| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Load ratings- I need help!
I am shopping for new tires. I am upgrading from a 16.5 rim to a 17x9" Raceline Raptor.
Here is my huge problem. I have done TONS of research on the load ratings and have come to this understanding. Load ratings: C- 6 ply D- 8 ply E- 10 ply sidewalls My problem is that every tire that I find in a 40" tire (the size I want), every single tire is a C load rating, which, in my research, everyone says that is unacceptable to put on a truck as big as mine (95 Ford F350 Crew cab long bed Diesel) So what do I do? Are these C rated tires okay because of the bigger tire size? I haven't found an E rated tire yet in a 40" tire size. If I have to stay at a 38" tire to have an E rated tire I would be okay with that, but I want to go to a 40" tire. Also it has to be a radial with good reviews regarding tread wear and good ride. Any recommendations or help? |
| Sponsored Links | |
Advertisement |
#2
Re: Load ratings- I need help!
Do you tow with your truck or is it more street driven with towing say a boat or car trailer on occasion? If it is the latter then you will be fine with the 40" tires in a C rating. If you tow heavy then I don't recommend it as you could overheat the tires due to too much load on them causing them to fail.
__________________
97 F-350 XLT CC DRW 4X4 PSD, 285/75-16 Custom bumpers, Gauges-boost/egt/trans, Swamps IDM, 3.5"dp- 4" exh., 3" Body lift, ES bushings/mounts, Built trans, billet conv, B&M pan, Hayden cooler, Adrenaline, stage 2's, IC, H2E, E-fuel ARP's, 910's, Smith Bros. to come |
#3
I don't tow much at all, and it is mainly street driven. However, I wanted to be able to tow if and when I wanted to.
#4
Also I thought a C rated tire would wear faster than an E rated tire?
#5
Load and compound rating are two different ratings.
__________________
96 cclb f350. idm mod, gauges-boost/pyro/trans temp afe stage 2 intake dp to 4" straight pipe studs, springs, pushrods srp1 intercooler electric fuel convertion 238/100 dp-tuner f6 |
#6
Look at the actual weight ratings of the tires you're interested in instead of the C,D,E thing. Sometimes an eight ply tire will have a higher weight rating than a ten ply tire, depending on the materials it's made of.
I wouldn't be concerned with it if you're not towing. |
#7
17's n 40's? To each his own...
__________________
1997 eclb xlt. 4" roughcountry 305 70 16 a/t Tymar intake, 5" turbo back, ts6 chip. 1985 mustang gt four eye hatch. Edelbrock h/c/i/c. 1992 toyota corolla. Beater/economy car 2005 ford escape |
#8
i run 40's on 18" wheel and load rating is D maybe odd size wheel size your looking at
__________________
1989 F350 7.3L PSD Crew Cab Long Bed 4x4 6" Lift 37" Military Wranglers _________ 04 F350 6.0L SD Crew Cab Long Bed 4x4 8" Donahoe Suspension Lift 40" Pro-comp X terrain |
#9
__________________
Jake Brown 1995 Ford F-350 4x4 CCLB, ZF5, Solid mass Flywheel, Banks Technicooler, DYI 6637, 3in downpipe, 5in exhaust, Isspro Gauges, MORE TO COME |
#10
those c rated tires are no were near strong enough for your truck, regardless if you tow or not.
__________________
1994 F-250, 7.3L IDI Factory Turbo, E4OD, 4.10 LS, XLT, SCLB, 2WD |
(View-All)
Members who have read this thread : 74
| '94IDITurbo7.3, 1997Fummins, 19stroker97, 444CuiOBS, 6.9performance, 7.3L F-250, 89 Stroker, 95PwrStrk, 96powerstroke96, 96P_Stroke4x4, 97-7.3powerstroke, 97supercab, Believer45, Bigdog, biggreen96, blackf250, bracketracer, Centxdiesel, csp, dalejrfan88, danielzink, david tx, diesel_brad, Dirtyboy82, dlmater, dragonboi, drkndzl22, dupee426, eleventhtruck, EverettWV, ezygo, Futchgator, geared_low550, gnxtc2, Greger96obs, gsxr1216, Hijo202, jbrixen, jerry k, jestersv, JSchuricht, LBF, leojr, LiftedREDStroker, madpogue, MB97PSD, MustangMatt96GT, mxredneck, mz2152, nickeagle, Nodge, OBSpstroke97, old man dave, old Smokey, oldfordisbetter, Otter70, psdmike, PsRumors, Richardi503, rusty1161, sargepep56, sdm, sg465, Shovel, Smash Fascism, speeddemon31176, threestud, TNR, twentyfootdaredevil, wannabstrokin, wildstang, woodking, zabeard |
| Thread Tools | |
| Display Modes | |
