fuel pressure drops at wot - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 10-19-2012, 01:52 AM
sixOno's Avatar
sixOno
Offline
Member's Gallery
70psi at idle but as soon as give the truck wot run the pressure drops and will drop to zero if i let it. Just put a new upgraded airdog II on because i thought the pump was getting weak. Ive got the blue spring upgrade 6.4 banjos. What could cause the pressure to drop that low but only at wot? Im stumped.
__________________
190/100's,adrenaline hpop,powermax,arp's,58v idp modrate tuned ficm,extreme x,5'' exhaust,afe stage3,coolant filtration,oil bypass,egr delete,airdogII 165,6.4 banjos,sump,egt's/boost/trans/fuel gauges.
Old 10-19-2012, 03:48 AM
lenzhotrod
Offline
Member's Gallery
Re: fuel pressure drops at wot
A restriction,a bad fuel pump, plugged fuel filter.....
  #3
Old 10-19-2012, 05:53 AM
treetechsixOH's Avatar
treetechsixOH
Offline
Certified Engine Destroye
Member's Gallery
Yep^. Pretty cut and dry there.
__________________
___________________________________
03 CCSB Lariat 350 SRW
Built by me @ Outlaw Diesel Performance
Warren/K&N/Deleted/Exhaust, few other goodies.
Studs, SCT, Nitrous Express, ODP RR, Custom Fuel waiting for install.
  #4
Old 10-19-2012, 12:33 PM
Mhatlen's Avatar
Mhatlen
Offline
Fuel it up again Dummy
Member's Gallery
Send a message via MSN to Mhatlen
Have you replaced upper fuel filter, the airdogII is a new fuel conditioner/pump assy? I am assuming.
I have heard of guys having problems with pick up in fuel tank, may be where you need to look next. Does it change with a full tank of fuel?
__________________
2006 F250 Lariat SC 4X4, ScangaugeII,CAT EC-1,Sinister coolant filter,blue spring, Atlas40, Updated Turbo lines/stc/standpipes/dummy plugs, DC Power 190 alt., 4"exhaust straight piped, Amp Steps,Optima Blue Tops,7"fabtech lift w/D&R Coils,Rancho RSX9000,Toyo MT 38/15.50/18. 168 lbs of Dyna-Mat,Also 200 lbs of foam rubber under cab and firewall.
  #5
Old 10-19-2012, 12:55 PM
sixOno's Avatar
sixOno
Offline
Member's Gallery
I wouldnt think it has a pick up ptoblem because im running a sump. New airdogII 165. And i changed the top filter. This is why im thinking airdog pump is bad.
  #6
Old 10-19-2012, 02:01 PM
Zmann's Avatar
Zmann
Offline
Member's Gallery
what did fuel PSI do before you swapped pumps ?
__________________
O6 King Ranch cc sb 7 inch lift ,37 Toyo's,Helo’s Edge Insight CTS guage only , Auber EGT , o8 center console ,2x10 subs, xm satellite ,coolant filter,RSX 9000 shocks,dual bilstein steering stabilizers ,Viper , remote toolbox popper, High Idle mod , up fitters added ,weather guard mats , ARP's, BPD EGR cooler, Fabtech traction bars, X3 Matt's tunes
  #7
Old 10-19-2012, 03:57 PM
sixOno's Avatar
sixOno
Offline
Member's Gallery
Dropped the sameway
  #8
Old 10-19-2012, 07:14 PM
Zmann's Avatar
Zmann
Offline
Member's Gallery
? wonder if the regulator is having an issue
  #9
Old 10-19-2012, 08:45 PM
sixOno's Avatar
sixOno
Offline
Member's Gallery
Im gonna check it out and see if its alright
  #10
Old 10-21-2012, 05:38 PM
sixOno's Avatar
sixOno
Offline
Member's Gallery
well i checked the airdog regulator and it looks good. could this be the regulator by the fuel filter? this may sound stupid but y would i need the regulator up there if ive got a regulator on the airdogII?
(View-All Members who have read this thread : 71
'94IDITurbo7.3, 04 f350, 04harley250, 04La4iat, 2 Stroker, AJ 007, amdriven2liv, bismic1, Blowby, BlueOx, bond james bond, caleb90, cshsrh, CTC DEEZUL, Da Oops, dauntejoel, Dirtyboy82, dunatic, F-25000, farmboy8201, FastFiveO, fordfan30, ghohouston, gonehunting, HankyD, Harley Strokin', HeavyAssault, hustler315, jammin60, Justin6.0, justintimemoto, KCDAXFACTOR, king dinger, mastrkee, mej1201, Mhatlen, miller45103, mkelly, Nally7.3Powerstroke, Nutz, ohiopowerstoke, pa-powerstroke, polish pete, Polkville, RescueF250, RollingZrock, Ron-M, ronngat, shadow6.0, shmokenpstroke, sho669, sixOno, Slated4Greatness, Smoker05, Smokin Stroker, Snake, stoker04, stroked99_1/2, StrokeThis8, SuperBlazin, tatertot, The Butcher, treetechsixOH, tripletdairies, UNRULEE, Wheelhop, woodking, wrenchturner250, Zmann, zx800x
You may not post new threads
You may not post replies
Forum Jump
