reverse lights dont work - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 08-04-2009, 04:58 AM
yzdude250f's Avatar
yzdude250f
Offline
single stacked stroker
Member's Gallery
97 f350 5 speed all lights work except reverse lights is there a fuse or something i can check, the lights havent worked the whole six months i have owned the truck and im just trying to figure out why or if it could be something fairly simple.
__________________
2004 svt focus build # 1041
saving for another truck
97 f-350 SOLD
swamps 175's
2l destroyer 66 turbo
ts with custom tunes
southbend clutch
iss pro gauges
hpx cross over
Traction bars
For as fun as that truck was it was sure a piece of $h!t
Boosting 45psi on a stock charger ^
Old 08-04-2009, 05:01 AM
Aljay's Avatar
Aljay
Offline
Don't EFN worry about it
Member's Gallery
Re: reverse lights dont work
Switch on the trans maybe??
__________________
Overfueled for your pleasure !
  #3
Old 08-04-2009, 05:55 AM
Believer45's Avatar
Believer45
Offline
Old guy from the old days
Member's Gallery
I would start with the underhood fuse (15 amp) for backup lights.
If the fuse is OK go to the backup light switch, you will need to check both wires for power. When in reverse you should have 12v to both wires, when not in reverse only one.
If there is only power to one wire when the truck is in reverse replace the switch.
In the illustration from the manual the transmission is hanging from a bench vertically if I am not mistaken, switch should be above and toward the rear I THINK.
__________________
1995 F250 'Stroke 4x2 5 spd long bed, Edge Evolution CTR, homebuilt OPEN ELEMENT INTAKE, switched 10k, Putco Master Boss running boards, one off heavy duty REAR BUMPER, 36" tall contractor cap, 287,000 miles. CLICK HERE for glow plug system help.
  #4
Old 08-04-2009, 12:40 PM
JAKE
Offline
PSN nerd
Member's Gallery
i bet the cheap a$$ plus come out of the transmission, i know my switch is going bad in my truck or the plug is messed up.
just one more reason to get my auto.
__________________
97 F250SC 4X4 4 LINKED ON AIR <- FOR SALE!!!!!!
00 F350CC 4x4 I NEED A FLATBED FOR IT!!!!! LET ME KNOW IF YALL KNOW ANYBODY THAT HAS ONE
TOTAL DIESEL PERFORMANCE
STOCK HORSE OF TEXAS ASSN
SOUTHWEST REINED COWHORSE
  #5
Old 08-04-2009, 01:21 PM
madpogue
Offline
Member's Gallery
Every tranny has a reverse light switch. On the auto, it happens to be part of the range selector switch, which also contains the neutral safety start contacts, etc. Any switch can fail; I'd bet a nickel the switch for the auto is gonna cost a buck or two more than the one for the manual. Not to mention all the fun the auto has with its torque converter lock-up being tied to the less-than-bulletproof brake light circuitry. For electrical reliability, I'll take a 5-speed any day.
BTW, to the OP, the voltage tests mentioned above should be done with the switch wiring connected. Another test for the switch: disconnect it, set your meter on resistance, and put the probes on the two terminals on the switch. With the truck NOT in neutral, it should read "open" (infinite resistance). In neutral, it should read zero resistance.
  #6
Old 08-04-2009, 05:01 PM
countryboyrob
Offline
Member's Gallery
did you check to see if the bulbs are not burnt out?
__________________
02 f250
  #7
Old 08-04-2009, 05:04 PM
Aljay's Avatar
Aljay
Offline
Member's Gallery
Funny stuff right there .
  #8
Old 08-04-2009, 08:11 PM
madpogue
Offline
Member's Gallery
Laugh at the n00b all you want, but just search this and, erhm, any of the other forum sites, and you'll find story after another of someone signaling for a lane change (remember, the brake and turn signals share the same filament in the rear 1157s), or flipping on the four-ways, or their CHMSL burning out, or they hook up the trailer lights, and suddenly their E4OD torque converter unlocks.
Here's a f'rinstance: TC unlocks with signal/Flashers??? - Powerstroke Nation
'Course, I suppose it is "funny" if (like my wife and me) you'd only own/drive a ZF.
  #9
Old 08-04-2009, 10:18 PM
yzdude250f's Avatar
yzdude250f
Offline
Member's Gallery
ok, heres the verdict the fuse was bad, replaced it, reverse lights work then it pops the fuse what else is on this circut could the rv plug be wired wrong?
  #10
Old 08-04-2009, 10:27 PM
Aljay's Avatar
Aljay
Offline
Member's Gallery
I have driven a few miles in a few OBS strokes with ZFs so excuse me while I barf !
I hate them and thats all there is to it. I will keep my semi modded 4r100 and lets just say I have had 2 of these trucks and narry a problem like you describe . I do keep my vehicles up so when a bulb burns out or there is an issue it gets tended to .
(View-All Members who have read this thread : 64
2000Censtroker, 7.3fordman, 8nout, 97OBSPowerstroke, ADubDiesel, Alvapowerchoke, Believer45, blackwaterstroker, Bugman, CCF350, cjrichtig, cntryboy17, Cratos, CTFFEMT, d21067, dieselboy01, Driles85, Eng53ine, ezygo, ghostang93, JAKE, JchampIII, jeremy_cs, JohnDeere9610, jpstroke96, jschildm, JToy, kbnord, kdubinwa, KernelKob, lazerf250, madpogue, Mini-Stroke..., mlclark, mxracer511, nashvillebill, nasty96, nick_pebley, old man dave, OLD'SCOOL, pk64f100, pstroke96, pstrokin97, Red assassin, rideracelivemx7, rpm-inc, RubberDuck, shmokenpstroke, Shovel, slammed83mazda, spectreblazer, stockjeep47, STROKER #1, tmillburg, toolmangary, vrcarrano, Wood., yzdude250f, zilla68, zpilgeram
You may not post new threads
You may not post replies
Forum Jump
