Cold Weather? Hard Starts? - GLOW PLUG SYSTEM TEST - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Power Stroke Nation! > The Library > [7.3L - Technical Info]
Thread Tools Display Modes
  #1
Old 12-17-2007, 03:08 PM
gregrob's Avatar
gregrob
Offline
Member's Gallery
Well, cold weather is certainly upon us for most of the states and I thought it would be useful to have this around for those who have noticed hard starting in the mornings due to the cold temps.
The main thing that is going to make or break a cold start for your PSD is the glow plug system. This is barring any gelled fuel, etc. The glow plugs, and glow plug relay system can be tested, and are fairly inexpensive / straight forward to replace any components needed.
The first and easiest test is to check the glow plug relay.
1) Let the truck sit overnight in fairly cold temps ( < 45º ) this will require the glow plugs to activate for a good amount of time for the truck to start properly.
2) The test part can be done several ways, first of all if you have a voltmeter, dial it up to the correct setting for 12V systems, ground it to a good ground, and put the + lead on the right/back side of the glow plug relay. With the key off, that terminal should read zero, while the other one (which connects to the battery) should read +- 12V at all times. You want to measure the one with zero voltage.
When the key is turned on, the one that had zero should go up to 12V and stay there for 30sec - 2min. This is feeding the glow plugs 12V to heat them up.
3) Have someone turn the key on for you, or turn it on and get back around to your tester quickly, and see if you have 12V across the relay. If you do, see how long the relay stays activated, if it goes off very quickly it's not allowing the gp's enough time to heat up and the truck is going to start rough. If the relay fails this test, replace it.
2-3a.) Some alternate methods to above, instead of using a voltmeter, jumper across the relay either with a screwdriver (which will cause sparks until you make a good contact) or with a set of jumper cables from the hot + terminal on one of your batteries, to the gp side of the relay. Make the connection for about 45 seconds, then immediately try to start the truck. If it fires up nicely, whereas it was struggling before, the relay is bad.
4) If the relay passes the test, and is good. Or if you replace the relay and still experience hard starts, you will need to move on to testing the glow plugs themselves. This can be done quite non-invasive, only requiring you to pull the valve covers if you find a bad glow plug, to replace it / them.
5) There are also a couple ways to test the glow plugs, you will need either a test light, or a good voltmeter that will read in ohms.
5a) Voltmeter method - Remove the large rectangular plug leading to the valve covers on either side of the engine. This plug powers your glow plugs and injectors. The 2 outside pins are your glow plugs, the 4 inner ones are for the injectors. () () () () () () () () Blue is the Glow Plugs Red is the injectors. Be very careful not to insert your test lead into one of the injector pins. The IDM feeds the injectors 110V and could cause a lot of sparks if it happens to try and actuate the injectors while you're testing, and could worse destroy the IDM, so steer clear of those and make sure you test only the 2 outer pins on each side of the plug.
Connect the ground lead of your voltmeter to a good ground, and insert the positive + test lead into the first glow plug pin.
A good glow plug will read btwn 0.8 - 1.2 ohms a weak glow plug will have much less resistance, and a completely dead one will have unlimited resistance through it because the electrode is internally burned out. Make note of the plugs that are out of range based on the cylinder number, and replace them. The cylinders are numbered 1-3-5-7 on the pass side, front to back, and 2-4-6-8 on the driver's side, front to back.
5b) The test light method - See 5a and substitute voltmeter for test light, if you don't have a voltmeter. Connect the negative end of the test light to a good ground, and insert the test light into the outer 2 terminals on the plug. If the test light illuminates the plug is still working. If the test light does not illuminate, the plug is bad. Make note of the bad ones and replace.
The disadvantage to this method is that it won't tell you if a glow plug is weak, only if it is completely burned up.
*note this does not apply to california emissions equipped vehicles (cali trucks) or the Excursion with 7.3L PSD engine (all years) as they use a controller to actuate the glow plugs instead of a relay. A bad glow plug on these trucks will throw an engine code.
Replacement parts - For the glow plug relay your choices are to buy a stock replacement ($$$), get a GPR-109 from NAPA for less than 30 bucks. This one will work, but some have had issues on them not lasting as long as the stock unit. There is a good option from Stancor, the part number for which I will let someone post. Or you can always find one that's designed similarly and rated for the voltage/amps that the stocker is or better, and use it.
Here is a link for the Stancor unit: http://www.alliedelec.com/Search/Pro...E5DA8041ECE17F
For glow plugs, you want to use only Motorcraft or Bosch plugs. This is very important as the Autolite / Champion cheap brands have a bad reputation for swelling up, burning out prematurely, and breaking off in the head. The motorcraft part number is ZD-11.
The relay is simple to change, disconnect the 2 large terminals, and the smaller ones, unbolt the relay, and install the new one.
The glow plugs are located under the valve covers. Remove the vc's and you will see 4 white wires, with black plug ends connected down beside the injector. Remove the plugs from the gp's, and remove the gp's with a 10mm deep socket.
Here is a pic of the glow plug relay. It is the rear most one, the on under the hose is for 99.5-03 trucks and is the AIH relay. The terminal on the left in the pic is the constant 12V to the battery, the other one on the right in the pic is the one you want to test.
Here is a pic of a good multirange voltmeter.
Old 12-17-2007, 03:44 PM
gregrob's Avatar
gregrob
Offline
Member's Gallery
Re: Hard starting? Cold weather? Look here
If you guys see any corrections that need to be made let me know.
  #3
Old 12-17-2007, 09:46 PM
NWSUPRD's Avatar
NWSUPRD
Offline
The Mule
Member's Gallery
NICE! Gregrob. The only thing I did different was instead of using a voltmeter to check the GP side of the relay when the key is on, I just used a voltage tester, the kind that has a light in it. Keep it in my truck all the time. It did not matter how much voltage I was getting as there was none.
__________________
1999.5 F250 PSD 4X4
1/8th mile 8.436 @80.21 mph, 1.848 60ft
www.mcspadden.cc/themule.html
[SIGPIC][/SIGPIC]
  #4
Old 12-18-2007, 12:02 AM
Fever's Avatar
Fever
Offline
Lurker...
Member's Gallery
Only problem with that is sometimes you'll get enough voltage to light up your test light, but not be enough voltage to turn on the glow plugs...(or whatever electrical device you are diagnosing)
with a meter you can verify battery voltage on both large lugs...
__________________
2003 F-350 Super Duty
  #5
Old 12-18-2007, 04:33 AM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
I like something that tells me how much also. Not just yes or no. You can get a decent meter from Home Depot in the electrical section for less than 30 bucks. A really good one for around a hundred.
__________________
  #6
Old 12-18-2007, 01:26 PM
NWSUPRD's Avatar
NWSUPRD
Offline
The Mule
Member's Gallery
Great point on the meter guys. Perhaps my meter should go in the travel tool bag.
  #7
Old 12-19-2007, 11:03 PM
gregrob's Avatar
gregrob
Offline
Member's Gallery
Not a bad idea. My relay is still working but I'm thinking of going to the Stancor
  #8
Old 12-19-2007, 11:25 PM
Haul_n_horses2's Avatar
Haul_n_horses2
Offline
Member's Gallery
You won't regret it.
__________________
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
  #9
Old 12-19-2007, 11:40 PM
vapstroke's Avatar
vapstroke
Offline
Member
Member's Gallery
Re: Cold Weather? Hard Starts? - GLOW PLUG SYSTEM TEST
whats the stancor #
__________________
Swamps, ITP diesel, DP tuner, BTS, Stecher Performance Diesel, DieselSite
  #10
Old 12-20-2007, 12:04 AM
gregrob's Avatar
gregrob
Offline
Member's Gallery
Stancor P/N: 586-902
(View-All Members who have read this thread : 1552
#1morris, '01F250HarvestGold, '94IDITurbo7.3, '99 stroker, 00 f350 powerstroke, 00 ford f250, 00f350Dually, 00PSD, 00psdlariatle, 00ryanstroker, 01lariat, 01larietcrewcab, 01OL'RED, 01platinum, 01powerstrokin, 01pwrchkn, 01str88, 01stroke, 01strokin, 02BigD, 02ccpsd, 02EXCURSION, 02f300, 02F350, 02powerstroke, 02POWERSTROKE7.3, 02psd, 02psdcrew, 02ST, 02stroker32, 02_powerchoke_F350, 03e450, 03geetee, 03superduty, 04 stroker, 04fx4drw, 04La4iat, 04MT, 04psd6.0, 04stroker, 05lariat, 06 f250 man, 06 stroker, 08psdbeast, 08_stroker, 1978psd, 1990 Scorpion, 1993 ford turbo diesel, 1997 7.3 ak-47, 1997stroker, 1999F350Lariat, 1BadF350, 1badz, 1Macaw, 1tontoy, 1treasurehunter, 2000dually, 2000SD, 2000XLifted, 2001-7.3Liter, 2002FordPwr, 2006nytro, 220Swift, 250truckguy, 273335, 2CAN, 2k550, 2MCHPWR, 2stick, 354racing, 35thls1ss19, 389SixPack, 4.0l sahara, 402notch, 450pipewelder, 4x4, 4x4door, 6.9turbocharged, 67cummins, 6869704x4, 6Spd_6Liter, 7.3-StRoKeR, 7.3FisherFord, 7.3klaus7.3, 7.3noob, 7.3pokesfan, 7.3stroker02, 73stroke99, 73z28cam, 79jasper, 79shovel, 7thMcD, 82crawler, 84crawling, 88 gtu, 88automan, 89turbo444, 89xj, 8inchstroker, 907superduty, 93whitese-r, 94.5pstroke, 94.5stroker, 95F250, 95ford7.3, 95rdstroke, 95smokinstroke, 97 white mule, 97-BIG RED, 9755, 97diesel, 97obs, 97ps5spd, 97_f250_7.3L, 99.5crewstroke, 99powerstroke34, 99sdPSD, 99SilverLegacy, 99smokin&strokin, 99strokin, 99STROKINSMOKIN, 99turbo, 99WHITESTROKE, 99whitestroker, 99_7.3Stroker, a141sparky, AaronL, abbottfarms, ABoyAndHisToys, acebeto, ACFarmer, Action, adcausey, ADubDiesel, AJDmotorsport, ajfetterman, Ak7.3, akkeith4570, Alancour, albinism727, All Jacked Up, alleng, alosha09, amd_h4x0r, Aminator, Amnent, amthatiam, Andrew240b, apollyon9515, area42g, Arisley, armyman24, asalm36, asantana5311, ascrap2003, ashfire115, AT&F1, ATRdriver1, atvrider01, Atx-PSD, aurora 7.3, aussie powerstroke, AUSSIE TUFFTRUCK, Austinfqt, aviatorkev, azoldwestforge, AzPsd55, b93pgt, babydoll, badblack01gt, baddad, badford350, Ballistic, Bama, Bama 03 7.3, bamaborn, Bar-m.cattle, Barnbuilder, bayleedorset, bazdog1, bbarkley, BCPowerstroke, BDS, beerboy, Beerplease, Believer45, ben02stroke, bfoster, bfr44, bftank, bhart, BIG, Big B, Big Bill in Tn, big trucker, BIG01RIG, bigblocktisdale, bigblue02, BigBlueBeast, BigBlueDually, BigE89, biggreen96, Biggsw784, bigjas, Bigjay400, bigjoe, BIGLARRYS03, bigmike73, bigred1997, bigred2001, BigRed97, bigrigkyle, bigrngyj, Bigsexy, BIGSIX, bigstrap3, BigTuck73, big_country1967, Bill R, bill4d, birddog55, birdmann79, birdog, Biscayne, bknight187, black cloud 02, black7.3l, black73, black974door, BlackCloudMafia, Blackford, BlackGold, BlackPearl03, blacksmoke.r.us, blacksmoke01, blacksmoke2321, blackstar, blk7.3ks, BlkNTan, blm510, Blowby, BlueAngel, Bluecat, bluedge8, BMac, bnbdiesel, Bob K, Bobs 7.3, bobtsgt, Boogie's AutoRama, Boost96, boostaddict, BootZ0360, Bormuth@66, borostroker, Bowen Morris, bpa658, bproffitt1014, Brad Johnson, brad.stoner, brad25, Bradbilt, BradleyStuart, BrahmerTamer, brandon.hovland, bravo-man, brent8893, Brian Cox, brianmorgan17, brob, Brock97, BrodsterM3, broncobill67, Broncoboss, brooksbronco17, Brotherbob, brower3, browncraig11, browning7.3, bruin4, bruster, brute_mt, bryan213, bryced1, budman, Buford-61, bugeye1257, bull7467, Bulldog, bulldog01, bullittbil, BumpRacerX, Bunk, Burg460, burghrm&m, burn1, burt williams, Bushwakd, Butchyatburg, ByrdDog, C5dad, cadd, Camarikiller6, camaroicoc, camocrewcab, CamoGirl, campygsxr, CamTom12, CanadianPS, cantrellc123, car94, cardiac, carlrossander, caseyk, casper7.3, CatmanC15, CAV64, ccmac, ccrowd, CCStroker, celltech, Cement, cemeyer, chach3835, Chad Edwards, chadh, chainsaw, chalkline, Chall08, chappy, chastalh, cherokeewheeler, chesterfire20, CHevDog1, childinplay420, Chipbreaker, choco1911a1, Cholt86, chopper, chris1978, chrisw, chuckbic, Chuggins10, chunkdunker, cjsobas, Clacker, Clarence_Carter, clawson, claybuster, Clayton53, CLIFORD3, Clutch414, clydesdale, CMPNS8N, cntryboy17, co04cobra, colekym, ColeTrain45, Coltaine, comparuly, CompOrangeCobra, contractorjoe, cookieman_30, coondad, corbin9191, cory, cory99, coryneedham, cota, Country, countylaw, Cowboyup, coxral, crash85, crawlerxj, Crazzy8, crbav8r, crewcabxlt, crhino, Critical, crobbins20, Crosswired, crosswired2, crowz, csetheridge, csilvers1984, CTFFEMT, CTShoaf, cturnmire, cummins killer, cumminstrokemydmax, CUMMINS_KILLA99, curb guy, Custerpsd, custom8726, cuz_im_CR, Cwillhite04, cwrkid2000, czangli7, D2HP, DABEARS, DADSHOBBY, dajain, Dakota F350, danneffgr, DanNJ, Darkhollow, Darkness, darkside708, Darrell, darrell401, daryls377, dave in tn, Dave R, dave186, Dave70454, dave96psd, David N, davydog, Daytonabill, dbart, dbuck, dcellis, DcMoore999, DeafJeff, Deeken, Deererainman, Deezle, deiter5262, delgao, dellwas, Delox, Delta161, DENNYTUCKER, Deronn, Dertho, Devlin, dexleo2, dfaust, dffdixie, dgaugler33, DHall, DHFF, dhhk03, Diesel Avenger, DIESEL DAN, Diesel Geek, diesel7.3, Diesel72404, Diesel73L, diesel78, dieselmac99, dieselman64, dieselman81, dieselmike1988, DieselnutN14, Dieselpoweredcowboy, dieselpwrdredneck, DieselRangerKid, dieselsmoke08, Dieselsmoke21, Dieselsvt, Dieseltron, diesel_84, DifferentStrokes, dirt devil, dirtbikedingo, dirtboy25, Disappointedpowerstroke, ditch_dawg, Divejunkee, djl95, DJM, dlnw98, DMDP, dmgilby, dmoffat, dmschmidt1200, dmstrucks02, DNSPSD, Dobbs15, DocBar, docweld, Donnief, Doolie, doubledoor, DoubleL, douglasharwood, DPS0925, dpski, DragulaSD, dreader, Drew2010, DrewGerhan, driftsmcgee, dsl_pwrd_ford, Dsycutter, dtott, dtrunyon, Duane, Duanesz, dubswyoming, duece, duelin3501, duncan351, dupee426, Duracrap, Dustin F2504x4, dutchwillis, duxpsd, dwstearman, Dynx, e.gresham, E99Superduty, EastTxStroker, eb76adam, EBBCLA, edge186, electricgooseharley, Elgin MGP, elhombre, elk junkie, elkhunter92, elkrunner, ellisfl09, ElMachine, endonoz, enemyofgore, erniesshop, erskine_e, euroford, everclear4520, EverettWV, ewils35, excavator, eyoung, F-127, f-150_xl, F250 Fever, f250-01, F350DRILLER, f450kingranch, Fanning7.3, farm boy, fast92gsx, Fastassdiesel, fastedy, fatfender, fcjarrett, feedsac, ferociousfish, FF2003F350, fhanrahan, fimar7, findau, Fingernip, fink33, finseeker, firedriver19, firefighter, firth4x4, Fischer, fishindude, flatlineracing, flicker, Flinch, flipkty, flyboy41, foobeca, Ford Crazy, ford19992, Ford3544, FORD4LIFE, FordCowboy, forddieselkicksass, forddude, fordfreak84, Fordfrombirth, fordguy64, fordizsick, fordman2121, FORDMAN345, Fordmud1, Fotno, Francesco, franmar_slo, frashdog, Freddieg37, freshstroker, Frodo, frosty111-000, fubar68, fudge35, futures1, Fuzz, gabebuttler, garden_grub, Garydmundy, GASMAN6674, gb1911, Gcashwell, GCncsuHD, geargrabbin97, geauxtigers9663, geidson, genuineford, gfkkarl, ghamrick, ghohouston, Ghyslain, GilroyRacing, ginoholt, Gkheadley, Glamping, glenn, glmorgan, Glock 20, glovemeister, Goatwrangler, GodGunsDiesel, godzillas dad, gohawaiian, goldiestroker944, goncrazy2003, Goneracin, gonzagabull, Goodbar419, goodoleboy45, Gosouth, gots_a_sol, Gotti2k7, grape, GraveDigger88, greatgrizzlybear, Gregch, Griz, Grizz99, gtakamoto, gwilliams2705, GWStoke02, hag000, Hansel, harleyguy13, harperc, harrymank, hatchman, Hater04, have12, hawkeye, HB-DELUX, hdchopfather, hdfattboy2001, HeadHunter, headlayoutman1, heilmrp, Helsley06, hendershot, highlandre, hildebrand, HillbillyDeluxe39, hilljack33, hiphopper, HMBUILDER4U2004, HockeyDude, hofiveo, Holleran, HollywoodTRBros, holmes76, honda68, hookupdiesel, Hoss1997, Hossified, hotchki, hrc200x, HRS PLY, hughball65, huntdog12, hunter scar, Hytcrdnk, IBeStrokin'7.3, IbeStrokin'97, ibq'n, Idaho Shooter, ih1947kb3, IL7.3 Powerstroker, iowahogfan, IraqVetUSMC, IrishGreens, ironhorseman, isak, Ithumpwheniwalk, itsallinthestroke, J.J.J.S2009, j007, J1mSevier, J5pete, Jack Petrie, jackadams, jacooper77535, Jagsdiesel, jakepolly, jameson, james_mtz07, jamisgood, Jarred hodges, jasensmith, Jason A, jason mondy, Jason.Horath, Jason73, jawaner, jawsfx4, JaxJar, jaybell, jaydirt, Jayhawk246, jbarlow15, JByrdWend, jc82chevyman, Jcam88, jcb, Jchappy12, jcmagone, jcsheriff, JD3020, jd444, jdecker88, JDH, jdk, jeenyus73, Jefferson, jeffvato, jelk15, jelk151, Jellyroll22, jeremiahmercier, JeremyRB, jeromejcp, Jeron, jerryjust, jersan1982, JerseyJim, jess, jessduen1, Jestes, jetdok2r, Jgman141, jgreer, jhyder408, JI97PSD, jim17, jimbobwhite, JimG, jimmiejet, jimmycrackcorn79, Jingoist, jjmills, JK Fab, jkiolbassa, jklso, jlermann, jloomis, jlray17, jlwalker9, JMK2003, Jnalaplace, joedaddy, Joefish, JoesEX, johnday, JohnDeere9610, johndeerezach, Johnny77Mutt, JohnnyTurner, johnrhodes, johnsps250, JohnTLittle, Joldham1016, Jolo170, Jomax, jonboy1833, jones184, Jordison460, Jordy53, Joush, jp988, jpxj94, jrex2506, JS98, JSC, jschildm, jscott64, Jsgarwood, jtgf250, JudgeKustom1, julpilon, juniort444e, just shawn, justin1889, justin8341, Justincredible, justinsane1, juvenile9, jwatkins, jwatrous, J_F250, K5383, KaBar, kade625, Kampy, KansasStroker, katostroker, Kazairl, kazmanff, kb2red, kcbhiw, KCDAXFACTOR, Keitho22, Kenneth L. Kilby, Kenny Bob, Kevinoffroad4x4, kfluke, kfredx, kickass54, kickstand, KingFish, Kip, kip4234, kips, kip_66, kirb390fe, kirkh, klacasse, KliffBar, Klr685, Knuckleduster, Kohrnholio, koltonv, korg70kbc, Kowe69, KPSquared, kramarj, Kris@MPD, KSC350, ktmrider, kvn555, KWT2000, KYcopespitter7.3, kylerf150, Kyle_KleinSS, kypowerstroke, LANCE105010, larryb, Larry_Dubya, lavernreiff, Lawn Jockey, lbeinks, lengelhardt, lesmes, lg07brute, lght1, lightnin, likearockcrusher, liltimmy08, LIONHUNT64, lisles7.3, livnlrn, lms, Locoelectrician, logo88, lonewolf, looper, lossscause, loudmouth, louisvanwilker, lpurinton, lsmenterprizes, Lt.DanHasNewLegs, ltlstnkr, lubeowner, luckee_d, LuckyFarmKid, lukiss, luny2nz, lvnlrge63, m320, MacDinho, macgyver5150, mack1, Mad Max, Madirsihman, madmaxz, mainedieselbill, mainer815, manleystangs, mannscustommotors, marco93L, Marine5811, markbrown47, markfuga, markm, markt, markyt, marshall99, MartinPenwald, martins96, Marty, Marty Mechanic, martymechanic, marx96, mas0427, mason_411, MasterJake, Matt-F350, matthewd11, mattmankow, Maverick26, Mayhugh, mckeddie, Mdt1992, MD_F250, meflamout, mej1201, Mercracing, mereynolds, metalphd, mgmccartney, mhfarmboy, michael521, micky_blue, middlemanjw, mike19, Mike96ZJ, mikecd, mikeg, miker660r, mikes6423, mikey28804, MilehighEX, milehighstroker, miles mckeown, mineonenj, minzbig, mjonesjr, mleg1972, mlynch1991@yahoo.com, mnstroker, MN_MountainMan, ModRx, mojoman, molikpaq, moliverna, Monster_NRG, montana350, Monumentally, Mooseposse, Morning wood, morseranch, MoStrokinIt, MOTO7.3, motocross01, motoxer93, mph881975, Mr.Wonderful, MrBill1, mrtheory, mrtoddy, Mrwr1223, Mr_Andy, mstadler13, mtgrease, muchi56, Muddin, mudguy, Mudlight, mudman6970, mudslinger02, Muleman2, munchie, mustang8992, MustangMatt96GT, mustube, mwessel, mx929racer, mxtwo50r, my79f, myerstech, Myles_S, mzwizanski, nashvillebill, nate00stroke, natedp, nation1979, NEBR99.5 OIL BURNER, neverkickn, NevrKnow, Newman, newmexicocrawler, newpowertroker, ngtstk3r, nhra686, nickeagle, nickels23, nickersonm, nickmcd, Nidecker1, nielsencod, nikole95, NiteOwl, nitrous mike, Nitrousjunkie347, njjeep, nl1990, nokes43, Nomapride, nopainnofear, nor, NORCAL-AW, NorCal997.3, Norm-TX, Northcountrywood, northid710, NorthlandTough, NQF350, ntgd1, Nutz, OBS BUILD, OBSDUALLY, OBSWIZ, ocracokeisland, odandy, ohiopowerstoke, oilburner2000, Oilfield_Digger, oilplane32, OKState, ol red, OLD'SCOOL, oldblue96, oldbluef250, oldcootonascoot, OldRedFord4x4, ole red, ONE BAD EXCURSION, oneshotonekill1966, Onetime12, ons hawes, optimus, Optimuscrime, Orezona, orly, Osofast, osumrall, otis_301, outalinecowboy, Outlaw1, OUTLAW101, Ozutah, ozzy 2002 psd, O_O, pag, PALMER02, papadelogan, parne, patricksar, Patrolman, Paul Capel, pc97f350, PDEMICH, pdj4814, PESCAHOLIC, Peter Gill, Peterbilt66, Phased3, phercinger, phillypsd7.3, PIERSON, pitcrew, pmasterson, po582, Pocket, podunk, policefordtuff, pontiac, ponypusher58, poon, pooter, Pops, porkchop097, Porkey47, porkeysr, powersmoker73, Powersmoker97', Powersmokesd, Powerstatement, Powerstroke Racer, powerstroke02, POWERSTROKE2311, powerstroke7493, PowerStroke94, powerstroke95, Powerstrokeeee, PowerstrokeMudder82, PowerstrokeR00, powerstroker20, Powerstroker350, powerstroker66, powerstrokeU2, Powerstrokex, powerstrokin01, prheitz, printzjd, procomp, ProF100, Prozon, prplpowerranger, psamead, PScompGenius, psd77066, PSDEng, PSDfan99, psdguy08, PSDLTD, PSDnate, psduser1, psims20, pstroke96, Pstroke_Dev, PwRsTrKe8907, quad143, quiznos_69, racefirecat, racer0121, racer8828, Raddadninja, rage250, ralph, ram360, ramaka90, RamIt, rancherstroker6, randyo156, Randysrollincoal, rangerboy234, Ratfink, raven, Ray Barnes, rayd1969, RAYZOR, rcktman, Rclayton7.3, rconcrete, rcooper919, rd2boys!, rdbranch, rdlewis, rdstud60, ready81, Red95stroker, Red97, redarrow325, redimix08, redline61, redneck mechanic, redpowerstroke, redram86, REDTHUNDER, reilly8282, Renegade7.3, Renegade73, Repyns, retiredsparky, retwelder, Reyf350, rfrostick, richard720, Richie, Rick59, RickF350, rickrhedin, rickvm, rider2xtreme93, rideracelivemx7, ridered99, ridiculously_necessary, RidinHigh, rileyrs, rimer1270, rinkeswa, Rixster, Rjmorrow, rllove, RLSCOAL, roachfam2, roadhzrd, Rob G, rob k, Rob02F350, rob10970, rob72, robbs4525, robert morgans, robert58, robr1970, robroy64, Robsdiesel, RockDoc, rockincrc, rogerm311, RoGrrr, Rogue1987, rollin22s, rollingcoal69, rollin_smoke, Ron's power stroke, ronngat, ronniecbass@yahoo.com, RookieStroker, Roots, Ross01, Royl_Bull, rpm-inc, rsbhunter, rScotty, rsfvscott1, Rufflehouse, Rupp250, Rusty-Ford, RustyHighboy, Rwtrower, RYan Gortney, RyanG85, Rybread1027, sagemonkey, SaintITC, salprofish, sam2003, sandfantom, sandmn1010, Sarge97, sasquatch, sausage450r, sbrofford, schemi, Schneider 86, scobee, scott99psd, Scottapher, scottmcd9999, Scotty_N000, SCPSD, screagle07, screamnstroker, SD01WD, SD70M, SDRiverRat, sdwi, Seawrench514, Seth Wilson, Seven-Point-Three, seven.3, sga6.0l, sgleshot, shawnsam, shaynep, shock, sick97psd1, sidetrack00, signguy, silent64, silverhoss99, simpleman, Sinisalo425, sinister dave, sinnful_46534, sirkdev, sirsofus, sjohnson0027, skbbuilding, Skintback, skippy, Skooter_Built, skriz69, slappy, SledDogg, sleepyhead416, slim0212, slimer691, slingshot, slippydaman, Slogging, slow7.3, slowduty80, slufkin, smith7.3, smjrhp1, smokindiesel2, smokinstroker92, smoknit, snapon66, sniperjms, sniper_101, snookslayer7726, snoopdog, Snowmannn, SNR, sodrod332, SoFlaKev, sokdaddy444, sol80, solrac06, sotexy, SouthJerseyStroker, southmike, Southpaw, Sparticus, spittin dip, spokanepaul, spoolin97, SpringerNC, square1, squeak12, srlaws, srswain, srutherford1, SSpeeDEMONSS, sstdriller, sstec, st1speed, stackedstroker, stalyon, stamfam6, Stampitguy, Stang07, stangn, Stanton, STAX, steve phillips, steve.s, stevedrums, stevv, stickboyracing, stlhdfishr, Stoneguy, stoney126, stoneykegonsa, storker95, stout7.3, stroked1125, stroked2000, Stroked550, strokedandhooked, strokedoc, StrokenBigBlue, strokeofagenius, strokeorcroak, strokepower, Stroker02, stroker83, STROKERBO, strokestar, Stroke_This, strokin dually, Strokin In Texas, strokin w/ alil cayenne, strokin09, strokin340, strokin7.3, Strokin87, strokin93, Strokin96, stryker258, Stump-puller, Suber 7.3, Summitdog, sunny644, Super Trucker, SuperStroke99, survivor, swampjeep, SWVa, SyN, t4050nh, T444, tallpaul, tangobravo, tardymike, tazjeepman, tbutera2112, tch.280, tecelec1, TechsMechs Power, Teecher45, tella, temaind, terrye, Texaskid89, texasredneckjae, TeZmonster, tgf, The Fireman, the wrench, thecabinetguy, thecrazyhorse, theghost47, thehydroseeder, thepapabear55, theron1128, theSLEEPER, Thesmokinpowerstroke, thirty two, thobui, tholdenfl, Thomas7.3psd, thunterf350, timar, timmartindale, TimmyNiewald11, Tims7.3, tjl, tkdbf350, tls390, tm86, tmalin72058, tneibling, tnsmoke, Toddw, tokinstroker02, tom 7.3, Tom S, tommydiesel, toms7.3stroker, tonka350, topshelf7.3l, Toreador250, torquepower, towsurfer, travis182008, travis79, Trayballs95, Tre Strokes, tree trimmer, trenner101, treps7.3, trixxstyles, troylance, Truck4, truckcap22, TruckeePSD, truckshop, Truck_driver06, TSJSD99, tstory1, ttec4u, ttyR2, Tuco, TucsonDon, tughill283, turfsupdon, TWIM, twrench, tx4x4psd, TXBammer27, txgp17, TXsmoker, Tygen1, tyler886, TylerDurden, TylerH, u.f.o., Uncle Salty, Unklhuck, upchurch, uptownkevin, usa1tonf350, USMCTJ13, Utah7.3, V-Ref, ved0303, VeggieOilDoug, vern232323, vf24tomcat, vic32ft, viddycent, villestrip, Virginstroker, voodoomaker, VW_Factor, wabosmoose, wadely, wakerc, walrus89, waltenbach, Wardy70, washingtoncoastie, wbdodgeiv, wds1279, weebieboy, Welder1, Welder843, wfstell, Wh19L45H, white06lbz, whitebeast73, WhiteCC250, whitekong, whitestroker99, Whoa566, Wholigan, whudson, whytry, wildstang3, wils2527, WilST, wiltface, winkfab, Wish_It_Was_A_Bowtie2004, wkrpinnick, Wojo, wolfmanfpd, wondo, Woodbeef, Woodnthings8, wooner, wristjockey, wrkoutaholic71, wyomingzephyr, Wyostroke91, xnigelx, xtreme radial, XTrmXJ, yeldarb, yosso, you smoke, yyaluff, zack179, zankof, zerocool420, Ziggy, zilla68, ZOSO, zx6rdewayne, ZXSEVEN
You may not post new threads
You may not post replies
Forum Jump
