fuel pressure problem 1999 e350 HELP!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 05-22-2009, 05:12 PM
1999F350's Avatar
1999F350
Offline
Member's Gallery
Send a message via Yahoo to 1999F350
early e350 when cold it runs great, after about 10 min of driving fuel pressure starts to drop slowly from 60psi to 0psi then dies, fuel pump brand new and pump still on with 0psi. wait another 10 min runs good then does same thing over again. no CEL. any body have any thoughts? thanks jay
__________________
1999.5 F350 XLT EXT CAB AUTO 4X4,K&N W/6037, DPF5,HIGH IDLE,80T,80E,120R,140BOOSTFOOLER,PHANTOM2 GAUGES BOOST,TRANS, EGT,CUSTOM 4R100 W/ JWVB,BILLET HARD PARTS,427LINE,RACERX PARTS,BD PAN,6.0 COOLER,DETROIT TRU TRAC,3.73,VAN TURBO W/ATS&HIFLO OUTLET,4" STRAIT PIPE,AFE INTAKE MAN,140V IDM,325/60/20 NITTOS,2.5"LEVELKIT,OPTIMA'S,PIONEER DVD/NAV
Old 05-22-2009, 09:15 PM
dmd's Avatar
dmd
Offline
Member
Member's Gallery
Re: fuel pressure problem 1999 e350 HELP!!
Hmmm... Did you check the flow, not just the pressure?
Try opening the drain on the fuel bowel and then turning on the key. The
fuel should come out of the drain with some force... If it just dribbles out
then the fuel pickup or the in-tank filer could be plugged..
__________________
'00 F350 Supercrewzer Lariet, PSD, Auto, 3.73, CC, 4x4, SWB, SRW, F250, 6 position chip, 6637, 4-inch turbo back exhaust, 38r w/ high flow turbine outlet, Adrenaline HPOP, BTS Trans, Swamps IDM, AIH delete, in-tank/pre-pump mod, heater/AC mod, Harvest Gold and Black / Packages: Trailer Tow, Camper, Off-Road. Overhead monitor DVD/TV/VCR
  #3
Old 05-22-2009, 10:54 PM
smorris's Avatar
smorris
Offline
you want some of this?
Member's Gallery
__________________
2000 f-350 cc lb dually 4x4, BTS transmission
7.85@ 90 mph on MT mud tires and 8,000 #
coming soon--97 cc lb 4x4
http://community.webshots.com/user/smorris1972
Incompatible Browser | Facebook
  #4
Old 05-23-2009, 06:43 PM
1999F350's Avatar
1999F350
Offline
Member's Gallery
thanks ill try that.
  #5
Old 06-05-2009, 02:53 PM
1999F350's Avatar
1999F350
Offline
Member's Gallery
got some new info from customer, he put unleaded gas in the tank and ran vehicle for a short distance. truck shut down, had it towed drained tank and changed filter him self. now truck runs good for 5-7 min then looses power and stalls. im running vehicle off a fabed aux tank now, guna see what happens, if ok problem in tank? my other question is would the gas have done any damage to any other parts of the fuel system? thanks jay
  #6
Old 06-05-2009, 05:20 PM
dblamp's Avatar
dblamp
Offline
<-- GO BRONCOS
Member's Gallery
If he ran it too long with gas, I believe that will do considerable damage to the injectors. Maybe Golfer (Swamps) will see this, and tell you for sure.
__________________
Anthony
2002 F-350 SRW 4x4 Lariat Crew Cab, Auto, MBRP 4" T409 Turbo back, AFE Stage 2, Isspro gauges (Pyro, Boost, Trans), BTS VB, DP F-5 (No start, Modified Stock, 60T, 80E, 120race)
Democrats are tyrants.
Republicans are cowards.
Jesus Christ is our only hope!
(View-All Members who have read this thread : 36
01stroke, 1999F350, 99powerstroke350, aklim, Barnbuilder, BOTLDPONY, Calico5, Channing, dblamp, DieselBrad, dmd, Dpage, FleetMan, fordguy, hawkeye, highfive, hyrk, jdexcursion, JerseyJim, JHill, jtaylor115, JuststrokeIT, Marty Mechanic, mauidieseldave, Metallitera, NorCalDiesel, rconcrete, retired jeeper, Rogue1970, rpm-inc, scobee, smorris, southmike, Tampa450
You may not post new threads
You may not post replies
Forum Jump
