Adding Intercooler to 95 OBS - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 OBS Power Stroke - Aftermarket & Performance
Thread Tools Display Modes
  #1
Old 12-12-2007, 01:28 AM
RevBubba
Offline
Member's Gallery
I am not sure about thh different years of bodies yet as i am new to Powerstrokes. I just picked up a 1995 5 speed with Luk clutch and downpipe.
I have been told I will need to replace my injectors soon...since I am doing this I want to put in bigger injectors...of course this brings up a lot of other changes that could be done.
As my truck tows a 28 foot travel trailer I was thinking an IC was a valuable option to keep everything cool and happy...plus it will allow me to push the power level a bit more.
I have looking into a Banks IC and they have a kit I could put in. It comes with directions and everything I need to make this addition. however, the costs are a bit high.
I have heard of guys putting in 6.0 or later 7.3 stock intercoolers. Are these as effective as the Banks unit? I am not a welder ( well I can use a cutting torch but MIG and TIG are out of my skill level) so the Banks pipes seem like a great idea.
So looking on feedback as to which is the better option for a shade tree mechanic. Banks ( or some other IC kit) or the 6.0/7.3 mod.
Thanks
Old 12-12-2007, 01:37 AM
444smoker's Avatar
444smoker
Offline
Built By Me
Member's Gallery
Re: Adding Intercooler to 95 OBS
Well yes the banks kit is expensive but its a bolt on kit no welding required, It works okay there is alot better ways to go with intercooling but in most cases requires welding of your own piping. Spearco, Hypermax, DIIC, City Diesel, all make a much better intercooler that is more efficient than the banks system but due to your situation Id say the Banks intercooler and a set of stage 1s from one of the vendors on this site, and Jodys (DP Tuner) programing will make that truck a good towing and Daily driving truck.
Robert
__________________
1996 Red OBS
Built Motor
DP Tuner
Garrett GT42
ARP Fasteners
Terminator HPOS
B-Codes
Crower rods
filled block
560hp
http://photobucket.com/444smoker
  #3
Old 12-12-2007, 02:05 AM
RevBubba
Offline
Member's Gallery
Well I am wanting to push teh envelop a bit more than that
So it is better to get the intercooler from one of the other vendors and have get a fabricator to make up the piping for me?
Who would you recommend for the best bang for the buck IC?
  #4
Old 12-12-2007, 02:36 AM
Tom S's Avatar
Tom S
Offline
-Moderator-
Member's Gallery
Best bang for buck is a used 7.3 cooler. Intercooler for OBS takes some work even the Banks one. You also have to consider how you are going to address the pumbing at the intakes too.
Tom
__________________
96 F250 4X4 AUTO
  #5
Old 12-12-2007, 03:34 AM
TerminatorEngineering's Avatar
Offline
Sponsor
Member's Gallery
Tom is right! I think Banks sells the pipe kit, or you can build your own. It's a lot of work, but worth it in the end!
__________________
Visit us at: www.TerminatorEngineering.com for all your Big Oil needs.
SDRCM #7
  #6
Old 12-12-2007, 03:53 AM
Aljay's Avatar
Aljay
Offline
Don't EFN worry about it
Member's Gallery
Yep I have a plastic 7.3 cooler and the pipes were cut and fabbed by me and a bud.
__________________
97 crew cab shorty-4x4
Overfueled for your pleasure !
Didn't ancient cultures make slaves or people they felt were INFERIOR carry them everywhere???? That's the way I see it .
  #7
Old 12-12-2007, 04:07 AM
crfracer's Avatar
crfracer
Offline
Member's Gallery
Talk to Powerstroke Racer, I just bought an all aluminum 7.3 IC from him for my 96 F250, and I think he still has a couple floating around. He was really good to deal with. As far as the plumbing goes, I couldn't tell you, I haven't tried to install mine yet, but I will probably build my own plumbing or if I can find someone other than banks that I like, I might go that route. Good luck.
__________________
1996 F-250 ext. cab, l/b, 4x4, john wood trans, home built intake and 5" stack, and more in the works
Go to: http://powerstrokenation.com/forums/...ead.php?t=3857
for an up to date story on the build.
  #8
Old 12-12-2007, 04:10 AM
Aljay's Avatar
Aljay
Offline
Member's Gallery
Stock drivers side with 12' of tubeing added to the cooler end. Pass side is a cut up 6.oh with some parts from a pass side 7.3 tube added. Mine work well and do not blow off. I used all stock boots and clamps also.
  #9
Old 12-12-2007, 05:26 AM
blk99
Offline
Banned
Member's Gallery
Send a message via Yahoo to blk99
go here link and look around. They have a kit also. You will eventually find it if you look around enough.
  #10
Old 12-12-2007, 07:12 AM
RevBubba
Offline
Member's Gallery
Thanks all for the tips and links.
(View-All Members who have read this thread : 384
'94IDITurbo7.3, 00PSD, 12v Ford, 1950gmcelc, 1978psd, 1997F350CCLB, 1997F350powerstroke, 1997stroker!, 19Dually97, 1TonStroker, 300,000 and counting, 444smoker, 4x4, 59fordcummins, 70DS, 78f100, 86turbodsl, 8LugThug, 94.5stroker, 94idi, 94youngturbo, 95rdstroke, 95tutone444, 96Crewcab7.3, 96pstroke, 96stroker5spd, 97 flatbed f-350, 97f350powerstroke5speed, 97PSD350, 97RuffRyd, 97stroker_08, 97_Stroker, Adam.Niesen, AddictedOffroad, ag71953, AKHILF574, AlaskaRedneK, Allister73, Alvapowerchoke, AMB, Badbob, BadDogPSD, Bamboo, barney1, Bayonet16, bert, Bigcody, BIGK, Big_Dan97, billmoody1, Binder man, birdco85, blacksmoke powerstroke, BlindViper, blown smoke, bluetech151, bobs96stroker, bolt_bucket, Bones96, Boomer22, borncountry, bpa658, bracketracer, brahum, Brian Cox, brock96stroker, btomassacci, Bulldog, caseyk, ccarrier, ccf350stroker, CCLBpsd, cemeyer, Chad Edwards, charlie99, chevyhurstolds84, cheysays7.3!, Choupique108, ckbed, clayc_989, clutchkick512, CNDiesel, co04cobra, Copperhead, cowboy_dan, CO_dairyman97, cr8zyfool, cracklin'stroker, cravin, crazystroke97, crewcab7.3, crfracer, cuebal84, CURTIS250, dajain, dalejrfan88, danielzink, dave186, davewild, dave_k96, david212acu, DCBILL, deerefanatic, Deererainman, Delox, DIesel is my life!, dieseltec192008, diesel_brad, Dirt_99, DMOSE10, Dragon, dragonboi, drake162, DRT1359, dsmfitty, dt6999, DZL JIM, DZLAL, dzlj 50, elk junkie, eric96obs, ethanharkins, EverettWV, f250rollinon37s, f250towrig, farmboy93, farmerrich, fastbee, fatkid350, fatsix, fieldtech, fitzgood, fitzih29, forddieseltweek, FordF250Stroker, fourwheeldrive9, Frenchb85, friskyjake, fuelman, g0nef1sshn, Gearbox, geargrabbin97, glovemeister, greaseballcreeper, Greger96obs, gstang408, gsxr1216, haddixj, halfbreed, hehman250, hellerb68, highfive, HMWH, HOLMES, hopkinsphillip, Hunter'97, ibuytoys, IHWelk49, iluv83vettes, Jake N, Jarrett Johnson, jbrixen, jbt8080, JCart, Jchappy12, JD3020, Jeepermc, Jeffro92, jeremiahmercier, jeric1, JGod, jim dandy, jkrum10238, JML93, joebob3093, JohnDeere9610, johndeereman, Josh+KTM+F-250, Jp667, jrracerdad, jschildm, jsnyder7.3, Jstrong43, junkyrddog780, just shawn, juststrokin', Just_Spoolin_around, jvencius, kawamatt2, kbmkviii, KDM, kenny, kip4234, klos, kmanxj, kokanee kid, krafty, kritter78650587, Kyle Parson, Lakerat, Lamont_24, lex, lifestroker97, LiftedSuzuki, Lildiup, Litnng, Logan21SV, louisvanwilker, lownslow, M8xpld, mandkole, maritimer10, mattymx, MB97PSD, mean matt, Meisner, metrojd, mholbrook98, Michael, mike scordo, Mike1996F350, Mike97f350, MikeHawk509, mikes95powerstroke, Mini-Stroke..., mj1193, MJR95PSD, mnccnm, moose99ps, Mr. Bob, mtcrsst199, Mttsnook, mustangii, MustangMatt96GT, mwalsh9152, mxmike869, mxredneck, nards_13, NastyCracker, natetheace, ncovey, nick112207, nickeagle, Nickg3130, Nodge, NOVAJOE10.5, NyCowboy87, o4ep3civ, OBSdan, Oc96stroker, OFarrell, Ol'Blue, old man dave, oldblue31, oldschool, OldschoolPSD, Oldsmoky96, Old_Machinist, onebad97, ongoingshow, ono_55, oregon96psd, Original Guster, otter, paul10, pdj4814, pennsylvaniabo, Pete467, petermoblin, Phatbulldog, phoneman, Pipeliner08, PJB, Plumberman20, Plumkrzy, poon, powerstroke cowboy, POWERSTROKE505, PowerstrokeKid, Powerstrokinit328, racehauler, Radarman, ranthom, rashole, Raul@stealth-automotive, rayd1969, ready81, Red95stroker, RedBull_04, redf3504x4, redneckabbott, REDTHUNDER, reinharm, reptillikus, Reubine, RevBubba, ridin high, Riley250, rkanai, robr1970, rockets10510, ROCKSTAR815, rodeo_man, rpm-inc, rredalty, RSieck, rudy, rusty1161, rusty9cab, rvstroker, rylerwick102, screamnstroker, sg465, Shaw, ShelbyGuy, sick97psd1, sled hauler, slick_fork, slowngreen, slutz4, sly10, SMOKE&STROKE, SNR, Speedy, SPless, sprtmetz10, spstactical, SquirrelCrusher, Stang07, Steve Jones, steve96, stoneykegonsa, STRAIGHTSTROKEN04, Stroked95, StrokeOfDarkness95, Stroker96, strokertown, StrokerTurbo7.3, strokin97psd, sunny644, SuperDuty73, svtf150, tater97, TECH51, tegeler74, TerminatorEngineering, texans, the great white, theBAT, THEDIESELMAN, thenephilm, theSLEEPER, Tim @ P.I.S., TimC63, timmay316, Tinscout, tjbeggs, Tom S, Truck4, turboaz2, TXStroker97, tyler731, TylerHerring, tysonxj, urbanwheeler, vapstroke, Wadevan, WannaRollCoal, Wazincow, winkfab, wishbone, xbrandonleighx, xrcris, YoungFordAddict66
You may not post new threads
You may not post replies
Forum Jump
