Egr Delete and Intake Elbow - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.4L Power Stroke - Aftermarket & Performance
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 12-10-2012, 05:06 PM
jeepnfool's Avatar
jeepnfool
Offline
Member's Gallery
OK, question is, why the elbow and is it worth it? I can get the block off kit for more than 100.00 cheaper, so what justifies the elbow?
__________________
2009 F250 SC 4X4 W/ Newton Lift
H&S Mini Max w/ 5" FLOPRO Turbo Back
Full EGR Delete w/ Elbow
AFE CAI
17x8 XD Spy's Wrapped in 35x12.50x17 General Grabber AT2's
Old 12-10-2012, 06:27 PM
powerstroke6.4's Avatar
powerstroke6.4
Offline
Member's Gallery
Re: Egr Delete and Intake Elbow
Just a little better flow compared to the stock elbow. Also cleans up the engine bay a little. I didn't notice any difference because I originally had the kit without the elbow and later purchased the elbow separately. If I was to do it again I would have just got the one with the elbow.
__________________
2008 F350 JOB 1
H&S MINI MAXX
HD300 W/S1M
SINISTER EGR/COOLER DELETE
5000LB AIR LIFT AIR BAGS
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD HOSS WHEELS W/35X12.5R20 NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
  #3
Old 12-10-2012, 07:50 PM
bluedura
Offline
Member's Gallery
do the full delete with elbow.... the egr/throttle plate housing is a gunked up mess the elbow looks clean and flows better!
__________________
kem tuned,4"downpipe to 5" back,cac pipe and elbow,dpf&egr delete,arp studs,ported intake,110 nozzles,diesel Dr. dual k16 airdog,2.5 level,bmf novacanes 35" trail grapplers
  #4
Old 12-10-2012, 09:11 PM
one2nine's Avatar
one2nine
Offline
Member's Gallery
^^^^ whs. Do a full delete including the coolers and egr housing.
__________________
2010 F250 CCSB - 73mm atmo, II pump, 60% nozzles, no limits intake, etc - sold
  #5
Old 12-10-2012, 11:04 PM
jeepnfool's Avatar
jeepnfool
Offline
Member's Gallery
So your saying you would spend an extra 140 and not have a performance gain? I understand people want it to look good, but I really dont see the benefit other than looks, which I really dont care about. Im thinking it can be removed and cleaned. After that, it wont gum up again since what is causing it is removed..
  #6
Old 12-10-2012, 11:39 PM
jeepnfool's Avatar
jeepnfool
Offline
Member's Gallery
Ok, so I bought the entire kit, delete and elbow. I was able to get it all for $207 shipped...
  #7
Old 12-10-2012, 11:47 PM
one2nine's Avatar
one2nine
Offline
Member's Gallery
You would spend hours disassembling and cleaning an egr valve. Going with the elbow is the right call to make.
  #8
Old 12-11-2012, 01:16 AM
riemer's Avatar
riemer
Offline
Member's Gallery
What kit and where'd you order it from? I need to get this on my truck. Also are you updating the tunes since your deleting the egr? I have an SCT with IDP and already have the EGR set as off, but was told tunes still needed upgraded.
  #9
Old 12-11-2012, 01:52 AM
bluedura
Offline
Member's Gallery
You may run into cruise control not working with the elbow,I did but kem mike too care if that in minutes no big deal, maybe someone else can chime in on how it works with other tuners, good choice on purchase!
  #10
Old 12-11-2012, 02:26 AM
powerstroke6.4
Offline
Member's Gallery
There probably is a performance gain, it is more than likely a fairly small gain but just to be able to clean up the engine bay a little is worth it. As for the cleaning like one2nine said, cleaning up the stock elbow would probably take alot of work not to mention the possibility of breaking the valve when you take it apart.
(View-All Members who have read this thread : 133
03sixspeed, 04fatboy, 08ford4me, 1slosvt, 2003ford, 3brorce, 98stratusryder, aircooled, AKpowerstroke, alexd, allblack08, ARCTICCAT, B585Ford, badlands, BIGBLUEFX4, Bigdiezel, bigharleyb, BigRedBlackSmoke, BillyBob427, biostroke1, bjmunderwater, Black 4.6 Beast, blaled, blkwrx, bluedura, boli714, Brahmus, brianwcooper, BritishGunner, Buford93, caleb90, Chris's Dually, Chuggins10, Clrsnow, colfaxent, Custerpsd, Da Oops, Deere8420, deereman, Diesel-1, DieselDZ, Dieslnevan2009, Diver86er, doc175, Eric@PTP, firedog23, Force2354, fordforever96, frusteri4, FullerF250, gearhead919, gmoney284, Goatro, hanleyj, hdstroker1450, HECTOR-BDPOWER, Humvette, injected79, InMotionJosh, jacmurr, jasensmith, jeepnfool, jgon08, JMG_361, Jmn111080, Joedarr33, joshua5438, Jtpappy6.4, Just1MoreTime, KB3MMX, KCMEADOWS, KR69IDI, kudzu, LABMAN, LowDog63, lubeowner, lxcoupe, mamadiga, matt_m73, maverik2711, maxharley, mclane187, MFD T-3, MrMike06, N2Lake, nickw226, nspock, one2nine, Pan4905, pooter, Powerstroke526, powerstroke6.4, powerstrokin104, ppmcevoy, Razzer, riemer, RJC2, Robs94z, Rook, rstan2010, RT-Angel Fire, savn47, Sawed Off, SD08, shafer171, shmokenpstroke, SickStroke6.0, Sigster, skobiak, Smokem, snorider99, Sparky351, spartan stroker, speedkills502, steelhorse08, stik, STR8TORQUE, stroke4fun, stroked99_1/2, teampfr2200, thedudes82, theSLEEPER, tryinforaford, TX_S, Uncle Buck, WERA, White_monster, Willis, wispy, woodking, wp3223, xltsp580, Zippys F350
You may not post new threads
You may not post replies
Forum Jump
