#1
Lets talk turbos
Ok so we know that elite has modded stock turbo's
We also know that elite is working on a set of "big" twins. How big of a single would it take to make lets say 700 ish on fuel? And possibly not be TOO laggy and still tow... is it even possible?
__________________
08 F-350 CC/LB single turbo Elite studs, Elite 60hp nozzles, Elite modded injection pump, Elite egr delete with wastegate, Elite built trans, EDE valve springs and pushrods, hardened valve seats Single turbo done by METuned by: Eric@Innovative diesel & Mike@KEM performance 7.79@89 mph 1/8 mile 8100# race weight
#2
Re: Lets talk turbos
im curious to see how this turbo set up on the new 6.7 will hold up and how much power you can throw at it?
i would think with a ball bearing turbo and a wastegate like the new setups should take away from some lag on a larger set up...maybe a BOV to release pressure so the turbo can spool up a bit faster? my experience on turbos are with gas motors so i dont know how much different it will be comparing to the diesel
__________________
!I BUILD AMERICA! CARPENTERS LOCAL UNION 209 08 SUPERDUTY FX4 6" PRO COMP LIFT WITH FOX SHOCKS ALL AROUND 37X13.5X18 TOYO M/T'S |
#3
Will there be 2 chargers on the 6.7's?
__________________
97 250, 400/300's, ts, swamps fuel/tuning,gen3, s475 88mm turbine, Intercooled, h11 headstuds, fire ringed heads, built tranny. 3.55's, 236,xxx miles fastest obs extended cab on fuel 12.28@110 ![]()
#4
No the 6.7 is a single turbo. Pretty cool design too.
Look at the d-maxs Dustin, how big of a single can they run?
__________________
2000 F-250 ex sb 4x4 Swamped 7.3 (CR coming soon) 1999 F-450 cc fb 4x4 Swamped 7.3
#5
thats the new 6.7 set up
#6
Just one turbo, but it will have 2 compressor wheels on a single shaft.
Dave
__________________
Smokyred- '97 F250HD SCLB 4x4 OFFROAD 127k miles Mods: Swamps tunes, BFH-SE/TN 2 kit, Gen3, a BTS, Comps, Crowers, and H11's up top, BLiNGtake plenums, an IC, Comp. fuel system. ![]() Coming soon: Hopefully my injectors, but prolly not this pulling season. ![]() I was Swamped, when being Swamped wasn't cool. ![]() My Pictures |
#7
TO everyone else please try to keep it on topic.... |
#8
You could probably get close to 700 with a 64" inducer turbo. Would love to see a gt42r 53 trim on the 6.4.
#9
how much boost can that set up handle? |
#10
A buddy of mine has a 64mm turbo off of a duramax thats ball bearing, i might try something with that.... |
#11
A GT4094 hybrid would crush 700 on one of these engines.
#12
my buddy has a gt42r with a 1.15 exhaust housing...going to go take a look at it tonight along with the dmax turbo.
#14
a gt4202 should be capable of 750rwhp based on its performance on a dmax. the heads on the 6.4 may need some work to equal that.
the elite setup has already made just shy of 700 (fuel only) on the test mule.... i hope to be testing these shortly as well.
__________________
2008 6.4 CC/SB 4x4 |
#15
if i could get 700 i would be happy, what about towing ect, out of the question?
#16
i believe it would tow excellent ... twins help that..now a single..forget about it.
#17
so what about a gt42 and a modded stock high pressure turbo
#18
i believe the elite setup is similar to that, using a 76mm primary and a aftermarket VGT....
if i can have 700 on fuel and good towing...done. |
#19
how much boost are we talkin here to get up to 700+
#20
60 ish....
#21
64 inch should move some air but the lag might make driving in traffic challanging |
#22
Cant decide to try a 42r as a single or use it as the low pressure turbo...
#23
I think you could make a single 42 run well in every aspect. If your goin low pressure, dont be scurred, throw a 45 at it :
__________________
#24
well i would by my buddy has a wastegated 42 off a detroit, going to take a look at both of his turbos today, i gotta do something!!!
#25
With a complete elite built motor you will hit 700+ on just fuel.
#26
i dont have the 8k that it costs...
#27
I think you should set up a single, that would be rather sweet. And I figured a complete Elite motor would be more than 8k.
#28
I am going to save this quote.
__________________
RDRCM#10 A select band of brothers- We stand together as one. Giant VT3, 27 speed, shimano deore, hayes discs, manitou forks/shock, excalibur wheels, hutchinson tires |
#29
TURBO FAQ AND Info...... - IH8MUD.com
this site seems to break down the turbo as far as building your own or doing the math for it... it can also answer any questions that most have about turbos and how they work hope this helps! |
#31
#33
Does anyone have some pics of the engine bays with the turbos out and some pics of how the turbos are setup together. Just need to get a visual of these setups since I don't have one to tear apart right now. I'm the guy with the turbos i'm trying to help dustin get a setup figured out. Dustin you need to just let me tear your truck apart and see how its all setup then we'll build some bada$$ parts
Shouldn't take more than a couple months you could cruise the mustang till its done.![]()
__________________
Mike Haller Haller's Repair (307) 778-8880 shop@hallersrepair.com Located in Cheyenne, Wyoming |
#34
A couple months....
#35
I was just kiddin. Hopefully dustin can have something together alot quicker than that.
#36
i better gregrob is gunna get me if i dont... anyway what did a 42r come on? Any big cat engines?
#37
here ya go
not mine by the way, i had to find a picture of a clean one on the internet haha
__________________
2008 F-350 CC shortbed Dark pearl blue Spartan tuned w/275 tune Autometer Cobalt gauges AFE stage 2 Intake. 4" Flopro exhaust with 6" tip 4" ceramic coated downpipe Level kit with 20" Jesse James widow rims with 35" nitto mud grapplers Ram Air Hood Top Gun Customz dual steering stabilizer Pro Comp traction bars Suncoast Transmission |
#38
Dont know if this is helpful or not....but here is a couple pics of a 42R.
[IMG]
__________________
2001 Chevy Tracker. Auto. pwr steering. power brakes. tinted windows. |
#39
The other ? would be tuning like i said in my thread.sounds like it would be trial and error finding someone to take the time to get tuning rite.
#40
Thanks for the pics guys
Black 08 I think it will take some tuning to get right since its not vgt not sure how hard it will be |
#41
IMO, the right sizing and tuning on the 42, and I'd be willing to bet you could use it, and be effective. Of course there are gonna be trade-offs. But you could make it work.
#42
A 42 or a smaller S400 would be my choice. Using a T4 housing I think it would be fine. It's not a very fair comparison, but I drove around with stock AA's and an S465 with a .90 T4 housing and it was peppy and EGT's were very cool.
Dave |
#43
if you're going with the gt42...how will the valve train hold up?
#44
I am going with the EDE turbo's as soon as I get my truck back rolling under its own power. From here on out the sky is the limit now that I got a Suncoast!
#45
If drive pressure is reduced, then i dont see it being any harder on it, i actually seeing it being easier on the valve train, I think i will externally gate it, so i can regulate drive pressure and/or boost pressure to around 55psi.
John, good luck man glad to see more are going to push past the 600 hp mark on fuel. |
#46
dont we all
__________________
1999 F350 CCLB TerminatedDP F-6 OLD Setup: 38R, H-11's, Comp 910's, Crane Push Rods, 250cc hybrids 2008 F250 Regular Cab 4WD
SCT: Innovative Diesels extreme tunes Dirty Diesel custom's SS 3" intercooler pipe, Flopro 5" Doc/Dpf Delete Zex |
#48
Most 3408s 3412s in marine/natural gas applications have true twin 42rs.
__________________
CenTexDiesel.com Logan Schneider 830-885-6500
#49
Cool going to look at some c15 turbo's tonight and see how big they are... i was looking at the 42r with the TIAL SS exhaust cover, pretty sweet set up i must say.
#50
The way the uppipes feed the turbo's is scary how close they are to the same thing...
#51
Damn that is pretty close to the same.
#52
I know i cant find any pictures of the uppipes themselves to see if the flange is welded to the up pipe or if it moves.
#53
are those turbo's in the second picture off our trucks?
#54
yes the first and second pictures are right from ford THe last one is off PPE website for there 42r kit for the duramax, Im thinking i can make an adapter very similar to PPE and mount the GT42 inplace of the low pressure turbo, and get rid of the high pressure turbo, piping from there out looks pretty straight forward. Might even be able to use a stock style intake with a different elbow... not for sure just yet, going to dive in a little deeper tomorrow.
#55
where will the position of the turbo be on the motor and will the up pipes be of similar length?
#56
dont know if this might help you out some
#57
Going off of the pictures, depends on how the mount is built and what other constraints there are under the hood, but im thinking right in the same place as the low pressure turbo thats under the hood now, or at least thats what im hoping, I plan on not modifiying the stock up pipes, just adapting whatever i need off the up pipes to an adapter.
#58
Looks to me like Elite is using stock up-pipes as well, and they have made some sort of an adapter to the turbo, but i cant tell from that pic but it almost looks like a modded stock high pressure turbo.
#59
what about having the wastegate release the exhaust pressure from both pipes instead of one?
from the looks of the bolt patterns, 2 different flanges are made. |
#60
you could but you really only need it to release pressure from one side but idealy you would want both sides to go through the wastegate.
#61
but that would only be releasing the pressure through that cylinder head vs both, i would think?
wouldnt you want the exhaust gas from all cylinders to exit through the wastegate? it may work different for diesels rather then gas vehicles thats why im asking. |
#62
Yeah I would think you would want it to wastegate from both sides, but it must be working fine with a single side wastegated, the only way to REALLY know is to hook two drive pressure gauges up, one too each up pipe and see what the drive pressure is like from both sides.
#63
this is just my .02...
if you are planning on going to the single turbo set up, then i would get a 2 into 1 collector to flange up to new turbo set up with wastegate tube welded to the collector to release equal amount of exhaust pressure, and have to flanges made for the 2 into 1 collector to bolt up the up pipes for easy installation and or maintenence. it would especially help alot and eliminate some of the turbo lag that would be created if you only had the wastegate on 1 up pipe. it would be painless and in the end everything would be bolt on. |
#66
yeah stuff for these trucks are crazy expensive im hoping it works though and if so i will pay you to fab up the parts for me haha that is if its streetable. how much is the turbo setup
#67
i would imagine turbo and wastegate would be the ones to break the bank, haha!!!
#68
The cheapest turbo i can find is around 2100 bucks just for a turbo with a 1.01 exhaust housing. Its a ball bearing so it should light pretty fast, I wont say that i will produce a kit, but i may make a few extras. |
#69
maybe try and use an internally gated exhaust housing. i dont really know to much about garrett turbos but if you end up using a BW turbo im sure you can find a gated housing from someone. i will try and call up my friend at his turbo shop and see what housings i can find for a t4 flange. what size exhaust wheel are you guys thinking about running?
__________________
06 orange stroker
#70
we'll see how it works first, i think if i can light it pretty quick at 6000 feet that anyone should be able to run it. |
#72
i think for faster responce for the turbo that an external wastegate is the way to go and also being that you're aiming for big power
#73
yeah thats my issue too damn elevation haha. if i didnt need my truck so much i would let you test on mine
#74
A borg werner style turbo would save on cost significantly but you can't get one that is ball bearing. I'm trying to round up a used one for you but most people with a ball bearing turbo dont' sell them.
#75
thats what i told him.
#76
I know you really wanna setup a good fuel only truck. But nitrous cures alot of spool up problems if we were to go with a non ball bearing cartridge. Also if you buy a journal bearing cartridge turbo and get it all mocked up you can buy a ball bearing cartridge later to swap in as they are completely interchangeable. Just some thoughts. But i'm going to bed so i'll talk to ya tomorrow.
#77
is the 84mm on the 42r the inducer or the exducer size?
#78
#79
http://www.bullseyepower.com/seepicture.asp?b=4&bc=50 http://www.bullseyepower.com/seepicture.asp?b=5&bc=50 This is the bullseye mount for the d-max. It's only 300 bucks. |
#80
how big is the inducer size on both turbos stock for the 6.4?
#83
56,65 i think
#84
thanks dustin me and BFT are still talkin to the dmax guys on the diesel place. they are bullheaded.
any new updates on your turbo ideas |
#85
Im doin the 42r for sure, just need funding for the turbo and a wastegate, then its going on.
#86
you should do what josh did and see how many people can contribute to the turbo project, haha!!! worth a shot...
#87
The only thing I am worried about is cylinder head flow, duramax's have better cylinder heads, so a single probably makes more power on a dirty than a powerstroke, but hell i will give it a shot, if it doesn't work, ill put a 64 as a bottom turbo, but im hoping to do this one time
#88
right on man cant wait to see it happen. we already tried one of those for a tcm for him but it never happened hahaha
#89
Ill keep everyone posted and i will take alot of pictures when i do it, Im hoping to use factory up-pipes, Flo-pro down pipe, and even a factory intake if possible, and BFT im going to do like you said and put the wastegate in a single pipe before the turbo, so it relieves drive pressure on both cylinder heads, I really hope this works, I'm taking a big chance of trying something new and i dont wanna fail too bad . But i do know at this point that an full egr delete must be done to make it work. Or at least run an air filter ![]() |
#90
if dustin is a good boy, psn might help him with a 42r ....
#91
sounds like santa clause is drivin a mean green 6.4 powerstroke
#94
good. Its an 07 yamaha yz450 ok buddy |
#95
that bike would go good with my 07 yfz450
how much |
#96
I got it advertised for 3750...
thats funny great minds think alike. |
#97
i will definately think about it though i got some buddies wantin bikes too |
#98
Cool man no worries.
#99
Has anyone thought of modding the stock low pressure turbo? Different housings with a bigger wheel?
__________________
2009 F350 CC SB 4X4 Lariat Ultimate package Black on black Spartan tuned -JD |
#100
Thats exactly what elites "tow compounds" are
#101
I tried to tell you just remember that.
__________________
2006 Triple Turbo Dodge My name is RAM and my coolant tank is full. |
#102
I see.....
(View-All)
Members who have read this thread : 5
| apollyon9515, boots1219, DKrazyKracker32, mertz, Santa Gertrudis |
| Thread Tools | |
| Display Modes | |
