OBS water pump - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 12-03-2007, 03:28 AM
farmerrich
Offline
Member's Gallery
OBS water pump
my water pump seems to be leaking from the weep hole it only does it when not running. it is a pretty steady leak. pressure tested it and the pressure held for 20 mins without dropping. Could I use some stop leak orr just replace it. also what is the eaisest process to remove it.
Old 12-03-2007, 03:48 AM
forddieseltweek's Avatar
forddieseltweek
Offline
Member's Gallery
Re: OBS water pump
Just replace it.... You will need the tools for the fan clutch that you can get from most auto part stores. It reallu is a pretty easy job..... Oh and get one from Ford, Not Autozone, Checkers,ETC.
  #3
Old 12-03-2007, 05:07 AM
TerminatorEngineering's Avatar
Offline
Sponsor
Member's Gallery
Re: OBS water pump
Will the IH 444 version fit? I understand it has a coolant filter on it.
__________________
Visit us at: www.TerminatorEngineering.com for all your Big Oil needs.
SDRCM #7
  #4
Old 12-03-2007, 10:25 AM
old man dave
Offline
Terminator Nation
Member's Gallery
Re: OBS water pump
I believe there is a writeup on TDS about doing the IH waterpump with filter install into an OBS. You have to modify the pump by chopping it a bit and find a serpentine belt but nothing major.
__________________
Just another 408hp '97 California Truck with a stock muffler
community.webshots.com/user/davepowerstroke
  #5
Old 12-03-2007, 03:25 PM
PowerstrokeKid's Avatar
PowerstrokeKid
Offline
Member's Gallery
Re: OBS water pump
You can also use a air hammer or a hammer and a punch to break the fan nut loose. I have replaced bout 5 water pumps on OBS never had a special wrench.
__________________
1996 F-250 4" Exhaust, Tymar Intake, More Mods Soon
  #6
Old 12-04-2007, 03:12 AM
Tom S's Avatar
Tom S
Offline
-Moderator-
Member's Gallery
Re: OBS water pump
There is a possibility of that jacking up the pump bearings but I think is semi remote.
Tom
__________________
96 F250 4X4 AUTO
(View-All Members who have read this thread : 47
7.3fordman, 79jasper, 96'BigBlue, Adinas95, Alvapowerchoke, BRAVO, cemeyer, Chad Edwards, clayc_989, Darkhollow, Deererainman, Deerezilla, Dieselfever, dieselman, farmerrich, fixithud, forddieseltweek, Hurley, Jeepermc, JRF, kf4zht, mandkole, materi, mgonzo, Michael, mpvoss, np205, NyCowboy87, old man dave, Old_Machinist, PowerstrokeKid, powerstrokenstang, PSDEng, Racecarhauler, Riley250, southerncockeye, STROKER #1, stroker1994.5, TECH51, TerminatorEngineering, tjsulli790, Tom S, towsurfer, u2slow
You may not post new threads
You may not post replies
Forum Jump
