loud air sucking sound and loss of power - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 11-06-2012, 12:06 AM
Rustymx11
Offline
Member's Gallery
lately ive been noticing my coolant level keeps dropping, and i keep having to add coolant. Ill fill up the degas bottle, then about a week later it will be bone dry. the truck is egr deleted and studded, so im not sure what the problem could be. any ideas? next issue. a couple weeks back i was at a stoplight, and when i took off i layed on it real hard and usually it'll light up the tires and have plenty of power, but i noticed a loud air sucking sound, and an extreme loss of power. I checked it out and noticed an intercooler tube rubber boot was cracked, so i replaced it and it seemed to fix it. I did another hard take off today and noticed the air sucking and loss of power once again, but all the boots are tightened down, and nothing looks to be out of place. Im stumped. Any help would be real appreciated!
__________________
Arp Head Studs, Sinister Egr Delete, Sinister Coolant filtration system, 6.4 banjo bolts, Blue spring upgrade, alliant water pump OEM head gaskets, 4in mbrp exhaust, Harley davidson front end, Nitto 420s.
Reply With Quote Quick reply to this message Go to the top
Old 11-06-2012, 12:09 AM
Snake's Avatar
Snake
Offline
40 lug nuts
Member's Gallery
Re: loud air sucking sound and loss of power
First thing I'd recommend is figuring out where your coolant is going. Is it leaking or is it being burned?
Second thing I'd recommend is not to run your truck hard until you have the issues fixed, starting with your coolant loss. How long ago were the head studs installed?
The sucking sound may be a cracked intercooler.
  #3
Old 11-06-2012, 12:27 AM
Rustymx11
Offline
Member's Gallery
Im really not positive on the coolant part. a few weeks back it was smoking what looked like blueish white smoke on take offs, so i figured it was a bad turbo seal. I tore the turbo apart and sure enough it was leaking real bad so i replaced all the seals and put it back on the truck, and it definately lowered the amount of smoke on take offs, but did not fix the problem, so im starting to think it could possibly be coolant being burnt out as well? I studded it about 6 months ago, and i used the factory ford head gaskets, and had the heads machined as well, so i dont think it could be a blown headgasket, i would figure it would be smoking much more if that was the case.
  #4
Old 11-06-2012, 12:34 AM
John Martens's Avatar
John Martens
Offline
Justaworktruck
Member's Gallery
Dont know what your problem will be, however our 2009 6.4l also got heads studded 2 months ago, and then not long after it had the same issues, when pull out to pass it was a white cloud for about a mile. The motor gave out 2 weeks ago and truck is still sitting on trailer. STAY close to home. It will not last long. We believe our motor is gone, maybe you can still fix yours.
__________________
Pullinweight
  #5
Old 11-06-2012, 01:34 AM
ServiceTech's Avatar
ServiceTech
Online
hell nah it aint studded
Member's Gallery
blueish smoke is oil burning. if you are loosing coolant and have blueish smoke, i would pull the dipstick and see if you are mixing coolant and oil. if you are mixing....... i would say its n oil cooler. as for the loss of power, im not sure at this point. keep us posted on this man, thanks
__________________
2006 F250 CC SB FX4 6.0L
If you do not want to register, fill this field only and the name will be used as user name for your post.
Human Verification
(View-All Members who have read this thread : 37
'94IDITurbo7.3, 6keeper, 7.3PowerStroke602, amdriven2liv, baggedbug, bf9412, bismic1, caleb90, coolvette, dauntejoel, dieseltech11, ghohouston, gpolenik, Harley Strokin', hustler315, jjdup, John Martens, KCMEADOWS, kystroker99, lsteffen13, mastrkee, miller45103, mxned, PwRsTrKe8907, Rustymx11, seanmesaeh, ServiceTech, sga6.0l, Six Liter, smergen, Snake, sonnyy13n, sootman73, Steel Maverick, Tjackson, webb06, Wheelhop
Forum Jump
