Performance Truck Products
Go Back   Powerstroke Nation > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 OBS Power Stroke - Aftermarket & Performance
Register FAQ Members List Calendar Timeslips Videos Sponsors Becoming a Sponsor Search Today's Posts Mark Forums Read
Closed Thread
Thread Tools Display Modes
  #1
Old 02-01-2009, 02:59 AM
ckbed's Avatar
ckbed
Offline
E-Hug
Member's Gallery
Traction Bars
Have the stuff to make a set, just had a quick couple of ?s about mounting them.
Recommendations on what to use for the bushings on each end, can't for the life of me remeber what they're called. What and where should I mount to the axle at? A couple I've seen basically either piggyback the leaf springs, or have a mount right next to em. And last, is there an optimum angle/length they should be?
Gracias
__________________
Cody B
{1996 F250 XLT PSD}ExCab 4x4 Auto, It makes air and diesel into energy so the wheels go 'round......
Originally Posted by bigrpowr View Post
.....you are as smart as the people you surround yourself with..so by default you are a retard.
Northwest Ford Diesels
Go to the top
  #2
Old 02-01-2009, 03:11 AM
nasty96's Avatar
nasty96
Offline
That thing got a Cummins?
Member's Gallery
Re: Traction Bars
I'll be making my set this spring. Going to weld brackets to the axle, and put the angle of the bars @ driveshaft angle, being my trucks a cc, they are going to be between 7 to 10 ft. IIRC, I think you are refering to what is called a hiem joint.
__________________
Ford makes it, I break it
1996 F350 CCLB 4x4 Broke Built Auto
2000 Dodge 3500 5 Speed 4x4 450k and Counting
2001 Dodge 3500 6 speed 4x4 Fully loaded
Go to the top
  #3
Old 02-01-2009, 04:25 PM
smokyred's Avatar
smokyred
Offline
Too much turbo
Member's Gallery
Re: Traction Bars
My bars are at driveshaft angle, and work extremely well. For my SCLB they are right around 6 1/2 feet long, and the rear mounts are welded under the spring bolts.
Dave
__________________
Smokyred- '97 F250HD SCLB 4x4 OFFROAD 127k miles
Mods: Swamps tunes, BFH-SE/TN 2 kit, Gen3, a BTS, Comps, Crowers, and H11's up top, BLiNGtake plenums, an IC, Comp. fuel system.
Coming soon: Hopefully my injectors, but prolly not this pulling season.
I was Swamped, when being Swamped wasn't cool.
My Pictures
Go to the top
  #4
Old 02-01-2009, 04:49 PM
OBSWIZ
Offline
Sponsor
Member's Gallery
Re: Traction Bars
Don't forget to have a shackle on the frame end.
Go to the top
  #5
Old 02-15-2009, 01:40 AM
Tom S's Avatar
Tom S
Offline
-Moderator-
Member's Gallery
Re: Traction Bars
How did you decide on that length?
I think I am going to use the pro comp brackets from the thread in the SD forum that Charles started.
Tom
__________________
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, 38R, Swamps Babies, Custom electric fuel,
Banks Intercooler, Tymar intake, Cowl Hood, 4" Stainless Magnaflow/Aeroturbine exhaust
14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Colorado PSD Club***Fuel System Photos
Go to the top
  #6
Old 02-15-2009, 01:56 AM
ckbed's Avatar
ckbed
Offline
E-Hug
Member's Gallery
Re: Traction Bars
Yeah, I looked at the pro comp brackets too, found some heim joints for a decent price. So I may just use their mounts and build the driveline to that.
Go to the top
  #7
Old 02-15-2009, 03:10 AM
smokyred's Avatar
smokyred
Offline
Too much turbo
Member's Gallery
Re: Traction Bars
Negative on that, unless you are using 2 mounting points on the axle and 1 on the frame. If you mount using 1 point on each with a shackle on the front they will not work.
Dave
Go to the top
  #8
Old 02-15-2009, 03:14 AM
smokyred's Avatar
smokyred
Offline
Too much turbo
Member's Gallery
Re: Traction Bars
Tom
Tom, if you have a long bed on your super cab, yours should be around 6 1/2 feet long like mine, assuming you have a stock height truck. Just sight the driveshaft angle and make them close or the same.
I'll see if I can get some pics of mine up tomorrow, I'll have to get some taken of them.
Dave
Go to the top
  #9
Old 02-15-2009, 03:29 AM
rickey
Offline
Member's Gallery
Re: Traction Bars
is there something special about that angle or just works for most? if not what is the best angle?
__________________
Sleeping Beauty early 99 F-350 stage 2 intake, 4in exhaust, DP tuner, 180cc injectors, 17 degree hpop and BTS transmission.
Kappa Sig
Go to the top
  #10
Old 02-15-2009, 03:45 AM
Tom S's Avatar
Tom S
Offline
-Moderator-
Member's Gallery
Re: Traction Bars
Dave did you just copy that angle or was there more to it then that?
Tom
Go to the top
Closed Thread
(View-All Members who have read this thread : 381
"THE DEMIZE", 01coleman, 01platinum, 01powersmoker, 01stroker7.3, 02BigD, 03ccf350, 03f250stroke, 04 stroker, 04KB, 1997stroker, 2+2, MN, 2000XLifted, 444Diesel4x4, 444smoker, 5ninef250, 69W900A, 6slow, 73LSTROKER, 90ranajo, 94powerstroke, 95f350, 95_7.3, 96 stroker, 96centurion, 96powerstroke7.3, 97-stroker, 97biostroke, 97F-250HD4x4, 97smoker, 97Strokerman, 97stroker_08, 97_powrstroke, 99 7.3, 99oilburner, 99psd-white, 99sixspeed, ADubDiesel, AKCCF350, AlanB, AlaskaRedneK, Albin, AMB, Archery Hunter, armalite, Astnpwr, baggedbug, Bamboo, bandit67, Bartlett99, Bartman, bazdog1, Believer45, BENZTEK97, Betaracer, big 7.3, Big K, big nasty, bigastrk, BigBadLou, BigBopper, BigCountryPowerStroke, BigRed97, BigStroker, bigwhite7.3stroker, bio-brad, Birdman127, Black Beauty 7.3, blackwaterstroker, blaze42069, BlindViper, blue99sd, bluedge8, BlueOvalDiesel, BMac, BockDiesel, bodaciouscj7, bowtiekilla21, Brennan, Brian Cox, brianb7.3, bryan rittenhouse, Bumpin, buzz380, c.s.langanpsd, carbed87, carter09b, caseih7010, casper12v, cbuttre835, cchildress, cemeyer, CGuava, chadow427, chappy, Charles, charlie99, Choupique108, chris 0., Chrisf97305, ckbed, CLIFORD3, Clint_FX4_TxBoy, CNDiesel, cntryboy17, cntryguy23, Colorado, coope3, cota, countryboyz04, cowboys4x4, cowboy_dan, cp3504x4, crowz, crum71, cumminskiller697, daddystoy, Dantheman, Darth_Stroker, daryl4412, davey99ps, DcMoore999, deiter5262, Dieselfever, Dieselgeek, dieselman47, dieselsoulja, dieselthrash, diesel_brad, dilligaf, DisturbedS10, dixiestroker, dlonno, dlopp, Double D's, DTIEK, Dzchey21, DZL JIM, dzljon, dzlstroker, EverettWV, Evil Temptress, ExtremeFord4x4, F-350, F250Hoss, farm boy, FARMDSL, flicker, flightmeck, flowmasters40, ford6.9, ford7.3sd, FordBoy86, FordF250Stroker, fordtch8, foxracing0934, freddie, Gentry08, genuineford, ghostang93, girvin, gnxtc2, Gobstopper909, goodstktbo, groomzybanshe, halerazor, Hardline, harleystroke_2005, Harohunter, Hartdiesel, haulin99sdp, Hawker, highland512, hinchr14, hitechredneck350, HMBUILDER4U2004, hookin78, hotstik, HOWIROLL56, hutchnoclutch, hwhizbang, Hyde, IHWelk49, INTPSTROKE96, itburns, Jake N, JaxJar, jaybuller, Jaydiesel7.3, jcmagone, Jeepermc, jefsred350, jello, jesus_man, JHill, jibmaster145, jjthomas89, Jmannz25, Jngreen, Joe, joebob3093, joeford302, JoesEX, JohnDeere9610, John_DeereGreen, JonFord, JPG, Junior, kainers, Kentuckydiesel, kip4234, KKUNLIMITED, kofire, KreaseDemon, kyle43335, KYmxracer52, LakesideLimo, Lmgrcivic, Local399, longlivepowerstrokes, lovrin28, magelyz426, MagKarl, Magnum PD, mallardslayer07, mandkole, Marty, matthewd11, mattr66, Matt_P, MB97PSD, mcdad1979, MidTennPSD, mike61, mikes_stroker2007, MilehighEX, millertime379, minidiesel, Monstar, montana350, moore20017.3, msbrpower, MSdiesel83, Mustaine7.3, mwalsh9152, my05psd, nasty96, nasty97, NastyCracker, ncovey, Neal 97 250, Nelly, noshoes, NyCowboy87, OBSBoysel, OBSWIZ, ohiopsdfordman, Ol'Red95, old man dave, oldbluef250, OldschoolPSD, ongoingshow, opie977.3, ParkerFly, pc97f350, Phatbulldog, philzman, pitcrew, powerstroke02, powerstroke095, powerstroke67, powerstroke742008, Powerstroked162, powerstrokefarmboy, PowerstrokeJunkie, powerstroke_23, powerstrokinc, PSDfan99, PSDfreak, psdmike, PSDTECH97, pstroke96, PTSUPERD, Pwrsmkin7.3, qcfarmer, R.E.Lee, RA3PSD, racehauler, radcustoms, Ramblin'_Man, RandysPSD, RCpullerdude, Red97, RedBull_04, redneckabbott, reptillikus, rescue911g, Reubine, RichWT, rickey, Riley250, Ripsaw, Rmartin-97, RNRacing, Rob02F350, Rodknocker, rpenner54, rpk427, rsvrrider, Rtxcoon, SamW, Sanger, Sapps, scro, shiftracing17, ShogunRider, silverslug, skyhigh2000, smok531, smokin95psd, smokin96, smokinford07, smokinstroker, smokyred, sniperonhigh, sparksrides350, Spray7.3, squeeks, Stiletto6.0, Stites02psd, stockjeep47, Stonepusher, Stroked95, Stroker96, StrokerTurbo7.3, sturbo90, stutterinwithastack, t444epsd, TalontedTSi, TANK'S 250, tank23, TECH51, TERRCO, texasmedic01, TheDirt, TheHumboldWagon, theSLEEPER, timfinnegan, tjbeggs, tmillburg, Tom S, tonto13, tractorsny, TravisT, treyloco, TRUBBS, txpsd, UNCOOL, urbanwheeler, userma3648, venomusduck, Vozar, waynej, webb06, whatabudro, Wheels, Why Not, winkfab, wjamesm, woodduck97, wynndaddy, XTrmXJ, yzdude250f, Ziggy
You may not post new threads
You may not post replies
vB code is On
Forum Jump
Hooker Headers
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
