turbo pedistal bolts - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 03-26-2009, 08:45 PM
diesel_brad's Avatar
diesel_brad
Offline
STILL LEARNING
Member's Gallery
does anyone know if the bolts that hold the turbo to the pedistal can be reused?
__________________
I am probably the most hated person on here, and I don't care
97 CCSB 4WD DRW 7.3 5spd DP Tuner, 6637, Flo-Pro SS Exhaust, 99 I/C, T500, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, SD springs Front/rear 315/75/16s,
Bunch of other trucks
Old 03-26-2009, 09:08 PM
guzzle's Avatar
guzzle
Offline
Member's Gallery
Re: turbo pedistal bolts
I think it depends on how many times you have removed and re-torqued them. Like any bolt, the threads will stretch some each time.
I would feel comfortable with re-using them twice over the original installation.
__________________
Bob - 'guzzle'
02 F350 4x4 SRW EC LB Lariat
guzzle's Mods & Maintenance Website
  #3
Old 03-26-2009, 09:20 PM
diesel_brad
Offline
STILL LEARNING
Member's Gallery
torque spec's?
  #4
Old 03-26-2009, 09:25 PM
guzzle's Avatar
guzzle
Offline
Member's Gallery
Another DEPENDS....
Ford's specs for both the pedestal to block and turbo to pedestal is 18 lb-ft.
Garrett's specs for the turbo to pedestal is 35-37 lb-ft.
The last time I installed my GTP38, 18 on the turbo to pedestal leaked a little and 35 fixed it. Others have stated the opposite.
  #5
Old 03-27-2009, 04:22 AM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
I've had mine off four or five times, never even put a torque wrench on them. Just tightened them up really good. No leaks yet.
__________________
  #6
Old 03-27-2009, 06:08 AM
99 7.3's Avatar
99 7.3
Offline
Member's Gallery
just make sure they are tight and the o-rings are in good shape (new). had mine off a bunch of times. no problems so far
__________________
09 6.7 cummins w/ a couple things
  #7
Old 03-27-2009, 01:45 PM
guzzle's Avatar
guzzle
Offline
Member's Gallery
According to the engineers (No engineer here so I can barely get my head around most of this stuff), The whole idea of torquing a bolt is to 'stretch' it so it will stay in place. From trying to get through some of the studies I have read (ever try reading a telephone book?), during the process of torquing a fastener there are radial and torsional stresses placed upon the bolt. These stresses begin the process of eventual metal fatigue.
On the turbo pedestal, you have additional stresses of heat expansion and contraction due to the close proximity of the exhaust turbine housing and downpipe. There are numerous automotive fasteners that are considered "consumable", meaning they should only be used once. I doubt if the turbo bolts fall into this category.
Due to bolt stretch and the possibility of metal fatigue failure, I said that I feel "comfortable" with only using the bolts a couple of times after the original install, that is not to say that you will or won't get many more uses out of them before the bolts fail. I just don't want it to happen when I am 500 miles from home.
One other thing I found interesting is the use of bolts and washers over the use of flange bolts like we find on the pedestal bolts:
"Do not use plain washers; their use can result in relative motion to change from the nut to washer, to washer to joint surface, during tightening. This as the effect of changing the friction radius and hence affects the torque-tension relationship. If, because of excessive bearing pressure, a larger bearing face is required, thought should be given to the use of flanged nuts and bolts."
(View-All Members who have read this thread : 69
02BigD, 444-4D, 91turbogsx, 96powerstroke7.3, 99 7.3, abbottfarms, abianca99, Arisley, Black Beauty 7.3, bryan rittenhouse, Bushwakd, chappy, chief055, CLIFORD3, codypowerstroke, cota, crowz, dblamp, diesel_brad, ditch_dawg, dzlstroker, Eric, F-350, f350mike, fastedy, fyrehose, guzzle, Harl, haulin99sdp, HMBUILDER4U2004, jaybuller, jdc753, JMF350, johns23, john_from_ict, jroller, J_F250, krankin, Layson, lehi, Martin #6, nasty96, NorCalDiesel, olyaee, OzPowerstroker, PeterB, psdually, Ramblin'_Man, retired jeeper, rich in co, Ripsaw, rpm-inc, SD01WD, smokinndstrokin, sneaky09, squeak12, straitcountry, Stringer Driver, Stroken7.3, StrokerTurbo7.3, thomasinnv, ToddZ, wooner, yobuda, Ziggy
You may not post new threads
You may not post replies
Forum Jump
