turbo flutter? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 12-30-2007, 03:18 AM
bigfords
Offline
Member's Gallery
turbo flutter?
My uncle insisted on putting a Banks kit on his truck, so I helped him even though I don't like banks.
anyways, his excursion is an 03 6.0, and now he has a weird turbo flutter. Almost like surge, but under almost no throttle. Whats the deal, it sounds like a pulsing turbo, but not sure what the cause is. Does it even have anything to do with the tons of hours of banks work we just did to it?
Thanks
__________________
2000 F250 Red CCSB.Full Force 238/100s, BTS valve body, T-500. Normal bolt on stuff.
"Because HE Lives..."
Old 12-30-2007, 03:45 AM
fishinfool98's Avatar
fishinfool98
Offline
Go Away I'm Baitin
Member's Gallery
Send a message via AIM to fishinfool98
Re: turbo flutter?
what rpm range is this happening at???
__________________
06 CCLB SRW grey first mod was PSN sticker
LINK TO PICS
MY SPACE
Sailors may come
Sailors may go
Tis the engineer below
That makes it Suck, Push, Bang, and Blow
"Closed due to EXPLOSIVE diarrhea, will be back when the EXPLOSIONS are over!"
  #3
Old 12-30-2007, 03:30 PM
Logan21SV's Avatar
Logan21SV
Offline
Sponsor
Member's Gallery
Re: turbo flutter?
what kind of banks kit did yall put on? Did it change the tuning??
__________________
CenTexDiesel.com
Logan Schneider
830-885-6500
  #4
Old 12-31-2007, 03:31 AM
bigfords
Offline
Member's Gallery
Re: turbo flutter?
well as of now, I think the flutter went away.
It was a banks stinger kit I beleive, it had the intercooler and all
  #5
Old 12-31-2007, 06:20 PM
mxchase's Avatar
mxchase
Offline
lott is my daddy
Member's Gallery
Re: turbo flutter?
for the most part this is normal when you start to put more boost and more air into these engines...even stock it can happen.
its called "turbo bark" or "turbo fart" depending on your maturity lol. since these turbos are variable geometery turbos and not waste gated the only way the air has to go out when their is excess is back through the intake tube.
listen carefully when it does it- it should be from the intake side..specifically the intake tube. it happens when you are under boost and suddenly let off. try boosting to 10 pounds or so and completely let off the throttle and you will see what i am talking about.
this is not just a ford thing- my friends dmax does the same thing.
__________________
www.myspace.com/mxchase
i'd rather be hated by 12 than carried by 6
  #6
Old 01-13-2008, 11:19 PM
airflo71's Avatar
airflo71
Offline
Sponsor
Member's Gallery
Re: turbo flutter?
Absolutely, the 03's and 04's have this problem more so than new models becuase of the precesnce of a throttle body in the intake system and esp. when power modifications are made. When the turbo does this I call it a FURBO!! Some sort of pressure relief device like a blow-off valve can correct this problem.
(View-All Members who have read this thread : 76
!!!PainTrain!!!, 06-f350, 93cherokee, 94prez, airflo71, aquaman, arvel_a, B18B1LS1, badluck_early99, BDS, BigDirty '04, bigfords, BilletGarage, blackwaterstroker, BlueOvalDiesel, bondsman, brickhead, broncof250444, BUFF, Bushwakd, bustednuckles, capmaac, charlie99, CMPOWER, cowboy_dan, Diezel Dawg, DIRTBIKEZ, duckdog500, dusted4eva, f-150_xl, F350Powerhouse, fishinfool98, flyin_rhino, genuineford, GOT FUEL, GPD270, gtmustang00, hag000, HiVoltage, Java, jcc01, Jomull55, jvencius, Kmack, Kountryboy 6.0, kyle43335, Logan21SV, lucky, makaveli200369, mattymx, Mooring Product, NWSUPRD, NyCowboy87, Potter, pro350hydro, Pruitt Motorsports, PSD Trav, PSDnate, pwrstrk4x4, pwrstroke6john, RescueF250, samdust, slowleak, smokin dually, Steelmonkey, stonecold108, StrokeThis34, strokethis7.3, Strokin304, SUPERIOR OFFROAD INC., t350, tkdbf350, Turbodiesel6.0
You may not post new threads
You may not post replies
Forum Jump
