He bypassed the water injection computer and he accidently left the switch on.......now the engine is full of water. Its hydrolocked.......i just spoke to a friend in Greenville. This is a 6.0!
the gp's on a 6.0 are outside the valve cover. remove the harness and unscrew the plugs. its is pretty east on teh driver side. the passenger side is quite the pain, esp if its got the old style harness that is all connected together. youll have to either break the harness, remove the cover to the ac box, or get REALLY creative. if its got the new style harness, you should be ok.
if u try to remove bus bar you will probly break it ($100+ part). remove valve couver n push off from inside glowplugs are 10mm deep socket. if there is coolant on plug u will have to change glow plug sleve
