HPOP change out - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 OBS Power Stroke - Aftermarket & Performance
Thread Tools Display Modes
  #1
Old 10-25-2012, 11:30 PM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
HPOP change out
I think I Finally going to put my T500 in tomorrow. Any tips on putting it in? I have never changed one before
__________________
97 CCSB 4WD 7.3 5spd DP Tuner, 6637, 4" Flo-Pro SS Exhaust(3" DP), 99 I/C, T500,Cali Truck w/120cc Split Shot Injectors, 1.0 exhaust housing/WW2, Irate Up-pipes, CCV Mod, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, PMF Traction bars, Rear Air bags,SD springs Front(V code)/rear(B code), 315/75/16s, 300HP/561TQ
Old 10-25-2012, 11:33 PM
countryboyrob
Offline
Member's Gallery
Re: HPOP change out
Theres a write up on here in the library.
Took me about 2 hrs to pull mine off, most of that time was spent waiting for the phone to load and running back and forth for tools.
__________________
02 f250
  #3
Old 10-26-2012, 12:17 AM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
Re: HPOP change out
Got it , thanks. How To: 17* HPOP Install ('96 truck) - PowerStrokeNation : Ford Powerstroke Diesel Forum
Question though, can you reuse the HPOP gasket?
  #4
Old 10-26-2012, 12:34 AM
Tom S's Avatar
Tom S
Offline
-Moderator-
Member's Gallery
Re: HPOP change out
That is a maybe. I would put one on for the sake of not having an issue.
__________________
  #5
Old 10-26-2012, 12:49 AM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
Re: HPOP change out
I just called the dealer. They dont have one, they are going to over night it for me
  #6
Old 10-26-2012, 01:45 AM
ghohouston's Avatar
ghohouston
Offline
whistle tits
Member's Gallery
Re: HPOP change out
I would put ford grey silicone on the gasket... Any gaskets making metal to metal contact at work, we always use ford grey, it doesnt leak, it works miracles, im not the type of mechanic to slap silicone on everything either
__________________
"Shamoo"
1997 F350 CCLB 7.3 ZF5 4x4, 6637, straight pipe, Gearhead tuned, complete super duty e fuel setup for the haters who doubted me
2001 TDI Jetta 5 Speed 3" turbo back straight pipe, 4" tail, 5" tip DLC1019 Nozzles
  #7
Old 10-26-2012, 03:51 AM
Patrick Feeley's Avatar
Patrick Feeley
Offline
Member's Gallery
Re: HPOP change out
If I recall correctly, the factory gasket has the seal "traces" on it and is not metal-to-metal (strictly speaking). There should be no need for the sealant. Cheers!
__________________
  #8
speeddemon31176's Avatar
speeddemon31176
Offline
Demon Dually
Member's Gallery
Re: HPOP change out
You do not need RTV on the HPOP gasket. If you do put any on there, make sure it is a super thin film otherwise you could push it into the holes in the pump and create nightmares for yourself. A new gasket and proper torque is all you need.
As far as changing the pump goes, drain the fuel bowl and HPOP reservoir, pull the fuel bowl, disconnect the HPOP lines, remove cover to HPOP gear bolt on front cover, remove bolt for HPOP gear, unbolt HPOP pump and remove it. Put in a new IPR for peace of mind into new pump and reassemble in reverse order. Remember to torque HPOP bolt to 95 lb ft.
__________________
  #9
Old 10-26-2012, 04:44 AM
TerminatorEngineering's Avatar
Offline
Sponsor
Member's Gallery
Re: HPOP change out
As long as the HPOP gasket rubber is not damaged, it's completely re-useable. And as said above, do not use any sealer. That stuff gets into the intake port, it can cause IPR issues.
__________________
Visit us at: www.TerminatorEngineering.com for all your Big Oil needs.
SDRCM #7
  #10
Old 10-26-2012, 05:05 AM
old man dave
Offline
Terminator Nation
Member's Gallery
Re: HPOP change out
I use one leg of a gear puller with a screwdriver through it to hook the HPOP pump sprocket when tightening up the bolt. My engine seems to like rotating at about 90 lbs (automatic trans).
__________________
Just another 408hp '97 California Truck with a stock muffler
(View-All Members who have read this thread : 137
0bs7.3, 19stroker97, 250turbo, 444CuiOBS, 4btchev, 505yam, 7.3maniac, 7.3psd1999, 91F250XLIDI, 91forddiesel, 94.5stroker, 94Matt, 94powerstroke, 95doodoo, 96ford250, 96powerstroke96, 97-7.3powerstroke, 97dodgectd, 97psd16.5mpg, Alvapowerchoke, atedder91, BadDogPSD, beau tn, bentpushrod, biggreen96, bigwhiteone, BIG_RED, Binder man, Black Pearl, bmorervns20, Bradbilt, btomassacci, Centxdiesel, chris1978, co04cobra, Copperhead, cumminskiller69, Cundiff, D2HP, Dallas O, danielzink, deezeljunky, double-s-diesel, dragonboi, dslcat, Epd444, Etaylor, EverettWV, F350 FF, farmall16, farmboy93, fordboy, foxman, fpOwerstRokeD, fullmetaledges, ghohouston, gnxtc2, gsxr1216, H-Bomb, Hijo202, Its.Strokn.time, Jamie5714, jbrixen, JodyF350, JRF, jsnuke, KADEH, Kampy, kip4234, kramarj, loudmouth, lovesdunes, mandkole, MB97PSD, Michael97, micky_blue, Mike97f350, milesengineer, monster-energy-825, mr4speedford, mykaos, Nodge, np205, Oakes, old man dave, ontwowheels, Otter70, OverBoost, Parts guy, Patrick Feeley, Petro, PJB, poorboy's stroker, Power97Stroke, powerstroke095, powerstrokecarl, PSD00, PsRumors, pumpkinmike625, Ranger50, rayd1969, RickM, Rkidd121209, rpm-inc, rsfvscott1, screamnstroker, sg465, sharpmotors, shaynep, ShogunRider, Shovel, slutz4, smith7.3, sonnyy13n, spectreblazer, speeddemon31176, strokindd, stuckagain, swaan, TBarrsTruck, teevo20, TerminatorEngineering, The Struggler, ToddM715, Tom S, truckcap22, trykillthis, twentyfootdaredevil, wadeclinton, wannabstrokin, WidowMaker, woodking
You may not post new threads
You may not post replies
Forum Jump
