| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Weird rattle from front end when going over bumps?
Hi guys,
I am experiencing a wierd rattle when going over bumps on the road. But it doesn't make this sound all of the time, only when the bumps and speed is significant enough. As a result, I retourqed my lug nuts as well as my caliper bolts, and tightened a number of things underneath the hood. But I am still experiencing the same sound under the same conditions. It sounds like it's coming from the driver's side and you need to have the windows down to really notice it. I intend to go underneath the truck to further investigate, but it could be just about anything and want to narrow it down a little at least. I read a post today about another member experiencing something similar. It was suggested that it could be the leaf springs which could be clattering when going over bumps. But it sounds like it's coming from the front end.. Thoughts... |
| Sponsored Links | |
Advertisement |
#2
Re: Weird rattle from front end when going over bumps?
Most of the time it's sway bar links.
__________________
2001 F350 CC SWB 6spd .......currently undergoing a makeover.....stay tuned. |
#3
Also could be bad ball joints.
#4
Sway bar links look fine.
#5
Ewxlt, is there a way I can confirm this? How common is this? I guess it would get worse over time?
Everything else looks fine and tight from underneath. |
#6
They may look fine but..........................
Just search 'sway bar links' and see how it's hard to tell if they are good or not. And here's an easy way to find out: Remove the bar completely. Should take all of 10 mins. Then you know for sure and it did not cost you anything. If the problem is still there, ball joints would be my next target. |
#7
Also could be leaf springs slapping each other, if its more of a clunking sound. But if it feels like its something hitting your floorboard, its probably sway bar links loose or bushings
__________________
"Shamoo" 2002 F250 7.3 E.C.L.B. e99 block. 18"KR Wheels, Rosewood 238/100's,BTS 4R100,Gearheads tunes,6637, 4 inch down, 5 back, 7” tip. DI headers, I.H. bellowed up pipes, Garrett 38r 1.0,CCV Mod |
#8
Thanks |
#9
IF you have the same problem i do, the leafs are worn out. I guess you could be ghetto and stick rubber in between tgem, im working on getting new leafs though... But yeah mine has been a light clunking Sound over bumps... Checked suspension thoroughly multiple times. And its not really anything to worry about. Im going on 3 years of clunking
#10
I guess, if it were the leafs, I would be able to look at them and see a clear space in between them? Thanks again! |
(View-All)
Members who have read this thread : 71
| 02powerstrokeguy, 03sixspeed, 06 SuperDuty, 2002f-250, 97stroking1982, 99whitestroker, a141sparky, Aaron S, augustus89, Betaracer, Bigblack350, billc, Bobs 7.3, Bumpin, CraneMech81, crete3845, damiensdad2, devinferg, drkndzl22, E99Superduty, eleventhtruck, evilhans, ewxlt, fatfender, firedriver19, Fuzz, ghohouston, HankyD, jammin60, jeromejcp, jestersv, jjlw, jparker, juvenile9, kystanger, LOOSEWHEEL, Madisdaddy0505, maritimer10, milehighstroker, mtray, mxjeepin, ntruderrider, Ole, passntime, podirtfarmer, powelce, powerstroke113, Powerstrokinfirefighter, pro350hydro, PSDaddict, pwrboatr, raptor, richard720, Rixster, Rock762, roofcock, rooster, RustBucketDA, sargepep56, scparrish, Shep, silent64, SledDogg, Smoker05, tbeckett, treetechsixOH, trucker4x4, villestrip, Wannabe, Wazincow, WYOutlaw |
| Thread Tools | |
| Display Modes | |
