03 6.0 hard start rough idle low power no codes - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 12-28-2013, 04:06 AM
Ursula's Avatar
Ursula
Offline
Big_Bad_Ursula
Member's Gallery
Trying to help my buddy get his truck running right, heres what we got
2003 F350 6.0. Truck has 170xxx miles, first off is it takes a bit of persuasion to get it to start and stay running after cranking for a good few seconds. Trys, Trys, Trys then finally catches like a hard Loping CAM for a few seconds, then tones down a little and begins to slowly warm up.
Park or neutral, truck runs rough but gradually pressing pedal down will smooth it out, seems to build boost, no hissing. Truck will barely move until its showing temps are almost at full operating.
Still after warming up and running rough, putting it into gear, low power until roughly 1500 rpms, and unless it downshifts on its own or stomping on it a few times, it will not pass this rpm range, if it does down shift it jumps to roughly 2300 rpms.
going to try and start off with checking fuel filters.
Help.
__________________
1999 F350 SRW CCLB 7.3
5" MBRP Turbo Back, S&B Stage 2 Intake, Boost Fooler, FPR MOD, TS 6 POS chip with Swamps Tunes.
Tri-Pillar w/GLO SHIFT Pyro/Trans/Boost
4:89 Moative Gear sets
8" RC Lift, 16.5x12 MT Classic II rims, 39.5x13.5 Super Swamper IROK's.
Old 12-28-2013, 04:18 AM
mysixoissick's Avatar
mysixoissick
Offline
Sick Sixo
Member's Gallery
Re: 03 6.0 hard start rough idle low power no codes
Check the ficm voltage, good videos about that on youtube
  #3
Old 12-28-2013, 10:47 PM
toolmangary's Avatar
toolmangary
Online
Fixing Broken Stuff
Member's Gallery
If the FICM is good then you most likely have injector issues, stiction.
__________________
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
  #4
Old 12-29-2013, 05:49 PM
Offline
Member's Gallery
I had/have the exact same problem with my very early 2004. +1, start by checking the FICM voltage. Mine was low, so I had that rebuilt. If that doesn't remedy problems, it could be a stiction problem, but I think it's very likely to be a high pressure oil problem (IPR, HPOP, etc.).
I'm in the process of installing a new HPOP and oil cooler, and fixing a number of problems at the same time.
Good luck!
__________________
  #5
Old 12-29-2013, 11:40 PM
toolmangary
Online
Fixing Broken Stuff
Member's Gallery
If it still runs the HPOP is probably still good, every truck I have ever seen that needed a HPOP had less than about 70 psi of ICP, which I figured was base oil pressure.
  #6
Old 12-30-2013, 02:19 AM
Offline
Member's Gallery
Apparently, at least from what I've read, early 6.0 HPOPs will excessively leak at the seal causing pressure and hard start issues. Mine really didn't have any problem starting hot, but after sitting for eight hours to a day the sump would drain causing one heck of a hard time getting it started.
  #7
Old 12-30-2013, 11:45 AM
toolmangary
Online
Fixing Broken Stuff
Member's Gallery
Did you change the HPOP? and did that fix it?
^^ That statement sounds like injectors.
  #8
Old 12-30-2013, 04:19 PM
Offline
Member's Gallery
It's in progress right now, so no, I don't know for sure if it fixed the problem. In addition to the no power until operating temperature thing, I was also having very hard cold starts, an increasing loss of power at operating temperature, and a frequent P2290 code. I do know my sump was draining when parked for some time, and I believe it was draining through the pump seal.
That said, my FICM did need service (37 VDC when running). Getting that fixed helped a lot with the lack of power when cold.
(View-All Members who have read this thread : 34
14fan77, 1997P-stroke, 1hydroman, 1ststroker, afFORDable, ajennings, bigjon18, charlez, chevyeater351, Dan V, FlossyB, highpockets, hornythrony, jjester1040, jmontes, KSStroker, littlelessmore, matthewd11, Michipicoten_SuperDuty, nitrouskid2601, pa32mays, partsandservice, RNally, scottrace1, slutnik243, spence_08, TCNashville, Tj561CO, tking7, toolmangary, txdieselmech84, Ursula, Wyo
You may not post new threads
You may not post replies
Forum Jump
