| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Oil pan gasket
Whats the best way to replace an oil pan gasket? Or is there only one way pull the motor.
| Sponsored Links | |
Advertisement |
#2
Re: Oil pan gasket
They don't come with oil pan gaskets. I do believe you can get them but i'm just running the Ford rtv that is apparently specifically formulated for the 7.3 according to the tube.
You might be able to drop the oil pan enough to scrape the old rtv out and put some new stuff in but that seems like it wouldn't be very fun. Doesn't take too long to pull it out.
__________________
'02 F-350 4x4 Black RC/LB 4" Lift with 35's. OUO Traction Blocks 20x10 Fuel Throttle's Lots of deleted parts... Custom fuel system w/ Strictly Diesel RR Dieselsite Adrenaline HPOP DI Up-Pipes DP-Tuned and more... |
#3
Re: Oil pan gasket
No way in hades to clean the old "grey death" off with out the pan coming completely off the motor. Just pull it and do it right.
__________________
97 crew cab shorty-4x4 Overfueled for your pleasure ! Didn't ancient cultures make slaves or people they felt were INFERIOR carry them everywhere???? That's the way I see it . |
#4
Re: Oil pan gasket
__________________
443.553.9234 - 410.392.3262
![]() Elkton, Maryland 2001 F250 - 11.62 @ 115.76 S475, Irate Gated T4, H11, Crower Springs, Smith Bros, My Fuel, Swamps Tuning, Gen3, 400/400's, Forged Rods. |
#5
Re: Oil pan gasket
#6
Re: Oil pan gasket
yep pull it out, also why your there might as well put new bearings in it and torque every thing down for insurance.. as well as a new rear main and any think else you would have to pull the motor to do. It only takes about a 4 or 5 hours to do and of coarse 3 or 4 to put it back in... good luck it is a pain in the butt
__________________
2000 f250 ECSB, 4x4 7.3 zf6, 150k miles Php hydra w/ php tunes and gearhead, 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, unlimited 160/30 sticks SB 1939-CB single clutch |
#7
Re: Oil pan gasket
Any suggestions of where to get the best bearings and by any chance the torques on the pan, bearings, and rear main
#8
Re: Oil pan gasket
Any motor supply,ebay ! Torque settings are easy as googling .
#9
Re: Oil pan gasket
K, thanks guys.
#10
Re: Oil pan gasket
So do they actually make a gasket or do i just use rtv. And i can't find the torque settings for the oil pan and rear main seal any where. Any seggestions. First time i've every pulled a motor and done any thing this big every bit of help and suggestions would be apprechiated.
| Thread Tools | |
| Display Modes | |
