7.3 injector problem or bad fuel?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 11-01-2008, 12:41 PM
crazycruz257's Avatar
crazycruz257
Offline
Member's Gallery
O.K. I have a 2000 Ford rollback tow truck with a 7.3 Powerstroke. I just replace the injectors about a month ago and the truck was running sweet. I fueled up thursday night out of town. Come friday the truck had a very strong fuel smell when running. By friday night 1/2 to 3/4 of a tank of fuel later the truck was smoking real bad and sounded like it was missing at idle. On the highway it runs like a top. Shut the truck off for a few minutes and it has a catch when you turn it over. Like the injector is stuck open and dripping fuel in the cylinder. We put it on the scanner and it says the #8 injector is bad. Now my questions are: Did I get some bad fuel and clog the injector to where it is stuck open? Or Do I maybe have a defective injector that is shorted and staying open? And how could I tell? If it is clogged and stuck open is there a way to clean it? Thanks in advance.
Later Cruz
Old 11-01-2008, 12:46 PM
Arisley's Avatar
Arisley
Offline
All done now
Member's Gallery
Re: 7.3 injector problem or bad fuel??
Welcome to the Nation!
Not real up on injectors, others are and will be on shortly.
I think I would start by pulling the injector and looking at o rings.
__________________
  #3
Old 11-02-2008, 02:38 AM
smokyred's Avatar
smokyred
Offline
What else?
Member's Gallery
#8 is driver's side-rear, check the wiring and if it's OK, pull the injector out and see if the o-rings are OK. If they are good you may have an internal injector problem.
Dave
__________________
DD- '01 2500HD Dmax/Alli Starlite DSP5
Play truck- '08 F250 6.4/Torqshift Spartan 310EL, Flo-Pro 4", White_monster air intake, RCD 4-link, RS9000's
No Limit cold side pipe and EGR delete in the mail
My Pictures
  #4
Old 11-02-2008, 03:47 AM
POWERSTROKER's Avatar
POWERSTROKER
Offline
Member's Gallery
Swap #8 with 2,4, or 6, if the problem stays at #8 you have a wiring issue, if the problem follows #8 injector replace it.
__________________
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by Gearhead Automotive Performance
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
http://www.dieselpowerproducts.com/
  #5
Old 11-04-2008, 02:32 AM
smokyred's Avatar
smokyred
Offline
What else?
Member's Gallery
I should have said that, lol. Also after you find and fix the problem, replace the o-rings on the injectors you pulled out, they are not generally re-usable.
Dave
(View-All Members who have read this thread : 89
02F350, 73stroke99, 84crewcab, aklim, AMB, Arisley, bamcbrideusmc, beaux, Big Chuck, bigd4me2, BigTXForddiesel, big_country1967, birdog, BlackPearl03, boggerr, Brian918, bryan.d, Bushwakd, casper7.3, ccsimpson, chris1978, Chuck550HD, colekym, cota, crazycruz257, crowz, davecobra, davey99ps, DHDiesel73, don2510, f250power, FAAST, Fordguy26, golfer, Gregch, have12, HunterP, JACKASS, jake2far, jaysonmore, Jgman141, Joedog, JSchuricht, ju015dd, kilapapipa, krankin, lep, lght1, LiftedLariat, Longdrive, LongGun_LeRoy, Lumpy, mandkole, mattrac, maxtrax, Mayday, mbbling, MilitiaMt, mostrokin, Mr. Jimmy, Powersmoker, PSDfan99, redclayfarmer, ren2094, Riley250, Ripsaw, Rogue1970, s.janks, shaddaddi, smokyred, stackedstroker, star73, tank23, Tater, Tazag01, tienanh4m, toddg, trenner101, trimacwest, turbocat1000, upinsmoke70, Wiggie, wooner, zack179
You may not post new threads
You may not post replies
Forum Jump
