| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Return lines & caps
Just got my new return lines and plastic caps today. Gona put them on tomorrow. Any suggestions on how to do them so the truck will start without cranking forever or am i pissin in the wind
__________________
I am probably the most hated person on here, and I don't care 97 CCSB 4WD DRW 7.3 5spd DP Tuner, 6637, Flo-Pro SS Exhaust, 99 I/C, T500, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, SD springs Front/rear 315/75/16s,
Bunch of other trucks |
| Sponsored Links | |
Advertisement |
#2
Re: Return lines & caps
Do like I said I replace everything then tighten everything back down. Then back the nut on the lines off just a hair. Hold the throttle to the floor & start cranking don't wait for the plugs. Crank for about 5 seconds give or take. Then get out & look at which lines have pushed out some fuel. With any luck all of em will have, tighten em all up & then repete the process. This time wait for the glow plugs & hold your foot on the throttle again. Soon as it starts & runs for a second you can back off the throttle but not all the way. 1/2 throttle or so kinda hard to explain you'll get a feel for it when you do it.
Main thing is you want to get the air out of the lines without killing your battreys & or starter. If you do it the way I described you might get luckey & get it in the first or second try. Main thing I guess is to have a feel for your truck & once you bleed the air out of the lines on a Diesel once or twice you'll get the hang of it.
__________________
#3
Would parking it facing down hill help any? I know it does for letting it sit for more than a couple of hours otherwise i loose my fuel prime. But i would like to squeas it in my garage to work on it not just in the drive
#4
I have no clue on that one, I did mine on a level surface so I donno if parking it on a hill would help it any. If she won't start on a level surface then there is some other issue that will need to be addressed.
#5
Well the theory behind parking it facing down hill is that the fuel will have to run uphill to bleed back to the tank when air is gettin into the fuel system at the engine. Should i lube the o rings w diesel fuel or will engine oil be ok?
#6
Engine oil is just fine, that's what I used on mine. Just make sure you get both O rings on the injectors.
#7
10-4
#8
Where do the copper washers go that came w the kit go? On the fuel lines where they go into the pump? And the fuel line coming out of/into? the fuel filter housing is wet. I already tried tightening it last week but it is still leaking. Does a copper washer go in there?
#9
What kit do you have....Dipaco...Interstate mcbee? If there's 8 coppers they go on the injector tips.
__________________
2001 F-250 handshaker #54 Stealth HPOPs Alliant ACs Forged rods with other junk to make it work Thanks to TDP, BDP, RDS, PHP and TDGrp |
#10
.Now i'll just have to let it sit over night to see how she starts. O and after closer inspection my return lines were dry and cracked. O-rings and caps looked good but all got replaced |
(View-All)
Members who have read this thread : 66
| 1995powerstroke, 220Swift, 6literpowerstroke, 94f250turbooo, abianca99, arctic-20v, artfd, azrich487, bean, Big Bore, Big Del, big jake, Black Beauty 7.3, Bobus, Cheeze, cory99, Diesel Avenger, DieselPower1966, diesel_brad, Doakster, DOGRUNNER, doubleshot, dzlstroker, Etcetera, F-350, farm1066, fbilly420, Fordpowered, gracing, harleyguy13, Holleran, Hyde, itsme, Jake N, jason mondy, jdc753, jensenciv10, jpd78, jumpvideo, kkpsiguy, lainemech, Longdrive, LRTMatt, mrfister11, my97stroker, powerstroke742008, pullths, racerx103, retired jeeper, Reubine, Sharpshooter77, silverslug, smokin86, smokinndstrokin, snapon66, Stiletto6.0, tank, thephenom60, Tim4, toolmangary, treyloco, vapstroke, willholl79 |
| Thread Tools | |
| Display Modes | |
