a shop as soon as you can and get them replaced with the champions. The longer you wait the more carbon that builds up on the electrode it will seperate in the head and then you will have to pay more money to get that plug removed and if it does not come out with the tool guess what. You have to pull the head or most shops will suggest a new engine. Just letting you know from experience.
  #10
Old 01-07-2010, 11:34 AM
woodduck97's Avatar
woodduck97
Offline
Member's Gallery
Re: 04 5.4
IF you have mecon V transmisson fluid the change intervals are more around 50 thousand miles iirc
(View-All Members who have read this thread : 9
00f250gasser, 01_fummins, 06SuperdutyFX4, carlrossander, KH250, mc44, socoman1988, suprdzlduty, ynkesfn2
You may not post new threads
You may not post replies
Forum Jump
