We own 2005 F-250 Powerstroke and it is equipped with ARP headstuds, EGR delete, 205cc injectors, custom turbo w/ a 66wheel, airdog 150 PSI pump, regulator return fuel system, banks intercooler, MBRP 4in turbo back exhaust, Bullydog rapid flow cold air intake, SCT w/ custom tuning from innovative diesel....
I have not had a chance to dyno it yet.... Anyone take a stab at the hp/torque to give me a rough idea, thanks!
Injectors are from a guy named Josh in Illinois who built his own.. and the turbo is the stock turbo VGT with 66 wheel, and machine housing from Garrett
The Banks exhaust and intercooler are good parts, they are the only Banks stuff I would get for my 6.0L. I have the intercooler, but still running stock exhaust.
Josh's injectors on a VGT should smoke like CRAZY. I run his 150's and they lay a cloud on the right tune.
Josh's 200's with a 66mm Fixed Geometry turbo put down almost 600hp on fuel about a month ago on Cale's tuning.
I'm guessing Eric has fuel pulled on them, I would give him a call and see if he has compensated for the larger compressor or if you are running a stock VGT tune.
while were on the subject, anyone wanna give me an estimate? everything is in my sig...
