Front Hub/axle help - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Suspension and Drivetrain
Thread Tools Display Modes
  #1
Old 07-11-2009, 06:14 PM
horses2
Offline
Member's Gallery
Front Hub/axle help
I am replacing my front hubs, and am not getting how the dust seal from the axle to the axle housing works. It doesnt seem to fit the axle housing and doesnt seem to fit like a typical seal on the axle itself.
The truck is a 2000 F350 4wd dually. the seal p/n is F81Z-1S175-HCA.
Did I get the wrong seal?
Thanks,
__________________
'00 F350 DRW CC 4x4 auto. Hutch mods, airdog, DP 80E flash, MRBP duals, a bunch of gauges,
to do list: diff covers, turbo, intakes, intercooler, chip
Old 07-13-2009, 05:23 PM
horses2
Offline
Member's Gallery
Re: Front Hub/axle help
any help out there??
  #3
Old 07-13-2009, 06:07 PM
whitjo's Avatar
whitjo
Offline
TennesseeHillbilly
Member's Gallery
It's not really a "seal" like you would normally think a seal should be. It's just kind of a barrier to help keep dust, mud, gunk, out of the axle tube. It presses on to the inner shaft and just kinda rides against the inner knuckle "C"
bracket where the axle goes in. The real axle grease seals are inside the differential housing. One on each side and have to be installed from inside.
__________________
Early '99 F250, 4X4, SuperCab, "PowerStroke", Auto,
PMT1 PCM, DP 80 tow
ISSPRO gauges
BDS front leveling kit
4" straight piped
Sinister pre-pump mod w/filter
Dick Cepek DC1 w/ Nitto Terra Grappler 325/65R18,
Annoy A Liberal....... Work Hard and Be Happy!
Please dont call me white or Caucasian. It offends me.
  #4
Old 07-13-2009, 06:27 PM
NorCalDiesel's Avatar
NorCalDiesel
Offline
Member's Gallery
Thanks,
IIRC If you're just replacing your hubs you should not have to replace any axle seals unless you pull the axle out of the knuckle. The only seals you should have to replace would be the yellow o-ring for the locking hubs.
To replace the axles seals you will need the axle half shafts out of the truck.
Are you also doing ball joints?
__________________
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
  #5
Old 07-13-2009, 11:50 PM
horses2
Offline
Member's Gallery
It turned into one of those "while I'm here" projects. I am replacing ball joints, axle dust seals, unit hub assembly, shocks, 4wd vac hoses, rebuilding the auto lock assembly, and putting on new rotors & pads & changing brake fluid. Painting everything that comes off so it will look good.
The old dust seal on both sides were broke into 2 pieces and there wasnt enough left to tell how they installed.
Now I just need to make/buy the knuckle seal instal driver.
Thanks for the info
(View-All Members who have read this thread : 61
02BigD, 04psdexcursion, 389SixPack, 99-350, 99strokin, All Jacked Up, Arisley, baddawg, Big Green, bigjake0524, bigjas, BigKid, BlackPearl03, Bryrylan, BuickLeSabre1960, Bushwakd, calebgriffin31, chappy, cjetcat, colekym, copperhead99, dblamp, DcMoore999, dennisr_f350, Driles85, drwoodchopper, ed3196499, fatfender, fgtex, HB-DELUX, horses2, id: 5520, ironworker25, Joedog, JonnyB, kywildcat, LongGun_LeRoy, NorCalDiesel, ohhno6.0, powwerstroke, ProF100, psdmike, richard720, rjmjr78, rpm-inc, SDER1, skav, Skpph, sling, snipeallevil, Sprint 47, steve burris, SWVa, tbrown, theham1105, tracknut, turboaz2, whitjo, wickedx, wooner
You may not post new threads
You may not post replies
Forum Jump
