What tank said plus depending on the backspacing of the rims you run will affect it but you should be safe with the run of the mill 35x12.5 and will look 100x better with a leveling kit, its amazing how little of a chance can make a big difference.
Worst case you might have to remove the front factory mudflaps and trim the plastic valence under the bumper.
Flaps are gone and trimmin the plastic is cool. I don't want some huge lift and I dont take my truck off roading for fun (thats what my baja bug is for...). I need new tires and I wanted to do rims at the same time. whats a good backspacing for 35's.
For the backspacing I have 18x9 rims with 5.00" which pushes them out a bit more than the factory rims. They stick out a little bit but not too much. Mine are wrapped in 325/65R18 Nitto Terra Grapplers. I also have the factory flares that add about 3/4" to the wheel wells, not much but just so ya know.
