3.55s or 3.73s - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.4L Power Stroke - Technical Info
Thread Tools Display Modes
  #1
Old 08-18-2008, 07:22 PM
Tedb
Offline
Member's Gallery
3.55s or 3.73s
What are you uys running and wich do you think would be the best with torqshift powerstroke combo. I am sure the 3.55s would be a little better for mileage but not sure how the would be with the auto transmission.
Thanks
Ted
__________________
2001 F350
SC LB SRW
Auto 4x4
Old 08-18-2008, 07:49 PM
LRTMatt's Avatar
LRTMatt
Offline
Village Idiot
Member's Gallery
Re: 3.55s or 3.73s
If you have the 20" tires the 3.55 will not give better economy and will be a gutless wonder. The 3.73s are plenty enough with the taller tire. Actually the height difference of the 20" wheels/tires makes the 3.73 act exactly like 3.55 gears with stock sized tires.
If you are only looking at 17 or 18" wheels then the 3.55 won't be too bad to deal with unless you tow at maximum GVWR.
  #3
Old 08-18-2008, 08:43 PM
slowleak
Offline
Member's Gallery
Re: 3.55s or 3.73s
just curious, what would rim size have to do with gearing?
__________________
PMRCM#1
  #4
Old 08-18-2008, 08:48 PM
1999F350's Avatar
1999F350
Offline
Member's Gallery
Send a message via Yahoo to 1999F350
Re: 3.55s or 3.73s
rim size doesnt matter tire diameter does.
__________________
1999.5 F350 XLT EXT CAB AUTO 4X4,K&N W/6037, DPF5,HIGH IDLE,80T,80E,120R,140BOOSTFOOLER,PHANTOM2 GAUGES BOOST,TRANS, EGT,CUSTOM 4R100 W/ JWVB,BILLET HARD PARTS,427LINE,RACERX PARTS,BD PAN,6.0 COOLER,DETROIT TRU TRAC,3.73,VAN TURBO W/ATS&HIFLO OUTLET,4" STRAIT PIPE,AFE INTAKE MAN,140V IDM,325/60/20 NITTOS,2.5"LEVELKIT,OPTIMA'S,PIONEER DVD/NAV
  #5
Old 08-18-2008, 09:16 PM
Tedb
Offline
Member's Gallery
Re: 3.55s or 3.73s
I was just curious if anyone had any experience with either setup on an 08. I understand how the ratios are affected by tire size. I guess wheel and tire weight may affect power and mileage also. I just figured that with the power of the 6.4 3.55s would be the way to go. We have a 97 5speed with 3.55s and it will do about anything you need it to. Just keep it out of OD once you get it rolling with a heavy load.
Ted
  #6
Old 08-18-2008, 10:25 PM
Cat_Rebel's Avatar
Cat_Rebel
Offline
OBS junkie
Member's Gallery
Re: 3.55s or 3.73s
I don't think you can order a new truck with 3.55s so it would have to be swapped. Assuming 4x4 that means front & rear ring & pinion = not really cheap. A 3.73 to a 3.55 isn't too much diffrent like a 4.10 or 4.56 is to a 3.55 gear. Nice thing about 3.73s too is thaty you can tow alot, run larger tires & still get good MPG.
__________________
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
  #7
Old 08-18-2008, 10:35 PM
skylinedan's Avatar
skylinedan
Offline
< pissed off pumkin.
Member's Gallery
Talking Re: 3.55s or 3.73s
A 3.55 would.nt be a bad combo considering the 5 auto has a slightly lower first gear, but if you tow I would go with the 3.73 any day. I have driven 3.73 and 4.10 s both and I will take a 3.73 over them all. with the 3.73s if I have to drop to drive I,m not killing the motor like the 4.10 does. You will pull harder from a stop with the 4.10 , but I think your millage is gonna be better with a 3.73 over all with stock hight tires.
Dan
__________________
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, bellowed up pipes, CFM + spyder conversion, DP tuned, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, fuel bowel deleat, and twin pumps on the way.
  #8
Old 08-19-2008, 02:39 AM
POWERSTROKER's Avatar
POWERSTROKER
Offline
Member's Gallery
Re: 3.55s or 3.73s
I've heard of a few guys getting 18+ with the 3.55's, as said above the Torque shift tranny does have a lower first gear, so unless this is gonna be tow truck more than a DD, the 3.55's should be just fine.
__________________
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by Gearhead Automotive Performance
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
http://www.dieselpowerproducts.com/
  #9
Old 08-19-2008, 11:55 AM
LRTMatt's Avatar
LRTMatt
Offline
Village Idiot
Member's Gallery
Re: 3.55s or 3.73s
The rim itself has nothing to do with it but the size of the tire placed on those rims at the factory is a huge factor!
Cat, the 6.4 trucks are available with 3.55s now. Ford went to that option in an attempt to help with the fuel economy complaints everybody has about the 6.4s.
  #10
Old 08-19-2008, 01:43 PM
F350DRW1's Avatar
F350DRW1
Offline
Darwin was right
Member's Gallery
Re: 3.55s or 3.73s
They are coming STOCK with 3.55's. Job 3. No need to order. Its a Ford band-aid to try and get the mileage up.
__________________
This space for rent
(View-All Members who have read this thread : 204
06TWO50Diesel, 08keith, 12v Ford, 1999F350, 2glamis, 2x6 bulldog, 4xton, 96 F-450, 96 stroker, 96centurion, 99350sd, 99coalroller, Aaron S, ADubDiesel, aggie, austin229, Bartman, BCPowerstroke, bhamm557, BigBluePwrStroke, bigd4me2, bigfords, BKB, BMac, Boats313, Brown Dog, BUFF, Bugman, cantrellc123, caseih7010, caspower, cat45, celjel, CGMKCM, Charles, chrisreedtn, Chuck B., clayc_989, clydesdale, Colorado, countryboyz04, crowz, Dave, dblamp, dc3655, DcMoore999, DeadBlow, deadbug, Deaththree, Deereman4020, Demolition, desertwheeler, Dewser, dfghgfhj, Dieseltron, dubswyoming, dudshep31, DYLAN6959, E-Man, e444, ELKHUNTER, eric.davis, ert0360, EverettWV, F-350, F350DRW1, F350Powerhouse, fbilly420, FL_Smokin_PSD, Ford Parts, FORD08(4X4), ford7.3sd, fordpowerf450, fordtrucksrule7, frashdog, geared_low550, gfdrb1946, GMAN1, gnxtc2, golfer, greenlion, Griz, gtmustang00, Harohunter, hawkeye, HiVoltage, Holleran, InMotionJosh, island8, JAE88, jason812, Java, jawbrkr22, JAYB1RD, JD Dearden, jdabnabe, jello, jim 1156, jlegg, Jngreen, joediesle, Joedog, john, John Rambo, John_DeereGreen, jonathan734, jschildm, kkpsiguy, krankin, KrayzKajun, kurtfromct, Layson, lilredranger, lownslow, LRTMatt, mabracing, MADMAN36, makaveli200369, Martin #6, MidTennPSD, MILFORD, Millheim, mjones, Mooring Product, morepower02, MSdiesel83, MSTR-P, nchappy, nitrogen, NyCowboy87, OFarrell, olblue, old man dave, ParkerFly, PGreenSVT, Plumbnman, procomp, ProF100, PSDfan99, RacerPuller, Rbloodhound, rebelchevy02, RedBull_04, Redfish, redracer62, retired jeeper, RockinJW, rock_doctor, RSP, Rustler, rusty1161, Saber123316, Sader, sagebel, SAK, SEOHPowerstroke, ShogunRider, Shredz77, sick97psd1, sikpig, SilverDiesel08, sirnunya, SKIRK, skylinedan, sled hauler, sledneck57, slowleak, smokyred, snipeallevil, southern boy, squeak12, stevens669, Stites02psd, Strictly Diesel, Stroked383, StrokerTurbo7.3, strokin6.0, superdutyfarmer, surveyor13, swalker, Tail_gunner, tch.280, Tedb, Tedzz, The Oiler, TheDirt, tholt34, TomzToyz2, Tre Strokes, TRX370r, urbanwheeler, wbigcount, wheat, Wheels, xray88
You may not post new threads
You may not post replies
Forum Jump
