Trans/Transfer case Fluid - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 10-02-2013, 12:20 AM
ltracer06's Avatar
ltracer06
Offline
POWER ON
Member's Gallery
I am changing my tranny and t-case fluid and I was wondering what fluid I should use for both? Also I have a new transmission from jasper and it say synthetic mercron, is this right?
__________________
1995 F350 XLT 4WD Powerstroke SCLB 5-SPEED
35/12.50/17 MTZ's, 17'' Helo Wheels, 4'' Lift
Edge Evolution, 3'' dp, 5'' Exhaust, K&N Intake-Fliter, Cobalt Autometer Gauges, Performance Clutch
Reply With Quote Quick reply to this message Go to the top
Old 10-02-2013, 01:09 AM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
Re: Trans/Transfer case Fluid
Dont need synthetic in T-case. Regular mercon is fine. If the warranty for Jasper trans states must use synthetic ATF, then use it
__________________
97 CCSB 4WD DRW 7.3 5spd DP Tuner, 6637, 4" Flo-Pro SS Exhaust(3" DP), 99 I/C, T500,Cali Truck w/120cc Split Shot Injectors, 1.0 exhaust housing/WW2, Irate Up-pipes, CCV Mod, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, PMF Traction bars, Rear Air bags,SD springs Front(V code)/rear(B code), 315/75/16s, (6)Alcoa 16x6 wheels 300HP/561TQ
  #3
Old 10-02-2013, 02:44 AM
ltracer06's Avatar
ltracer06
Offline
POWER ON
Member's Gallery
Its ATF in both?
  #4
Old 10-02-2013, 02:58 AM
gnxtc2's Avatar
gnxtc2
Offline
Member's Gallery
Yes^^^^^
Billy T.
gnxtc2@aol.com
__________________
'97 Black F250HD SC
Punisher trans, PI Converter, 6.0 cooler
Dana 60 RSK w/ V & C SD springs
PIS 175/80s, Honey Badger Jr, Comp910s,
Smith Bros Pushrods, ARPs, Fluidampr, IC, E-Fuel
3" Plenums, CJC Traction blocks,
HFHV IDM, Billet D66, Tuned by NLTD
238K
Other vehicles
-1987 Buick Grand National (Staged)
-2004 Mercury Marauder
  #5
Old 10-03-2013, 10:44 AM
jeremiahmercier's Avatar
jeremiahmercier
Offline
Member's Gallery
A lot use the Redline MTL (Manual Transmission Lube) and claim better shift quality and less gear noise. I myself prefer the mtl to the atf. There are a couple brands of mtl, I'm sure they all would work.
__________________
-1996 f250 4x4, ZF5, ECLB, Firestone ride-rite air bags, Fuel tank vent mod, Live tuned Dp-Tuner, CAI, 3"dp, FF stage 1s, CCV mod, t500 , SB clutch, D66, Beans Fuel system, and hypermax intercooler. now w/ BASB turbo, Irate t4 mount, & P.I.S 175/100s
-2002 F250 4x4, auto, ECLB, CAI, CCV mod, Live Tuned Dp-Tuner, air heater delete, 4"dp
  #6
Old 10-03-2013, 11:06 AM
SledDogg's Avatar
SledDogg
Offline
Member's Gallery
I run Amsoil ATF in my t case. About to put in my trans again.
__________________
06' F250 Harley Davidson CCSB-blue sping kit(massive difference)
02' F250 sclb 7.3, Auto, 4x4, XLT loaded, Frnt Add-a Leaf, 4" Silverline tb, 6637, Billet Grill, Dynoproven.Com Honeybadger Jr HPOP, Full Force Stage 1 sticks, F8 chip w/Jonathan tune (Dynoproven.com), Air Lift 5000 air bags, Curt Q20 Fifth wheel,, RCI 60 gal Aux fuel tank,[B]
  #7
Old 10-03-2013, 01:56 PM
jeremiahmercier
Offline
Member's Gallery
The redline mtl is advertised as made for manual trans that call for atf,... just a side note
  #8
Old 10-03-2013, 03:03 PM
madpogue
Offline
Member's Gallery
^^^^ Castrol TranSynd is another product made for this "class" of gear box. The 5-speeds in the original Saturns were of this type, and their folks swear by the TranSynd. Supposedly available at truck stops, but I haven't been able to find it locally.
  #9
Old 10-03-2013, 06:06 PM
Patrick Feeley's Avatar
Patrick Feeley
Offline
Member's Gallery
When I bought the TranSynd for my 94, I got it at the "local" (nothing is that local to me) ZF distributor. It was $45-$50/gal about 4-5 years ago. Cheers!
__________________
  #10
Old 10-03-2013, 11:29 PM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
I totaly missed the 5 speed in your sig
YES, SYNTHETIC ATF
On a side note, has anyone use GM synchromesh in our 5 speeds?
If you do not want to register, fill this field only and the name will be used as user name for your post.
Human Verification
(View-All Members who have read this thread : 52
1992ccsbpsd, 96 7.3, 96powerstroke96, 97-7.3powerstroke, Alan Hicks, Arcturus, atbays, BBowden73, bfoster, Bobs 7.3, Bradbilt, Bradysmail1969, Bugman, camd94234, cpdad93, csp, D66stroke, deezeljunky, Esp0660, Gaius, gnxtc2, Greger96obs, gsxr1216, hendricksbus, Hijo202, jake2far, jamessabb, jeremiahmercier, jtgf250, ltracer06, madpogue, Mike97f350, Nodge, OBSpstroke97, OilBurner62, old man dave, old Smokey, Patrick Feeley, plzstrokeme, Powerstroke Man 6.4, Redman84, RM20, SevenThreeOBS, SledDogg, spd1979, superduty improved, ToddM715, Tom S, twentyfootdaredevil, umpalumpa1985, wesjordan
Forum Jump
