2006 6.0 oil leak PICTURES INSIDE - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 10-15-2012, 10:49 PM
blake b
Offline
Member's Gallery
hey guys i have a 2006 f450 with 6.0 and i noticed today a few wet oil spots under it and after looking around in the parking lot at where i usually park its been leaking for a while.it is dropping from the bell housing and the starter is covered in oil, also i popped the hood and there was a large amount of oil on the bottom side of the hood and alot down on the valley of the engine. i took pictures so hopefully some one will be able to help me out. thanks alot in advance
Reply With Quote Quick reply to this message Go to the top
Old 10-15-2012, 11:41 PM
CTC DEEZUL's Avatar
CTC DEEZUL
Offline
Hood Rich
Member's Gallery
Send a message via AIM to CTC DEEZUL
Re: 2006 6.0 oil leak PICTURES INSIDE
check the blue boost boot on the outlet of turbo
__________________
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
  #3
Old 10-16-2012, 01:19 AM
blake b
Offline
Member's Gallery
just checked the hose and it appeared to be good but what i did find is on the dip stick the part that slides down over the dipstick tube is broken off and basically the handle is sitting right on top of the tube. could oil make its way all the way up the tube and spray out the top? in the pic you can see the part thats broken off its slid down the tube a little way
  #4
Old 10-16-2012, 01:24 AM
SnowWhite6.0's Avatar
SnowWhite6.0
Offline
Member's Gallery
Run it and check the oil cap or the oil filter houing .. seen both of them crack before ... Best thing to do is spray it off and drive it and see where it comes from
__________________
SnowWhite- hot tune, head work, stuff deleted, little more air flow. Your not so typical 6.slow
Previous truck- 95 12v 550hp. Lots of fuel lots of timing.. head work big sticks... SOLD to younger brother
-Jordan
  #5
Old 10-16-2012, 01:55 AM
ghohouston's Avatar
ghohouston
Offline
whistle tits
Member's Gallery
looks like you also have quite the exhaust leak there...
__________________
"Shamoo"
1997 F350 CCLB 7.3 ZF5 4x4, 6637, straight pipe, Gearhead tuned
2001 TDI Jetta 5 Speed 3" turbo back straight pipe, 4" tail, 5" tip DLC1019 Nozzles
2002 F250 7.3 E.C.L.B. e99 block. 18"KR Wheels, Rosewood 238/100's,BTS 4R100, 4 inch down, 5 back, 7 tip. DI headers, Garrett 38r 1.0,CCV Mod sold at 286k and missed
  #6
Old 10-16-2012, 02:17 AM
lenzhotrod
Offline
Member's Gallery
I agree with the bad exhaust leak and I also think it may be the oil filter cap/housing leaking. Follow the oil towards the front of the vehicle and to the highest point.
  #7
Old 10-16-2012, 02:34 AM
Bubbawagsf250's Avatar
Bubbawagsf250
Offline
Member's Gallery
no its not from the dipstick tube cause
i have the samething on my truck that
little part is gone and it never leaked
  #8
Old 10-16-2012, 03:39 AM
blake b
Offline
Member's Gallery
Checked the oil cap everything is dry and i srarted ot and looked around and camt see oil physically coming from anywhere really the valley is the only thing covered in oil if that helps
  #9
Old 10-16-2012, 03:45 AM
treetechsixOH's Avatar
treetechsixOH
Offline
Certified Engine Destroye
Member's Gallery
Easiest way to find an oik leak like that is to soak the engine in degreaser for about 15 minutes, rinse with a hose. Let the truck idle until you find where its leaking from. I did one the other day. I started the truck and went a did something else for about 20 mins. After returning i found the leak immediately. The glow plug connector had come unseated.
__________________
___________________________________
03 CCSB Lariat 350 SRW
Built by me @ Outlaw Diesel Performance
Warren/K&N/Deleted/Exhaust, few other goodies.
Studs, SCT, Nitrous Express, ODP RR, Custom Fuel waiting for install.
  #10
Old 10-16-2012, 04:27 AM
blake b
Offline
Member's Gallery
I will do that first thing in the morning
If you do not want to register, fill this field only and the name will be used as user name for your post.
Human Verification
(View-All Members who have read this thread : 91
06 f250 man, 06Powerstroking, 50gstroked, 521TURBO, 5954cc, 7.3, 93_444idi, abbottfarms, AGV2006PSD, amdriven2liv, big deal, BIG99, BigBlack03, BlAcKeNeD, blake b, bryanlayne, Bubbawagsf250, buggut, caleb90, chief410, Chuck550HD, codykthekilla, CTC DEEZUL, D66stroke, Darkhorse, dauntejoel, daywalker, devinferg, Duracrap, ernieb143, Flatbedcowboy1, fluent09, Francismp, frenchy 111, ghohouston, goodoleboy45, griffin6997, HankyD, Harley Strokin', HeavyAssault, hustler315, jb772, jeffdschulz, Jingoist, Joemahma, johnsdeere, JumpMan92, Kirkpatrick004, lilcrowe, majek5, mandkole, mastrkee, Mhatlen, Mr.Wonderful, mx185sw, ndenyse, nitrouskid2601, NJ2005X, njmudrat, Nutz, OrangeBlood, Phil@dieselcore, PowerStroke94, powerstrokedkid87, POWERSTROKE_GOD, Realdealoo8, Roush4_6, ryahh21, seanmesaeh, Shovel, Six Liter, SIXOHKID, skippy 1058, sly1types, smergen, smokenblack, Smoker05, SnowWhite6.0, sonnyy13n, SootRoller, StrokeThis34, tamo2004, toolmangary, treetechsixOH, wango1, wannabstrokin, Weatherlite, webb06, wkrpinnick, you smoke
Forum Jump
