| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
white smoke after stage 1 injectors
i have a 2000 super duty i just installed rebuilt stage 1 single shot injectors from full force diesel an 6 pos chip with tony wildman tunes about 1000 or so miles since the swap my truck now blows white smoke at start an keeps smoking untill warm the smoke smells like raw fuel i took my time when doing the injctors ie checked an cleaned cups tightened everything to spec did i do something wrong? truck never smoked untill after injectors also did new glow plugs gaskets it starts very easy even when cold an runs better than it ever has just smokes alot untill warm any help on where to start would be great.
| Sponsored Links | |
Advertisement |
#2
Re: white smoke after stage 1 injectors
Does it continue to smoke at all after it warms up? It could be that you have an injector that is sticking and dumping fuel when cold then freeing up once it warms up. Even new stuff can be bad out of the box.
__________________
97 F-350 XLT CC DRW 4X4 PSD, 285/75-16 Custom bumpers, Gauges-boost/egt/trans, Swamps IDM, 3.5"dp- 4" exh., 3" Body lift, ES bushings/mounts, Built trans, billet conv, B&M pan, Hayden cooler, Adrenaline, stage 2's, IC, H2E, E-fuel ARP's, 910's, Smith Bros. to come |
#3
thanks for the reply it seems to clear up after about 10 to 15 mins of running an doesnt smoke after i start to drive it. is there a way to pin point witch injector is causing the smoke without pulling them all
#4
Runs some Rev-X through it, should free that sticky injector/injectors.
#5
ill give that a try but i really dont want to keep running it with the amount of smoke it puts off when cold ive read some stories of washing cyl down an breaking rings an such dont want to ruin the motor over a set of 1100 doller injectors i wouldnt be happy
__________________
2000 super duty crew srw psd 6 speed stage 1 injectors ts chip with tony wildman tunes k&n intake boost fooler wicked wheel IAH delete with boost fitting glowshift gauges fuel,boost,pyro 35 12.5 vortracs on 18s 4" exhaust 5" tip stage 4 clutch, bellowed |
#6
Did you run a straight edge across the top's once you were done? Did you install new O rings on them along with new coppers?
__________________
01 F-250 SC PSD,260k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, P.I.S 230/100, Studs, 910 springs, Forged rods, Water injection,Swamps Tuning, MBRP 4" dual's, Aero, 6" tip's, 100 axl tank, 4" Revtek lift, 37-12.50-16.5 MT's
Joe ISSPRO PERFORMAX GAUGES |
#7
they came ready to drop in new orings an coppers i did tq them to 120 in lbs i did not put a straight edge them but they all looked even i taped on them with a dead blow an a peice of 2x4 to make sure they were seated lightly. thanks for the replys im starting to think i should have bought new injectors.
#8
im goin to pull it apart tomrow an chech them with a straight edge but could it be a injector stuck open an dumping too much fuel? ive heard really good things about full force diesel injectors an they should go good on them if it turnsout to a injector
#9
Injectors do not "stick" open. You could have a broken nozzle, but if so it would smoke all the time.
I am assuming you have tuning to match the single shot injectors? |
#10
[QUOTE=CSIPSD;1925629]This is not a 6.0... Stick to something you have a clue about.
Hmm.. I put a set of stage 1's in my 7.3 and I was having the same problems as the OP until I sent rev-x through it. |
| Thread Tools | |
| Display Modes | |
