Hangin' Weight - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > The Nation's Hangout > Sled Pulling
Thread Tools Display Modes
  #1
Old 01-07-2009, 08:11 PM
Marty's Avatar
Marty
Offline
Busy Busy
Member's Gallery
Hangin' Weight
Lets see how ya'll are hangin weight on the front of your trucks please.
My truck is but a mere 7400-7600 lbs usually and the weight classes are upwards of 8k... sometimes as high as 8600.
__________________
443.553.9234 - 410.392.3262
Elkton, Maryland
2001 F250 - 11.62 @ 115.76
S475, Irate Gated T4, H11, Crower Springs, Smith Bros, My Fuel, Swamps Tuning, Gen3, 400/400's, Forged Rods.
Old 01-07-2009, 08:19 PM
03f3507.3's Avatar
03f3507.3
Offline
Member's Gallery
Re: Hangin' Weight
__________________
2003 F350 BAMF EDITION
5.9 CR 2.6 Puller
Thanks to
L&L Diesel
Drivelines Plus
Industrial Injection
Farmers Machine
Georend Brothers
2008 F350 Daily/BAMF Tow Rig
Spartan Tuned 7.987@ 84.76 1.65 60ft
  #3
mech2161's Avatar
mech2161
Offline
Cummins Power
Member's Gallery
Re: Hangin' Weight
I used a front receiver that bolts in behind the bumper. I made a bracket that slides in and pin it in place. The draw back is the end of the frame horns aren't very rigid. Over the years it twisted my bumper. Last year I used the same set up but added braces to the tow hooks.
__________________
Kevin
12v CONVERSION IN PROGRESS, Special thanks to:
South Bend Clutch, MOTORSPORTSSUPPLY.COM, Pure Diesel Power & Performance, Carson Stauffer Diesel Service, Weston Shupe, zstroken
  #4
Old 01-07-2009, 08:20 PM
CNDiesel's Avatar
CNDiesel
Offline
PSD
Member's Gallery
Re: Hangin' Weight
How much does each one of those plates weigh?
__________________
1994.5 CCLB 7.3 385 w/zf, 375hp converted to auto.
1996 CCLB, Spearco 6.0IC, 5" exh, Electric fuel, 300/200s, studs
  #5
Old 01-07-2009, 08:26 PM
03f3507.3's Avatar
03f3507.3
Offline
Member's Gallery
Re: Hangin' Weight
each of my weights were around 95lbs so with all 5 and the rack i was a shade under 600lbs added...
  #6
Old 01-07-2009, 08:50 PM
Marty's Avatar
Marty
Offline
Busy Busy
Member's Gallery
Re: Hangin' Weight
Originally Posted by 03f3507.3 View Post
That's exactly what I was thinking of doing. Mounting two recievers in where the tow hooks were so that I could take it off and put it on easily.
Did you have a problem with the end of the frame turning downards?
Yeah I was going to do it like that since it looked easy but it means I have to get rid of my fog lights. I'd rather not.
Any pictures though? I recall seeing it at the buck that one time but it's been a lil while.
Could you give a better picture or try to explain how this is attached to the frame? Do you have any pics of those mounts before you stuck them in the tow hook location?
  #7
Old 01-07-2009, 08:52 PM
RSieck's Avatar
RSieck
Offline
All Talk, No Walk?
Member's Gallery
Send a message via AIM to RSieck
Re: Hangin' Weight
I'll have to get some pics when I take mine off. I removed the front bumper, then the tow hooks. Then I removed the front bolt that connects the front leaf spring shackle to the frame. I then drilled a hole opposite of the hole that bolt was in, so I could stick a grade 8 bolt all the way through the frame. I used some 2x2x1/4" square stock and drilled a hole through that. Stuck it in the frame, and stuck a 1/2" grade 8 bolt thru the frame and square tubing, and bolted it solid. Slid the front bumper back on, then I used a piece of 4x4x1/2" angle iron to connect the 2 stubs sticking through the bumper. It was good enough to hold close to 1100lbs...
Mine looks really similar to the one above, except I don't use receiver hitches.
__________________
Early 99 PSD 4x4, Goerend Billet Tranny & Converter, GREEN
  #8
Old 01-07-2009, 11:05 PM
pontiacross's Avatar
pontiacross
Offline
OverFuelingForYourPlesure
Member's Gallery
Re: Hangin' Weight
I also used 2 reciever hitches on mine
__________________
Ross
2.6 modified street pulling truck "The Lone Stroke " 2011 season video!
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
  #9
Old 01-07-2009, 11:34 PM
OldschoolPSD's Avatar
OldschoolPSD
Offline
all ur OBS r belong to me
Member's Gallery
Send a message via MSN to OldschoolPSD
Re: Hangin' Weight
Marty if you want to fab something I'll give you a hand. I think I have a stick of 2" reciever material at the shop.
What kind of weights do you have? I have one that I built for my truck that will hang 1600lbs of the old style JD weights that could be modified, becuase I don't need it anymore.
__________________
Ford stopped building trucks in 1997
  #10
Old 01-08-2009, 12:44 AM
Powersmoker's Avatar
Powersmoker
Offline
10.61 @ 128 MPH
Member's Gallery
Send a message via AIM to Powersmoker
Re: Hangin' Weight
Mine did the same thing........twisted the bumper mounts. It was alright with 500lbs but when i decided to hang 1300lbs to the front it twisted it slightly.
__________________
2000 F-250 Regular Cab
1069 RWHP 1768 Torque
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
EVIL-DIESEL.COM
Murff Racing Twisted Diesel
Empire Diesel DieselSite
Swamps Diesel
(View-All Members who have read this thread : 121
"THE DEMIZE", '99superdutydually7.3, 03f3507.3, 03strokergavin, 04 stroker, 1badpsd, 85camaroman, 96 stroker, 99 7.3, 99F250Smitty, Bates, Big Bore, Big K, Binder man, BoomerL37, brandon_7, brianb7.3, bryan rittenhouse, bsdracing, chappy, Chrisf97305, CNDiesel, cntryboy17, cota, countryboyz04, Craneman, D2HP, daryl4412, Dave, David N, Dieselgeek, Doakster, DZL JIM, F-350, farm boy, farmboy99, FARMDSL, fordtch8, FORDTRANSTECH, fuzzys69, genie144, Got Diesel, hendershot, HMBUILDER4U2004, Holleran, hookin78, HotRodTractor, House, hutchnoclutch, IBESTROKEN, ironworker25, JakePSD, jdc753, JerrodGlover, JHill, jibmaster145, Jmannz25, Jngreen, jshank, kampinguru, kramarj, kyle43335, lildevil02, LRTMatt, lubeowner, Marty, mavricktoo, mazdaparts, Mbarrett, mcmullentrucks, mech2161, mflores, moore20017.3, morepower02, Moulder, Mudskiff, mustang_gt_350, NyCowboy87, OldschoolPSD, OVERSTROKED, P714, Pipewhiner, pontiacross, Powersmoker, powerstroke742008, PSDfan99, PSDTECH97, qcfarmer, red95psd, Rmartin-97, rnagel21, Rob02F350, rpm-inc, rrr, RSieck, screamin6.0, sea71, sick97psd1, silverbullet4x4, silverslug, sirnunya, smok531, SmokeWithEveryStroke, smokinndstrokin, smokyred, squeeks, Stroker96, StrokerTurbo7.3, Super_Hauler, suprdzlduty, tank, theSLEEPER, tkdbf350, truckpullin_75, UNLIMITED_DIESEL, zx800x
You may not post new threads
You may not post replies
Forum Jump
