7.3 to a 460 Big Block swap?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 11-29-2009, 08:06 PM
woody_1's Avatar
woody_1
Offline
crittergitters.net
Member's Gallery
Hi, its been awhile since I posted.I had some truck issues.I blew the head gasket on my 7.3 .I am afraid if I just replace the gasket and not Fire ring the heads it will happen again. It seems it is going to be pretty expensive for the work on the 7.3 heads.I assume to much boost? I am thinking about selling the motor and going BIG BLOCK for the mud races.Something faster off the line.My question is I have a brand new BTS tranny E4OD with a PCS controller what do I need to change for the big block to still run this tranny? And I will have some parts or whole motor for sale in the near future maybe.It still runs now just builds pressure instantly. Any advise would be helpful.
Woody
__________________
1995 F350,AFE stage 2 ,3" Down pipe,4" Magnaflow Exhaust,custom Shackles,14" and 15" Atlas springs,54"Boggers,20"x14"wheels,2 1/2 ton rockwells w/ 6.72 gears,F-550 Disc brakes,High rise steering,Tranny cooler,Shimmed FPR, gutted EBPV.Autometer gauges.BTS tranny with a PCS trans controller,Stage 2 injectors,Tony's Wildman 6 position chip,Pedal mod.
Old 11-29-2009, 08:09 PM
davey99ps's Avatar
davey99ps
Offline
Davey B
Member's Gallery
Re: 7.3 to a 460 Big Block swap??
The bellhousing is different for 460 then it is for a 7.3
__________________
95 CCLB- 238/100s, H2E, termy t500, wipe out pushrods, comp 910s, mbrp exhaust, bdp tunes, and 8" lift
99 ex cab - Rolled 3/10/10
  #3
Old 11-29-2009, 08:15 PM
slowleak
Offline
Member's Gallery
destroked has adapters if i remember right.
with only stage 2's. i dont see you having a problem with studding the heads and leaving it be
__________________
PMRCM#1
  #4
Old 11-29-2009, 08:17 PM
davey99ps's Avatar
davey99ps
Offline
Davey B
Member's Gallery
Advanced adapters makes one to i beleive. Like slowleak said though, where your at power wise i would think it would be alot cheaper to stud your engine rather than building and swapping in a big block.
  #5
Old 11-29-2009, 08:46 PM
woody_1's Avatar
woody_1
Offline
crittergitters.net
Member's Gallery
Thanks,I have had a few bids on just the labor is around $2000.00 Then when they see the truck they back out.
  #6
Old 11-29-2009, 08:48 PM
countryboyrob
Offline
Member's Gallery
how many time has it blown a head gasket?
  #7
Old 11-29-2009, 08:52 PM
woody_1's Avatar
woody_1
Offline
crittergitters.net
Member's Gallery
First time.
  #8
Old 11-29-2009, 08:53 PM
slowleak
Offline
Member's Gallery
what turbo are you running?
  #9
Old 11-29-2009, 08:54 PM
woody_1's Avatar
woody_1
Offline
crittergitters.net
Member's Gallery
Just stock.
  #10
Old 11-29-2009, 08:56 PM
woody_1's Avatar
woody_1
Offline
crittergitters.net
Member's Gallery
The last time in the mud ,I looked up and seen the boost gauge 45 .Do not know where it was or if that was the max it hit.
(View-All Members who have read this thread : 8
7.3-StRoKeR, Bulldog, DMDP, EverettWV, ghostang93, kcbhiw, Mason Parker, thirty two
You may not post new threads
You may not post replies
Forum Jump
