| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
6.4 to a 7.3 or 6.0???
So my 6.4 was totaled and have decided to step down to a older truck. I was looking at buying a 7.3 or a 6.0. Why should i buy a 6.0 over a 7.3 and what all is required to really start building some power. What are some things to look out for?
__________________
Murdered 2004 EX v/b mod valved blistens 08 mirrors 05 headlights 20x9x37 5" SCT LiveWire flopro exhaust head studs egr delet coolant filter 6.4 banjo bolts 4.5bs 8 1/2 western V plow Oh ya and train horns of coarse. |
| Sponsored Links | |
Advertisement |
#2
Re: 6.4 to a 7.3 or 6.0???
Get a 6.0 I'll sell you mine!!
__________________
07 ford f250 Josh Vandyke |
#3
A 7.3 is a pretty easy motor to build. I am personally a big fan of the 6.0L. I love the t
torque shift tranny in the 6.0L. It is way more reliable than the 7.3L tranny. Yu can't go wrong with either. If you really want to do research get on YouTube and watch the videos from powerstrokehelp.com. This guy is extremely knowledgeable about all powerstroke engines. Please please please if you do buy a 6.0l make sure you buy one with ALL mintaince records. Iwould hate for you to get stuck with someone's problem. I have a 7.3L excursion 6.0L F-250 and the new 6.7L (F-450) and I will tell you right now I would rather drive my 6.0L over any of the other trucks. I just love love love my 6.0L.... |
#4
I would stick with a 6.4 but that is because I want one. I like my 7.3 and wouldnt mind a 6.0 but they are both old hat. And I wouldnt buy a 6.7 (although I would take one if it were given to me
) mainly because of it not having an International under the hood. Anyhow that is my opinion, good luck with yours and have fun shopping.
__________________
2002 CCLB 4X4 6" skyjacker lift * Ford AIC * 4" turbo back Diamond Eye exhaust * 6637 mod w/ Donaldson filter * Gauges* No Foil * Edge Insight CTS 1988 Camaro Iroc Z 2000 Polaris Scrambler 4x2 400- Bored out and tuned by DAB Racing ~Andy~
#5
Is there some links to what needs to be done to a 6.0 to build power?
#6
There's a thread at the top of this section called "Horsepower goals for 6.0"
#7
ya i was looking at it nothing to specific. Someone want to give me the run down on head studs what to use and why and the oil cooler?
#8
I have arp studs in mine along with the oem gaskets, DO NOT get the black onyx gaskets. I had those on my truck for 4000 miles before they blew. My mechanic installed them right but there just crap. The reason we use head studs is the fact that the factory bolt are weak and let the head lift off the block, which blows your head gaskets. The thing with the oil cooler is it can become clogged over on the coolent side, which lets your oli temp get really warm. Mine blew when my egr went bad, so I replaced the cooler and deleted the egr. Thats something else you will want to do is get rid of the egr, they cause havoc to your coolent and usually system and when they go out they take the oil cooler with it.
__________________
2004 6.0 Crew Cab 4x4-Arp studs, OEM gaskets, egr delete, 4in turbo back, air dog 2,blue spring upgrade, Warren 205/150s, Warren Comp Trans, Mad Turbo Werks Stage 4, coolent bypass lines, sct live wire with looney wild and extream x, autometer phantom 2 gauges, 58v ficm, afe stage 2 intake, zoodad mod, ccv mod, 6in lift, 35's |
#9
So what kind of head studs oil cooler and egr delete do you recommend? I have to make some power with this as well. So i wil be doing exhaust intake and a tuner any recommendations on this as well i am currently looking for a excursion is it matters.
#10
You cant go wrong with arp head studs. If youve got some money to spend you sould get a bullet proof diesel oil cooler. They totally relocate the stock one so that is actually uses air liquid insted of your coolent cooling the oil. Egr delete dosnt really matter to much as long as you get the replacement up pipe with the kit and not just a block off one. For exhaust I would get a 5in mbrp with no cat, you dont need an intake until you swap out for a bigger turbo, and I would get an sct tuner livewire or x3. Cusom tunes will make a big difference too, and there not that expensive.
| Thread Tools | |
| Display Modes | |
