| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
EBPV delete?
What does this do? I know the EBPV makes my truck sound like a B52 after a few minutes from startup if I let it idle but what is it's main purpose and what's to gain from deleting it? I hear of people getting shorting caps to kill codes and leave the sensor sitting in the engine valley.
Can someone enlighten me on the purpose of this or lead me to an informative page that will? Thanks Dave |
| Sponsored Links | |
Advertisement |
#2
Re: EBPV delete?
the EBPV heats the motor up by closing the butterfly valve in the turbo, By removing it you will have more flow out of the exhaust. You could just unplug the harness that goes into the pedistal. Then it will never come on and you wont have to worry about it and hear it anymore. I use mine it as a exhaust brake with a switch, it closes the valve causing the rpms to drop and loose speed coming down hills with trailers.
__________________
MINE:08 F-250 CCSB king ranch erics tunes livewire 99: sclb 6 speed, 4" lift,4" exhaust, EB 99 F-450: ccfb Boss v plow. 6 speed 5" ex,EB 1985 Peterbilt 359 Big cam III Tuned up a little HERS:2001 F-350 ccsb notta stock! [/quote] |
#3
Re: EBPV delete?
Is it basically a mix between an EGR and choke to help the motor warm up?
I've seen housings and plug adapters for this and it seems that if the aftermarket has parts for it, it must yield some gains worth mentioning but at what cost? Thanks for the quick reply. Dave |
#4
Re: EBPV delete?
some people just unplug it from the actuator and wire it open, but that just keeps it from closing, you dont get the extra room in your exhaust.
__________________
early 99 cc 4X4.. 4" exhaust, cushtom tunes, DI hybrids, DI tranny, GQSSB turbo and 3" plenums from WOP, 13.94 @ 96.9mph.. on stock turbo |
#5
Re: EBPV delete?
Here some stuff Maintain poasted...the 6th video down tells you how to gut and plug the EBPV if you want to go that route.
http://powerstrokenation.com/forums/...ad.php?t=27551
__________________
2000 F-250, RCLB, Auto!!
#6
Re: EBPV delete?
Dave, you can just unplug yours and not worry with the gutting.
Justin
__________________
Justin #62 '97 F-250 - 255k 463 hp - 7-9-09 BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, live tuned by Jonathan @ BDP. Heartbreaker 2 pulling sled |
#7
Re: EBPV delete?
I'll have to look into it. I am looking at swapping in a new turbo and saw this as an option on some of the housings.
Does it cause issues disconnected in the cold mornings say, like, in North Dakota? It's freaking cold up there and I'll be there in a year. Thanks guys Dave |
#8
Re: EBPV delete?
It doesn't make a huge difference in warm up, but it helps some. What I did on mine was cut the wire and put it on a switch. If I want it on, I turned the switch on. As long as the switch is of, it can't come on. That way I can also use it as an exhaust brake.
Justin |
#9
Re: EBPV delete?
__________________
2001 F250 Ext Cab LB 7.3 Super Duty 4X4 auto,Jody's Tunes, Single Shots, open air intake, AIH delete, AutoMeter Ultra-lite2 Gauges, triple pod, Mile Marker hubs,259,999 mi. then odometer broke Oct. 09. MBRP 4" turbo back. Banks power elbow. Non ebpv ped. plus wicked wheel. Don't spread my wealth...spread my work ethic
#10
Re: EBPV delete?
That sounds cool too. Poor mans Jake brake.....sort of. If North Dakota had hills, I'd consider it. It's too flat there and that's where I'll be.
Thanks for the inputs guys. I think I'll just keep it the way it is and go with a replacement turbo. I'm not looking to spend everything I have to get every hp out of my DD here. I have a racecar for that. Great educational value here though. Dave |
| Thread Tools | |
| Display Modes | |
