2003 F250 6.0 Oil Leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 04-27-2009, 05:13 PM
lbarattini
Offline
Member's Gallery
I can chase an oil leak to somewhere at the rear top of the engine. Turbo and accessories blocking my view even with a mirror. It comes from under a heat shield above the top of the bell housing when I view from underneath on the driver's side. Are there any videos/manuals that would show removal and replacement of the Turbo Charger to get a view of the area in question. I am a carpenter by trade not a mechanic and could use some help.
Thanks,
Lou
Old 04-28-2009, 02:22 AM
POWERSTROKER's Avatar
POWERSTROKER
Offline
Member's Gallery
Re: 2003 F250 6.0 Oil Leak
Is it wet toward the front of the engine?
I see alot of oil cooler gasket leaks, they start at the front and run toward the rear of the engine.
could also be a HPOP cover gasket, over time they tend to flatten out and not seal as well
__________________
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by Gearhead Automotive Performance
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
http://www.dieselpowerproducts.com/
  #3
Old 04-29-2009, 07:50 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
I am betting either turo pedistal o-rings or HPOP line o-rings.
Look in this thread, there is a turbo removal video in there.
http://powerstrokenation.com/forums/...ad.php?t=27551
Never mind, just now noticed it was a 6.0
__________________
Last edited by Arisley; 04-29-2009 at 07:51 PM. Reason: Didn't read the OP good enough.
  #4
Old 04-30-2009, 06:29 PM
lbarattini
Offline
Member's Gallery
There is some oil residue in the valley between the heads. This was caused by the oil filter cannister o-ring leak which I replaced. The main leak at the top rear of the engine still persists and is much heavier than what was coming from the o-ring leak at the filter.
Thanks,
Lou
  #5
Old 05-01-2009, 03:44 PM
RescueF250's Avatar
RescueF250
Offline
The Unseen Mod
Member's Gallery
Send a message via AIM to RescueF250
ICP sensor ???
__________________
Thanks to Doug at GoGo Diesel, Matt at Gearhead, Ryan at Full Force, Vivian at Quick Tricks, Greg at Diesel Power Products, Adam at First Coast.
(View-All Members who have read this thread : 54
00strokey7.3, 03 powerstroke staked, 04PS, 393LX, 99strokin, afFORDable, Arisley, B18B1LS1, bigboy73, BIGDUX, BigTex2973, bswanzek, c.salt, carsmars, Chad Edwards, DMDP, Dustin F2504x4, f350mike, fireslayer, Force2354, FT30FC, george german, gfaststroker, JD F350, jeremyshanemoore, julianb281, KyleK, lbarattini, maps, Marksperformance, matthewd11, Millerfarms, Mr. Bob, Mvastine, OhNoSixOh, Ol'Red95, RAUD, RescueF250, rsmith7373, sanocafire20, sga6.0l, Shef, shreyshah1120, smokinndstrokin, SoCalPowerStroke, squeak12, Teva, TexasStroke01, Tom S, tominyuma, userma3648, Weazel
You may not post new threads
You may not post replies
Forum Jump
