HELP PLEASE, no boost,black smoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 09-03-2008, 02:26 AM
2kstroker
Offline
Member's Gallery
Had an oil leak from turbo pedestal.Replaced 4 o'rings. Engine started and runs OK,except when I push it. There is almost no boost 0-2 #(on the boost gauge)and a lot of blackish,brown smoke. What did I do wrong?It all went back together OK no extra parts.Please help,I'm open to all sugestions
Thanks
Old 09-03-2008, 02:30 AM
Logan21SV's Avatar
Logan21SV
Offline
Sponsor
Member's Gallery
Re: HELP PLEASE, no boost,black smoke
IC boots, Red rag in Intake, Red rag in IC tube. Can you hear the turbo?
__________________
CenTexDiesel.com
Logan Schneider
830-885-6500
  #3
Old 09-03-2008, 02:43 AM
POWERSTROKER's Avatar
POWERSTROKER
Offline
Member's Gallery
Make sure all your clamps are tight.
Did you replace the o-ring where the compressor meets the intake spider?
__________________
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by Gearhead Automotive Performance
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
http://www.dieselpowerproducts.com/
  #4
Old 09-03-2008, 02:49 AM
2kstroker
Offline
Member's Gallery
I took off the IC tubes,clear.I flushed water thru the intercooler,it flowed good,then blew out with hot pipe connected and cold pipe disconnected at intercooler started engine to blow out excess water. If a rag is in the IC,how can I get it out?
Thanks for replying
  #5
Old 09-03-2008, 02:57 AM
2kstroker
Offline
Member's Gallery
I went over the entire system,rechecking all connectors,clamps,but I did not replace the large o'ring,it seemed OK,I don't think it could create my problem.My first inclination,was,that I left a rag in the IC pipe.That is why I took it all apart.
  #6
Old 09-03-2008, 02:59 AM
POWERSTROKER
Offline
Member's Gallery
Did you put the red line back on the wastegate?
Did you hook the rod back onto the EBPV?
  #7
Old 09-03-2008, 04:03 AM
Logan21SV's Avatar
Logan21SV
Offline
Sponsor
Member's Gallery
Did you put red rags on top of the heads? maybe put the spyder down without taking one out?
  #8
Old 09-03-2008, 06:29 PM
fbilly420's Avatar
fbilly420
Offline
Member's Gallery
Is the collector securly attached to the back side of the turbo?
__________________
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
  #9
Old 09-04-2008, 03:57 AM
2kstroker
Offline
Member's Gallery
You guys are alright.Thanks for all the replies.I'll go over it again,starting with the collector to turbo and clamp.
Thanks again
  #10
Old 09-05-2008, 03:04 AM
2kstroker
Offline
Member's Gallery
With all the replies,I found the problem.The actuator arm came off the waste gate valve pin.
Thanks again, to all who replied
(View-All Members who have read this thread : 66
0373, 2kstroker, 97PSD350, 99coalroller, 99F250Smitty, alumguy, Arisley, bigd4me2, BigRed97, big_stroker, BMac, BoilermakerSteve, brandon_7, c125bob, chewbacca, crowz, Dantheman, Deepsky3539, Deputydog, Dieselfever, Dieselgeek, doubledoor, ELKHUNTER, F-DuceFifty, fastco5, fbilly420, Firedogbme, fishinfool98, golfer, Greg373, Haul_n_horses2, JimTJr, kyle@DI, Logan21SV, Martin #6, matthewd11, mattrac, muddy_one, newmexicocrawler, PHPDiesel, Ramblin'_Man, rconcrete, redmist, rocketron, Rockrunner86, Rogue1970, rpm-inc, S&RTransport, sagebel, sirnunya, spb_2006, Stiletto6.0, Stites02psd, straitcountry, stroker99, StrokerTurbo7.3, stroketeck, SUPERDF350, theSLEEPER, Thuglike, tienanh4m, TrailerHauler, urbanwheeler, Wheels
You may not post new threads
You may not post replies
Forum Jump
