Fuel mileage mods? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 7.3L Power Stroke - Aftermarket & Performance
Thread Tools Display Modes
  #1
Old 01-29-2013, 04:25 PM
jimmyfunk60
Offline
Member's Gallery
Fuel mileage mods?
What's the best fuel mileage mods for an 03 7.3 crew can diesel with auto tranny and 4x4 I'm getting 13-14 mpg now and got 18 out if my 250 6speed.
Old 01-29-2013, 05:29 PM
7.3's Avatar
7.3
Online
I'm A Beast
Member's Gallery
Re: Fuel mileage mods?
manuals get better mpg. keep lockouts unlocked. lighter foot. intake may help a little. exhaust may help a little. a good tuner with eco tune help a bit. keep tires psi higher, 70-80. check your wheel bearings and grease the needle bearings. Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page dont haul around unnecessary things. summer your mpg will go back up.
  #3
Old 01-29-2013, 06:09 PM
Clarence_Carter
Offline
Member's Gallery
There's a whole sub-forum on mileage.
MPG - Fuel Economy Discussion - PowerStrokeNation : Ford Powerstroke Diesel Forum
13-14 mpg sounds fairly good for a crew cab dually. A manual trans is more fuel efficient and was your F250 a crew cab? Adding cab size increases weight. Dual rears increases rolling resistance. I'm far from expert, but I hope the mpg forum helps.
__________________
'00 F350 LBCC DRW 4X4 with Spectre filter, muff delete. TS 6 pos chip in hand (Not in truck). In-bed fuel tank. 480 K miles on truck, 180K on current engine. Former FEMA hauler. Gooseneck ball and 16K 5th hitch. Has the pump and controls for air-bags, but no bags.(yet)
  #4
Old 01-29-2013, 06:13 PM
cntryboy17's Avatar
cntryboy17
Offline
Member's Gallery
Fuel mileage is for cars if you want mileage don't drive a truck
Sent from my SAMSUNG-SGH-I847 using AutoGuide.Com Free App
__________________
E99 F-350 CCSB 4x4
1990 F250 7.3idi 4x4 5 speed- SOLD!
  #5
Old 01-29-2013, 08:36 PM
southmike's Avatar
southmike
Offline
Village Idiot
Member's Gallery
1st check for boost leaks, google ebpv sensor clean..actually it is the line off the manifold that gets clogged as a start.
__________________
  #6
Old 01-29-2013, 08:39 PM
countryboyrob
Offline
Member's Gallery
Agreed
  #7
Old 01-29-2013, 09:11 PM
jaybuller's Avatar
jaybuller
Offline
Member's Gallery
Naw ww, these things can get decent mpg too....I can get over 20 with my 7.3 6 speed truck. Just drive it like grandpa! But realistically I normally get 17 to 18..... I think if you get 16 in your dually you'll be doing good though. But like already stated winter mpg will normally be a mpg or 2 less
__________________
2000 f250 ECSB, 4x4 7.3 zf6, 150k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, unlimited 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling 15k through the mountains.
  #8
Old 01-30-2013, 01:04 PM
7.3's Avatar
7.3
Online
I'm A Beast
Member's Gallery
oh so we should just settle with the mileage it gets and not try to increase that at all? well why try to make more power out of your truck then? it makes so much factory, deal with it.
  #9
Old 01-30-2013, 04:42 PM
jaybuller's Avatar
jaybuller
Offline
Member's Gallery
these trucks are pretty much set to go from the factory the best for mpg. you could stick skinnier tires on there, re gear to 3.08s or put a gear vendors overdrive on there. but as far as engine mods these things are good to go mpg wise. rolling resisstance improvments(free spin kit, skinny tires) and wieght reduction(tires, rims, uneeded items in truck run half tank of fuel instead of full) will get you the most results.
  #10
Old 01-30-2013, 06:57 PM
kilapapipa's Avatar
kilapapipa
Offline
Old Yeller, REBORN
Member's Gallery
There is a hell of a lot more room to increase power than there is to improve mileage.
__________________
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
(View-All Members who have read this thread : 128
02powerstrokeguy, 1982atm, 1996f250xlt, 19stroker97, 2000f350v10, 2dedge, 53fordguy, 7.3, 94youngturbo, adrianmedina1987, ArmyGuy45, bddmax, becareless06, benbrink20, bergpsd, beyondlogic, big nasty, BIGLARRYS03, biostroke1, Biscayne, BlackBettyzPimp, Blackbullet73, BlackHogDown, Blake Williford, Bob K, Borncountryboy, BRAVO, Breacher, bruce51d, BucktownPSD, Buford-61, burger318, cabloom7.3, caleb90, centralmax, cheysays7.3!, childinplay420, Clarence_Carter, Cloverleaffarm, cntryboy17, Cowboyup, crawlake, Custerpsd, Cutty72, dan-devries, dieselman81, DieselX, dspowerstroke, ewxlt, F250DieselQUEEN, farmall99, ford0220, ford4life76, fordguy2, Fordguy26, fr0stbytten, GCncsuHD, Gibrid4x4, golfer, greanbeans, grecoface, Greg, Greggenstein, harleytruck3392, haulin2000, hoist00, honda68, hunter scar, ironworker40, jaybuller, jbrixen, JCart, Jellyroll22, jimmyfunk60, JohndeereClyde, Jonesky, jopes, juvenile9, KCMEADOWS, ken6881, kenord, KenV, kilapapipa, LANCE105010, leechapple22, leoneo01, loc712, Locknload00, Luke909, maritimer10, maverik2711, meat, Nickderky, Notalent, PETERC, Platinum Crew, PowerSTOKED_Bryan, powerstrokefreak101, printzjd, PSDBrian, raptor, Redrock2000, rfrostick, rickvm, Right seat driver, sargentdan, SeeYa, sgtchadgreen, sinister dave, sinnful_46534, slingshot, smokin99stroke, Sneezy Beltran, southmike, Spoolen&Smoken, stickandtin, Stroker12691, Strokerdog, SVTSkip, towsurfer, Treyspooner65, trolling2, true98jeep, wicked027.3, wildbillcody97, xChrisHx
You may not post new threads
You may not post replies
Forum Jump
