05 6.0 smoking problem////warrenty? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 12-18-2007, 12:30 PM
couldbelower
Offline
Couldbelower
Member's Gallery
i have a 6.0 f350 crew cab. the truck has started smoking pretty bad for the first few minutes the truck runs each time its started up if it had been sitting for a few hours. the smoke is white smoke and seems to be getting worse but it is very inconsistent. some days seems bad and then the next day not so bad. i have read a lot about bad head bolts causing the head gasket to leak. everytime i get an oil change even before this staretd i would need my collant filled sometimes a little but other times a lot more. the truck has 80 k on it.
i am trying to figure out if this will be covered by its 100k motor warrenty. i also am starting to get a rear main leak and front main leak. i am hoping to get all this fixxed at one time in hopes that the warreny will cover it.
does anyone have any warrenty expierence in any related situations.
also the truck has an 11 inch lift on it and a full 4 inch exhaust from the turbo. will that be of any factor?
any help is appreciated.
Old 12-18-2007, 01:46 PM
Evil Eye's Avatar
Evil Eye
Offline
Slacker
Member's Gallery
Re: 05 6.0 smoking problem////warrenty?
White smoke is either EGR cooler or HG's. More than likely it's your EGR cooler. Both are common problems.
Get the truck in and take any tuners or programmers off the truck. The lift and turbo might get you some flack from the service manager, but shouldn't have any affect in having your warranty work done.
__________________
Shawn Carlson
Proud Navy Vet
2005 F250, CC, 6.0 PSD, FX4
(The Sweet Unit)
  #3
Old 12-28-2007, 03:12 AM
RescueF250's Avatar
RescueF250
Offline
The Unseen Mod
Member's Gallery
Send a message via AIM to RescueF250
Is it tuned ? sounds to me like head gaskets and studs man. Yes thats cover under warranty as long as you dont have it tuned, or if you are cool with the dealer, the rear main and front are covered by the warranty.
__________________
Thanks to Doug at GoGo Diesel, Matt at Gearhead, Ryan at Full Force, Vivian at Quick Tricks, Greg at Diesel Power Products, Adam at First Coast.
  #4
Old 01-04-2008, 11:36 PM
mxchase's Avatar
mxchase
Offline
lott is my daddy
Member's Gallery
lift wont hurt. most ford dealers will honor warrantey with out a cat in place, some will require your cat in place.
sounds like exactly what mine did. i had an EGR problem. took it in and got in back 3 days later.
__________________
www.myspace.com/mxchase
i'd rather be hated by 12 than carried by 6
(View-All Members who have read this thread : 60
00Rich, 05 6.0, AMB, B18B1LS1, badluck_early99, bassrippin365, beast6.0, BigTonka, BUFF, CATdiezel, cemeyer, Century Coronado, CGMKCM, charlie99, couldbelower, danf250, daryl4412, Dieselboy, Dirt_99, dsanders, East County stroker, Evil Eye, F350Powerhouse, farmerrich, genuineford, GotRox, GPD270, greenbeast, HiVoltage, jasonl, Java, Joedog, jvencius, JW45, Logan21SV, lownslow, matthewd11, Mr. Bob, muddslgn, Orezona, peanutsfive, Power Stroke, PSD Trav, razorscs, RescueF250, Rob05F350, rottys, southbend_powerstroke, Stiletto6.0, txpsdcrwchf, xP12ODIIGYx, yamt03
You may not post new threads
You may not post replies
Forum Jump
