| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Low Boost ???
Alright so I was playing around a bit with the chip and I turned it all the way off and I noticed at wide open throttle the boost built really quick to 15psi and then all of a sudden I heard it bleed off to 10psi and no matter what the throttle position I then turned the chip up to the 100hp level and did a half throttle run (cause anymore and the tranny will give me the finger) and the boost did the same thing. I am thinking a new aftermarket waste gate and boost code eliminator. what do you think
| Sponsored Links | |
Advertisement |
#2
Re: Low Boost ???
I would check for boost leaks, 15psi seems alittle low. Even for a stock tune!
__________________
99F250,12v conversion, DPS twins, DDP4s,airdog150,arp studs,benched pump,ported/o-ringed head w/+.020hg, hamilton cam,valvesprings,billet retainers/locks,maxxspool pushrods,24v tappets,dual electric fans,grid heater delete. On the quest for a 75mph roll on!!!!!!!!! BTS tranny w/6.0 cooler "What can happen will happen" |
#3
Re: Low Boost ???
i dont know what kind of turbo you have but 00strokey was gettitng 25.5 after his tune when he had a stock turbo. and i think the wastegate and boost fooler is a good idea.
__________________
2005 F-250 4x4 XLT FX4 6.0 62mm/87mm SCTX3 by Tad 155cc Elite injectors aFe Stage 2 Prodry Intake 4" turbo back with 5" stack ATS tranny Banks techni-cooler Aeromotive 200 FASS 150 Bigger lines with regulator APR head studs EGR delete 2 1/2" lift 35X12.50 BFG M/T ISSPRO gauges airlift air bags |
#4
Re: Low Boost ???
Check the boots and up pipes. I can hit 30ish in my 120 tune with a stock turbo, and yes its not good for it.
__________________
1999.5 F350 PSD CC Dually 05' Conversion Stage I's - Gearhead Tuning - BTS - PCS F550 rear suspension 1999.5 F350 PSD S/C 6spd Dually R.I.P. Will Iott - "This ain't no practice run" ![]() |
#5
Re: Low Boost ???
I would do all the above post.I can hit 30 psi easily and quickly.
__________________
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~ |
(View-All)
Members who have read this thread : 39
| 01strokin, 02BigD, 91turbogsx, a5t1, Arisley, big_stroker, biltfordtufftx, Bushwakd, chucknorris1217, damons250, dblamp, derekc, dixieland-diesels, fordguy64, Gotti2k7, hyrk, Jeron, jess, jgos929, joediesle, joeford302, jvencius, krankin, mattr66, Mbarrett, Morningstar908, ottskee, Phiber Optik, prussell89, rpm-inc, SKINNER, Smokin444, stroker99, Strokin450, TrailerHauler, userma3648, White Sled, whitepower7.3 |
| Thread Tools | |
| Display Modes | |
