6.4 front seal leak...3rd time in.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.4L Power Stroke - Technical Info
Thread Tools Display Modes
  #1
Old 10-09-2009, 05:41 AM
RKracing's Avatar
RKracing
Offline
Member's Gallery
Front seal leak ....small leak but still.....3rd time in 15,000 miles.....What the hell is going on? Any body "been there-done that" ?
Old 10-09-2009, 06:01 AM
bigrpowr's Avatar
bigrpowr
Offline
Laces Out
Member's Gallery
Re: 6.4 front seal leak...3rd time in....
ive heard about this. mine had some residue underneath the crank but never a leak. i wonder why your's would leak more than once!!!
__________________
08' F250 4x4 w/ 3:55's
  #3
Old 10-09-2009, 02:43 PM
fbilly420's Avatar
fbilly420
Offline
Member's Gallery
Do you know if the are replacing the sleeve that goes over the end of the crank with the new seal? I have heard that if it is not replaced with the seal it is more likely to leak.
Or they could be installing it incorrectly I just finished the 6.4 courses through Ford.
__________________
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
  #4
Old 10-09-2009, 10:39 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Offline
Stroken it 7.3,6.0,6.4
Member's Gallery
Is to much boost causing this?
__________________
08 F 450 King Ranch 6.4
Elite Race trans, Spartanized, ARP, Icon 4.5 on 35's, RDP boots, HID'S, OUO ladder bars, 3" I/C pipe
04 X 6.0
08 tow mirrors, ARP studs, RDP boots.
01 X 7.3, Dp, Cass 238/80 Hybrids, Terminator Dual pumps, TNBB holding on for dear life @40+psi, TE thermostat, ARP studs, Fluidampner, RDP 6637, RDP boots
  #5
Old 10-11-2009, 06:34 PM
cbenn
Offline
Member's Gallery
Mine did this when I was out doing the learning process for my new TCM/275, but it was just a small amount, not enough to even make it drip, wiped it off and so far it hasn't done it again, I thought it was from doing the learning process as I had my foot into it real hard and most likely my boost was real high during this process, right now I'm not going to worry about it as I don't normally run my truck that hard, cleaned it up real good and just watching.
  #6
Old 10-14-2009, 11:26 PM
RKracing's Avatar
RKracing
Offline
Member's Gallery
OK...My bad....Not a dripping leak but heavy residue.....about to leak...you decide...will post pics as soon as I can.
  #7
Old 10-15-2009, 12:39 AM
aggie's Avatar
aggie
Offline
Member's Gallery
Ive seen it too. Happened in the first 1000 miles. was replaced and hasnt leaked since. If its anything like a rear main on a 7.3, you have to replace the seal and the ring together.
__________________
[SIGPIC][/SIGPIC]
http://www.trucksourcediesel.com
  #8
Old 10-16-2009, 01:57 AM
RKracing's Avatar
RKracing
Offline
Member's Gallery
Here's 2 pic's.
  #9
Old 10-16-2009, 02:03 AM
Dzchey21's Avatar
Dzchey21
Offline
WWDD
Member's Gallery
mine looks pretty much just like that, either high boost or a poor seal design is causing it, im not taking mine in untill it leaves a drip on the ground
__________________
couple trucks one fast one not
  #10
Old 10-16-2009, 02:24 AM
roughneck0913's Avatar
roughneck0913
Offline
Member's Gallery
the seals on a 6.4 are designed to be put in dry there teflon coated the tech putting seals is is probably coating seal or crank thus ruining the seal and it will leak they need to put seal in dry and clean crank and use the special seal driver should seal then just my .02
(View-All Members who have read this thread : 83
03 stroker, 03silvertj, 03sixspeed, 2000Censtroker, 444CuiOBS, 7.3, Aaron S, aircooled, allblack08, BIGBLUEFX4, BigRedBlackSmoke, billv999, Blowby, bscooter99, btaylor08, caleb90, chunkdunker, Corey08FX4, Cory151, DieselDZ, dieselstoke99, Dieslnevan2009, djen223, dnabrillhart, drh4250, DzlNut, eshpile, F350 CC SB, floridastroke, forddude343, fordpowerf450, frusteri4, George C, greaseltn, haulin99sdp, Hotnail, IHPowerstroke7.3, ilmathewspro, jrp67, lxcoupe, matt1183, mattbo505, michaelleblanc, MikeSherman, MJO8585, Mugsy, mydually, NickNasty18, niklid05, Pan4905, rblood, Roenicke95stroker, rshosted, Rubenk, ruizhernandeztrust, sanocafire20, scott2001, Screamineagle 2008, scubasteve77, Silver Beast, sledder, snieto08, SoTexRancher, Specializeddieselnw, Stallion Forward, stroked99_1/2, TeamChampion12, tmartin, tony97gt, travisH3, tree trimmer, treetechsixOH, uga33, Uncle Buck, Ward, wfodiesel, White_monster, wispy, Wizzard of Odds, xrxmxcx, youbetcha, Zooky
You may not post new threads
You may not post replies
Forum Jump
