7.3L turbo engine loses power/RPM's - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 02-16-2009, 04:48 PM
99 SuperDuty
Offline
Member's Gallery
Question 7.3L turbo engine loses power/RPM's
When holding at steady RPM's either driving or running in park (doesnt matter) it sounds like the engine is releasing air. When it does the engine loses power and the rpm's fall. If I accelerate it goes away until the rpm's hold steady again. Any ideas? ? ? ?
Old 02-16-2009, 04:57 PM
7.3fordman
Offline
OBS PSD Owner
Member's Gallery
Re: 7.3L turbo engine loses power/RPM's
My 96 Powerstroke has the same problem, at lower RPMs (1500 range)when motor is cold, while holding the same throttle position. Push harder and it will speed up and be fine. Can hear the same air sucking noise. Any Suggestions?
  #3
Old 02-16-2009, 05:07 PM
casper7.3's Avatar
casper7.3
Offline
Member's Gallery
only when cold i'd say the ebp valve is closing in wich case it would be a normal condition
on edit: welome to the nation guys
__________________
LUKE
2002 CCLB AUT0 4X4
S&B, DI/PRICOL GAUGES, CCV, ZOODAD, TS CHIP-MATT AT GEARHEAD,
38R, ADRENALINE, SWAMP'S IDM, 4" T/B MBRP
05 CONVERSION, 4 INCH LIFT, 325/65-18 FIERCE ATTITUDE M/T
WILSON 5000 GALAXY DX66
  #4
Old 02-16-2009, 05:08 PM
Fever's Avatar
Fever
Offline
Lurker...
Member's Gallery
EBPV sounds about right...
__________________
2003 F-350 Super Duty
  #5
Old 02-16-2009, 05:26 PM
7.3fordman
Offline
OBS PSD Owner
Member's Gallery
Where is the EBPV located and should anything be done to fix this annoying problem?
  #6
Old 02-16-2009, 05:34 PM
99 SuperDuty
Offline
Member's Gallery
my 99 doesnt do it cold. It will do it all the time. It is very annoying. It seems to be stealing power form the truck.
  #7
Old 02-27-2009, 01:25 AM
7.3fordman
Offline
OBS PSD Owner
Member's Gallery
Is it a possibility that it could be the wastegate??? Someone heard my truck and said that was what it sounded like
  #8
Old 02-27-2009, 02:22 AM
Harl's Avatar
Harl
Offline
Harl
Member's Gallery
Send a message via AIM to Harl
Yep its the EBPV... My 96 did the same thing when I drive it took the power from my truck so I just unlpuged it..
__________________
Cody,17
DD-1996 F250 Powerstroke, 5speed, 4x4 ecsb
Mods: GlowShift Gauges-Boost, Pryo, Oil psi and Fuel psi. DIY 6637 Intake, 160/100's, Wildman 6pos, Stage 2 water/meth, D66, TE HPOP, Vailer Clutch, Custom Bars and 5in turbo back....
PT-1995 F350- totaled
Soon to be brought back to a 1992
http://www.youtube.com/truerednecks
(View-All Members who have read this thread : 66
01Danny, 7.3 superior duty, 7.3fordman, 91turbogsx, 99 SuperDuty, abbottfarms, aklim, Archery Hunter, Arisley, Barnbuilder, big_stroker, Bronx, Bushwakd, cardiac, casper7.3, dblamp, DcMoore999, Dieselgeek, dixieland-diesels, ELEV OFF, f350mike, Fever, fixithud, flhpi-ohio, fordguy64, golfer, Harl, hookin78, Houser04LLY, ironworker25, jake4747, JBrown8988, JerseyJim, Jesse Lambert, jjdup, johnday, JustDiesel, matthewd11, mattrac, nasty96, ohiopsdfordman, outlaw 4017, Outlaw1, Pdt1081, perwin24, powerstroke006, rconcrete, retired jeeper, Ripsaw, Rmartin-97, SEANPATRICK, sissy, SS317, stangwengert, Stringer Driver, Stroken7.3, stutterinwithastack, Super_Hauler, tbolt, TERRCO, Thomas7.3psd, tonyton71, toolmangary, trimacwest, zilla68
You may not post new threads
You may not post replies
Forum Jump
