6.0L no start... Please help!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 01-05-2010, 10:54 PM
Mr. Bob's Avatar
Mr. Bob
Offline
Member's Gallery
I have a 2003 F350 6.0L with a no start. It does not crank over... After checking it out I found that the switched ground from the computer was not triggering the starter relay...
I jumped the ground and the truck cranks over but will not fire..
I have no fuel pump action... not getting triggered... I tried to plug the scan tool in and got no communication... I checked the computer for powers and grounds which were all good, so I took the computer and plugged it into another 6.0L truck and it started the other truck...
Any suggestions??
Thanks!
Bob
__________________
1995 Ford F350 XLT CC LB, 4X4, ZF5, South Bend Con OFE, 1996 Cummins, SDX 5X.014 injectors, HE351CW, 175 Pump, mack rack plug, .024 DVs, AFC mods, 4GSK, Studs and O rings and 60LB springs, Colt Cams II cam, 6637 air filter, 4" exhaust, PSD Intercooler, Autometer Cobalt Gauges
Old 01-06-2010, 12:04 AM
MoyockPowerstroke's Avatar
MoyockPowerstroke
Offline
Member's Gallery
Re: 6.0L no start... Please help!!!
Any suggestions??
Thanks!
Bob
I'd run it by cheezit on FTE.com
  #3
Old 01-06-2010, 12:24 AM
Tizzo's Avatar
Tizzo
Offline
Member
Member's Gallery
How/When did it quit running?
__________________
If your gonna be Dumb, You gotta be TOUGH
  #4
Old 01-06-2010, 01:16 AM
Jay03GT
Offline
Member's Gallery
You've checked all the fuses and PCM relay?
  #5
Old 01-06-2010, 05:39 AM
Mr. Bob's Avatar
Mr. Bob
Offline
Member's Gallery
Thanks
Died while driving I believe
Yes I have... all the fuses are good and the PCM relay is working...
  #6
Old 01-06-2010, 08:19 AM
PSDPlayer's Avatar
PSDPlayer
Offline
Captain Negativity!
Member's Gallery
Send a message via AIM to PSDPlayer
You say no communication. No communication on the network or the scan tool doesn't turn on? Does the cigarette lighter work? Datalink power is tied to the lighter, not the power point.
This thing really sounds like it lost key power. PCM turns on the fuel pump relay. Does the FICM even cycle the injectors when you turn the key forward?
__________________
Website:www.gogodiesel.com Forums:forums.gogodiesel.com Facebook: www.facebook.com/GoGoDiesel
Email: Doug@GoGoDiesel.com
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
  #7
Old 01-06-2010, 11:27 AM
kyle43335's Avatar
kyle43335
Offline
bring the chain
Member's Gallery
the computer shut down to protect itsself. all the negative outputs arent there. the samr thing happened to my truck. replace the glow plug controller. and it should be fine. let me know if this helps
  #8
Old 01-06-2010, 06:42 PM
Mr. Bob's Avatar
Mr. Bob
Offline
Member's Gallery
The scan tool powers up but will not communicate with the vehicle. The FICM does not cycle the injectors, the computer does not turn on the starter relay or the fuel pump...
Originally Posted by kyle43335 View Post
the computer shut down to protect itsself. all the negative outputs arent there. the same thing happened to my truck. replace the glow plug controller. and it should be fine. let me know if this helps
I unplugged the glow plug controller and it still does not turn the fuel pump or any other computer controlled component on.... Should I start unplugging modules until I get communication???
  #9
Old 01-06-2010, 08:11 PM
PSDPlayer's Avatar
PSDPlayer
Offline
Captain Negativity!
Member's Gallery
This is just funny.
  #10
Old 01-06-2010, 08:22 PM
PSDPlayer's Avatar
PSDPlayer
Offline
Captain Negativity!
Member's Gallery
I would go and check the 30amp fuse in spot 116. That's from the ignition to the pcm. As long as that is good. The first thing to disconnect would be the fan. Then start disconnecting sensors with VREF. Modules on the network would have their own issues.
(View-All Members who have read this thread : 60
03kingranch4x4, 04La4iat, 04MT, 04seater, 06 f250 man, 50gstroked, 6.0&SN95tagteam, 7.3rattler, 997.3PSD, 99whitePSD, Adinas95, ahardiek, bigblak250, Brad Trombley, brute_mt, caseyk, cheezit, CUMMINS_KILLA99, DNichols3288, droflakcin, evil 04, eyoung, flybykota, gaping46and2, genuineford, ghostrw, have12, hhansen, imthemedic, jdc753, jdjanetka, jimdman, Johnboy3, jtaylor75, markt, mattmankow, mct.in.tn, MHJ, oldbluef250, powerstroke765, raradcli65, Rhino6.0, RPMXTREME, sasquatch24, scenarioL113, seven.3psd, shamrock442, shatski, spicychicken, Stripp, Strokin304, Tbobhill, teo9554, tgaliger, thorguy57, toolmangary, turborangerdude, tyler886, wickedwhip21, yamanub
You may not post new threads
You may not post replies
Forum Jump
