PLEASE HELP!!! E99 ROUGH IDLE NO POWER - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 10-27-2012, 02:36 AM
broncocarnage
Offline
Member's Gallery
I have a early 99 and yesterday i was driving and all of a sudden it started running rough the check engine light came on and it died. i cycled the key and it fired right up. it runnin real rough and has no power. so far i have changed the fuel filter, buzz tested fine and has 45 pounds of fuel pressure at idle @ 500rpm. im also getting code p1668.. i have read it mat be gem module, what is a gem module? whats your thoughts?
__________________
TOW RIG
early 99 crew cab swb psd 4" lift 35's
gtp38r turbo
stage 3 hybrids
Diesel Innovations tunes
DIY tymar intake
4" turbo back
6spd manual 4x4
MUD BOG TRUCK
82 full size bronco
solid axle d44 chromo axles 4.56's and a detroit up front
9" 4.56's and spooled in rear
c6 trans 4k stall np205
408w stroker @ 650 flywheel h.p.
Old 10-27-2012, 03:45 AM
speeddemon31176's Avatar
speeddemon31176
Offline
Demon Dually
Member's Gallery
Re: PLEASE HELP!!! E99 ROUGH IDLE NO POWER
That code is for the IDM module which is under the hood on the driver side. I would start by looking at the connections at the valve cover gaskets for burnt or damaged pins. The other possibility is that one of the connectors to the injectors on the inside of the valve cover gasket came loose. In order to fix that you need to pull the valve cover gasket and physically check it out. Look up the 25 cent mod for a permanent fix to this problem.
__________________
  #3
Old 10-27-2012, 05:26 PM
broncocarnage
Offline
Member's Gallery
i have checked the harness all the way to uvch, if it was a harness wouldnt it fail the buzz test? i have a friends truck over and im gonna try his idm and see what that does.
could it be cps?
  #4
Old 10-27-2012, 08:12 PM
speeddemon31176
Offline
Demon Dually
Member's Gallery
Nope it is an IDM code. Your IDM could be faulty. Just be careful you don't fry your buddy's IDM.
  #5
Old 10-27-2012, 09:00 PM
broncocarnage
Offline
Member's Gallery
swapped idm and still runs bad...
  #6
Old 10-27-2012, 09:31 PM
ghohouston's Avatar
ghohouston
Offline
whistle tits
Member's Gallery
Have you physically taken a volt meter to the uvch's?
__________________
"Shamoo"
2002 F250 7.3 E.C.L.B. e99 block. 18"KR Wheels, Rosewood 238/100's,BTS 4R100,Gearheads tunes,6637, 4 inch down, 5 back, 7” tip. DI headers, I.H. bellowed up pipes, Garrett 38r 1.0,CCV Mod
GIFSoup
  #7
Old 10-29-2012, 01:08 AM
DIESEL DAN's Avatar
DIESEL DAN
Offline
Member's Gallery
fuel pressure seems low at idle. bad pump???
__________________
Early 99'(10/18/98)f-250,4x2,Super Cab XLT 8' Bed
MBRP 4" Turbo Back W/ 5" Tip,
Grover 1700 Single Trombone Air Horn
Coolant filter Bypass W/ Napa Gold #4070 Filter
Air Intake #6637 Filter W/CCV Mod,V-10 Trans Cooler
Stewart Warner Gauges: Trans,Pyro,Boost,
15% Window Tint
Retro Solutions 55 watt HID's 5000k
08' Super Duty Finned Diff Cover
  #8
Old 10-29-2012, 05:40 PM
broncocarnage
Offline
Member's Gallery
i think my gauge is off i changed fuel pump and its the same.
  #9
Old 10-29-2012, 05:41 PM
broncocarnage
Offline
Member's Gallery
i got it pulled down to the valve covers after church and before football... ill get the uvch ohmed tonight.
(View-All Members who have read this thread : 38
7.3 X, 7.3psd1999, 97HorseHauler, Black Pearl, blandproud, broncocarnage, bryan.d, codykthekilla, cory99, coyoteecrownee, DIESEL DAN, dieselman81, drh4250, EmptyPockets, farmboy8201, Fordguy26, garrddogg, ghohouston, huck31, Hunter'97, jboord, jcc01, JoJo, jones184, Jordy53, Josh 99 7.3, Luke909, MOTO7.3, nopainnofear, Ohnny101, oldwood, polish pete, powersmoker73, PowerstrokeMudder82, RLSCOAL, speeddemon31176, wyattearp21, yzstroker11
You may not post new threads
You may not post replies
Forum Jump
