Erratic idle after highway driving - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 10-12-2012, 03:01 AM
smokenblack's Avatar
smokenblack
Offline
cuz Chevy and Dodge SUCK!
Member's Gallery
2005 F-350 6.0 105K. Truck starts fine every time, idles and drives normal. Only after holding highway speeds for more than 15 minutes and coming to a stop the engine begins to lope erratically and intermittently. Hit the go pedal and moves right along only with an occasional surge in power. Only current code is for glowplug on a single cylinder. Cleaned EGR valve, changed oil and both fuel filters, air filter is clean, removed programmer and returned to stock tuning and nothing changes. Any ideas?
Old 10-12-2012, 04:20 AM
Mhatlen's Avatar
Mhatlen
Offline
Fuel it up again Dummy
Member's Gallery
Send a message via MSN to Mhatlen
Re: Erratic idle after highway driving
Nice driver front tire thingy there,lol You have a scan tool to check ficm/icp/ipr when its doing it?
__________________
2006 F250 Lariat SC 4X4, ScangaugeII,CAT EC-1,Sinister coolant filter,blue spring, Atlas40, Updated Turbo lines/stc/standpipes/dummy plugs, DC Power 190 alt., 4"exhaust straight piped, Amp Steps,Optima Blue Tops,7"fabtech lift w/D&R Coils,Rancho RSX9000,Toyo MT 38/15.50/18. 168 lbs of Dyna-Mat,Also 200 lbs of foam rubber under cab and firewall.
  #3
Old 10-12-2012, 05:18 PM
smokenblack
Offline
Member's Gallery
Thanks, I enjoy her daily.
Yes..what should my baseline readings be and/or what am I looking for?
  #4
Old 10-12-2012, 05:47 PM
Mhatlen's Avatar
Mhatlen
Offline
Member's Gallery
Ficm should be 48 volts +or_ at all times and all speeds.
The ICP should be around 580 at idle and IPR around 21%
You can take the values of icp/ipr:
koeo
idle
1500
2500
All need to be taken at 190* +or_
Post those and will look up where they are ideal.
Also if you can see egr desired and egr position you can rule that out.
It may be a injector causing you the grief ??
  #5
Old 10-14-2012, 02:57 PM
smokenblack
Offline
Member's Gallery
Will post data as soon as I can. Truck hasn't missed a beat the last 2 days with the scanner hooked up in record mode!
  #6
Old 10-17-2012, 03:40 AM
smokenblack
Offline
Member's Gallery
Question Re: Erratic idle after highway driving
Is it normal for my EGR position voltage to always be 0.00V? This value never changes, always 0 at idle, acceleration and cruise. All other values shown above right on the money.
  #7
Old 10-17-2012, 11:59 AM
Mhatlen's Avatar
Mhatlen
Offline
Member's Gallery
No the egr is controlled via map sensor and pcm adjusts as necc, you may check wiring harness to both. It should be throwing a cel either way.
Do you have a custom flash for your pcm where it was rolled back and egr is deleted as far as pcm goes?? PHP I believe does this with his tunes.
You can always probe your egr plug it uses 5 volts max in operation IIRC.
  #8
Old 10-18-2012, 12:31 AM
smokenblack
Offline
Member's Gallery
I returned the PCM to stock programming to see if the tune was the cause of the erratic idle. I never looked at the egr position voltage with the tune installed. No CEL with stock or custom tune. Could the EGR valve be bad or not moving causing the position voltage to always be 0?
  #9
Old 10-18-2012, 01:10 PM
Mhatlen's Avatar
Mhatlen
Offline
Member's Gallery
Can you track both: actual position and desired for egr with your scan tool?
It would be worth the time to pull it and see if its coked up, also take close look at the o-rings if they are leaking.
Do you have a way to check fuel pressure? have you put in blue spring for fuel pressure regulator
  #10
Old 10-18-2012, 02:08 PM
smokenblack
Offline
Member's Gallery
No way to check fuel pressure and and I have not done the blue spring installation. I will check and see if I can view position and desired together.
(View-All Members who have read this thread : 71
03fathead6.0, 04 f350, 04 oilburner, 04harley250, 04La4iat, 06f350stroker, 7.3Xenia, amdriven2liv, bf9412, bhc99, BigBlack03, Bigdog, BINGS6.0, bismic1, blackhawk783, Bumpin, caleb90, Diesel Jay, feeldman, fordfan30, gman77, gonehunting, halhiggins, HankyD, HM-8404, hustleman7777, hustler315, JD3020, Jeffro92, Jnalaplace, jobsi, johnsdeere, jp115, Justin6.0, ktmrydr686, leroynasty, maverik2711, Mhatlen, miller45103, mjcolemn, mkelly, muddynoll, mxjeepin, mxned, nitrogen, nrook, paranoidredneck, polish pete, power-smoke, pwrstrkr, Realdealoo8, Redline7.3, RescueF250, rkmarcum, Rocky mountain stroke, Ron-M, SDER1, seanmesaeh, Shef, Six Liter, smokenblack, Smoker05, stoker04, stroked99_1/2, Super Duty Dude, surfdunn, tatertot, tbuilt, Wheelhop, you smoke, zilla68
You may not post new threads
You may not post replies
Forum Jump
