#101
Re: Traction Bars
That sounds great. I take still real no downsides that you have noticed.
#102
Re: Traction Bars
I think I have it correctly mapped out on a template how the axle moves fore and aft when the suspension is compressed and released. I believe the spring at the front end from the eye to the axle gains 1/16 of length released and shortens 1/8 to 3/16 when fully compressed. The suspension otherwise I think follows the radius from the front spring eye to the center line of the axle with an appoximate travel of 5.5 inches up to the bump stop to 2 inches dropped til the shocks fully extend.
I drew that out on paper and started playing with possible places on the frame to put the front mount that best follows that adjusted arc. Using the pro comp brackets the bars do not really need to be super long like one might think. I was looking at a 58" set when I quit playing with if for the day. The brackets should be here this week so I can better mock it all up then. I also want to compare how it looks on paper to what the driveshaft angle is. If it that comes out close I would feel really comfortable. Tom Last edited by Tom S : 03-22-2009 at 06:42 PM. |
#103
Re: Traction Bars
Tom, from my experience, you would be best served to install the rear mounts and their joints then play with the tube length using pvc. The front mounts will locate the joint centerline at about 2.5" below the frame rail (IIRC) and this is difficult to account for until you have them. You're correct on needing a shorter tube length with the procomp mounts because they are mounted higher on the axle-- the link is basically the hypotenuse in the triangle.
In thinking about my truck (lb sc), a 58" tube would have oriented at a flatter angle than the drive shaft. I would have liked something a little longer but it could not be accomodated. My tube angle is 'slightly' steeper than the shaft. However, my suspension still has good compression and loads the links good under pinion load so it appears to be very close. One last thing, with the adjustable joints, you can change the centerline length range of the bars by about 3/16" between preload max and min. The preload is still unknown and I want to play with more when towing a trailer. I'm happy with it empty but the jury is still out on the trailer....
__________________
94.5 F250 4x4 SC, 5spd, 196K, ACs, TDP 6pos, SD IC, Termy modded 17*, IDM/CCV mods a shined up old turd... |
#104
Re: Traction Bars
Thanks for the reply. I have really enjoyed this thread and am looking forward to this project.
Tom |
#105
Re: Traction Bars
Awesome. One day I will beable todo that
__________________
1994.5 F350 CC Long Box 7.3 ZF to Auto E4OD conversion complete. |
#106
Re: Traction Bars
The brackets arrived today. Nice pieces and a lot more heavy duty then I was expecting. I think the box was like 20lbs. Kind of a shame I will not be using the nice poly bushings from the kit. Just need to touch up the powder coat some where they were touching in the box. Thanks to Chris at Truck Source Diesel for getting these too me.
#107
Re: Traction Bars
I started working a bit on this today. The rear mounts were not exactly bolt on. With the spring perches on my axle, I had to scribe them in to fit flat on the spring perch as they were hitting the tube. Got to spend a little time with the angle grinder on that deal. I also had to elongate the hole where the locating pin goes just a bit. I should have the rear bracket installation wrapped up in the morning though.
Tom |
#108
Re: Traction Bars
Re: Traction Bars
95- I was about $500 incl u-bolts..
Tom-- I first thought that I'd need to clearance the mounts a bit but they sat flat and touched the axle tube a little. Your spring pads must have been a tad shallower than mine were to have your mounts rock on the tube. I then had to put in the extender bolts on the spacer block. Not exactly bolt on, I agree... |
#110
Re: Traction Bars
I reused my U-bolts as they were good shape although I did consider if from a safety perspective. I did review the factory manual and it did not say anything about not re-using them. When I put new springs in the front years ago I got them from a medium duty truck parts place in town and they made them up while you waited for them.
__________________
96 F250SC 4X4 AUTO![]() F-6 live tuned, BTS Transmission, 38R, Swamps Babies, Custom electric fuel, Banks Intercooler, Tymar intake, Cowl Hood, 4" Stainless Magnaflow/Aeroturbine exhaust 14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected Colorado PSD Club***Fuel System Photos |
| Thread Tools | |
| Display Modes | |
