Replacing front axle seal... - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Suspension and Drivetrain
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 05-30-2009, 09:41 PM
JimTJr's Avatar
JimTJr
Offline
Member's Gallery
On my 03 Super Duty. I had a hub go out, inner needle bearings. Believe it or not they never made a sound to my knowledge. But I developed a rattle, and in looking for it saw some axle grease seaping down from the passenger side tube. Grabbed the universal joint, it wiggled up and down almost an inch. Outer bearing (Load bearing) was ok. drove it home last night, took it apart today. Found the needle bearings GONE,,, and the outer axle shaft ruined where that bearing rides at. So, I got the hub warrantied from O'Rileys. But now I need the outer axle shaft, and to replace the inner seal. Do I HAVE to remove the carrier? And if I do, does it need reset? (I don't have a clue how to do that...) Or can I just remove those four bolts in the Differential and bring that assembly out?
Thanks for any info in advance! I hope Ford has that axle piece in stock Monday morning.
__________________
*48* Jim T. 2011 F-350 Lariat, CC, LB, SRW. White Platinum Metallic Tricoat. Black leather seats, I probably wont have*PMS,, with this one, at least no major attacks of it!
Old 05-30-2009, 09:50 PM
Super_Hauler's Avatar
Super_Hauler
Offline
Super Hauler!
Member's Gallery
Re: Replacing front axle seal...
remove the 4 bolts on the back side, then pull the shaft with everything on it right out. Then you can put the new seal on there. The new seal is a PITA if you dont have the tool. I just used a peice of pipe and a hammer and a vise to keep the shaft still while i tapped the seal in. Its pretty easy to do once you get it started.
__________________
MINE:08 F-250 CCSB king ranch erics tunes livewire
99: sclb 6 speed, 4" lift,4" exhaust, EB
99 F-450: ccfb Boss v plow. 6 speed 5" ex,EB
HERS:2001 F-350 ccsb notta stock!
  #3
Old 05-30-2009, 11:59 PM
JimTJr's Avatar
JimTJr
Offline
Member's Gallery
NO, my diff is leaking grease. I need to replace the seal near the carrier. I am leaking out the end by the universal joint....
I also need to replace that large seal on the small piece of the axle. But the one that is leaking is way up by the gears.
  #4
Old 05-31-2009, 01:47 AM
slowleak
Offline
Member's Gallery
Jim take some pics of what your talking about. when you refer to the carrier, i would assume drive shaft...but your talking axles.
__________________
PMRCM#1
  #5
Old 05-31-2009, 01:51 AM
Super_Hauler
Offline
Super Hauler!
Member's Gallery
Ya driveline carrier bearing and axels are two totally different thing. I dont know of any diffs that have grease in them, but there is diff fluid in there if thats what your talking about. But like he said gets some pics and we will definitly be able to help you out.
Or are talking about leaking fluid from your yolk on the front side of the differential?
  #6
Old 05-31-2009, 02:55 AM
JimTJr's Avatar
JimTJr
Offline
Member's Gallery
ok, sorry, not "Grease" It's Gear lube, It is seeping out the end of the housing tube at the universal joint. So it's the inner (and only) seal that is leaking. (For that side anyway) I have the axle out and on the floor, I need to know if the carrier for the ring and pinion needs to come out to replace the seal in the differential. There certainly is not much room in there, that's for sure. If it needs to come out, I'll replace both sides of course.
  #7
Old 05-31-2009, 03:15 AM
rpm-inc
Offline
Member's Gallery
Yes it needs to come out. Remove the bearing caps and keep track of orientation, which side, etc.
There is a special tool to install the seals. I tapped mine in with a socket. Hope it's ok, haven't driven it yet.
check out Home for parts
__________________
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
  #8
Old 05-31-2009, 03:30 AM
JimTJr's Avatar
JimTJr
Offline
Member's Gallery
So other than orientation, there are no worries about the gear setup? (Nothing will change in lash, ect...) I assume there is a torque value for those bearing caps? Anyone know possibly what it is? (I can find it from the Parts guy when I get the seals and axle I imagine)
  #9
Old 05-31-2009, 02:05 PM
DIRTBIKEZ
Offline
Member's Gallery
85 ft-lbs for caps, 35 ft-lbs for diff cover. Do not mix up the shims. Easy Job really. :)
__________________
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
  #10
Old 06-01-2009, 12:55 AM
JimTJr's Avatar
JimTJr
Offline
Member's Gallery
Thanks, I didn't have ANY shims on either bearings race.... maybe the shims are between the bearings and the carrier? Looks like there may be some there.
IN any event, my NEW problem is getting the seals out!
You can see, there were no shims,,, The race laid right against the housing tube.
I got some of it out while destroying it,,, but the rubber is still in the housing?
Any tips on getting it out, and the other side too now? May as well replace both sides of course, since I had to tear it all down.
He!! too bad I don't need ball joints, I am all the way to them now,,that's all that would be left.
Tempting to replace them now, but they were done when I bought the truck,, so they "Only" have about 80k miles on them,, but they are MOOG and greasable, they should last much longer.
If I have more hub problems, I am really tempted to go with the Dynatrac system,, it looks pretty sweet.
(View-All Members who have read this thread : 140
01powerstrokin, 02powerstroke, 03Excursion, 2000XLifted, 2006Duty, 2ridgebacks, 351c, 389SixPack, 444-4D, 6.0_psd, ADJDWG, armalite, Ashby, Austinfqt, beav, Big Red S/C, bigo, BKB, BlackPearl03, blaze42069, bmw10494, Bowpassion, budman, BUFF, Bushwakd, C5dad, CALADASH, Calico5, ccrowd, chappy, coope3, Dantheman, dauntejoel, dave jr, dblamp, dieselford000, Dieselgeek, DIRTBIKEZ, dixieland-diesels, dogmaticus, doubledoor, Drew2010, ernieb143, F-350, f350red, fishyPSD, fordboy424, FordSuperDuty05, fowjacob, Gotti2k7, gtobob, gunfixer, haymaker, Heavy_Duty, Hhgro, huck2080, hutchnoclutch, jcmagone, jdexcursion, jensenciv10, jeromejcp, jessduen1, JettBlack, JimTJr, Jngreen, JNORTON, Joedog, Jordy53, justind, kade625, kx450f, Layson, lep, lossscause, Macguyver, MagKarl, mattgw86, matthewd11, Metallitera, metso434, mgilboy, millertmenow, mjcolemn, moco, Moejoenorge, mrgto, mrplowjr_ez_v, mtmod50, mx185sw, nasty96, NELLY83, northern64, ocracokeisland, ohiopsdfordman, oil burner, OLD'SCOOL, Oscar1017, pa-powerstroke, Peroni, phercinger, Pipewhiner, PSD2006, PSDfan99, PSDOWNER, PWRstroke_smoke, Ramblin'_Man, Rdh605, Redman84, reilly8282, rholman, rockNnachos, Rogue1970, rpenner54, rpm-inc, Ryan444, Santa Gertrudis, sgleshot, sick97psd1, silverslug, slowleak, smokinstroker92, smoroz, Stringer Driver, Super_Hauler, suprhlr, tank, tank23, tch.280, theham1105, thunter95, Tj Krawler, tjohnny62, ToMorrow44, Tomtnwlkrs, travisH3, TWIM, Ursula, wargle, whodathought
You may not post new threads
You may not post replies
Forum Jump
